Valve questions from a total numpty |
Post Reply | Page <1 3456> |
Author | ||
Drewan77
It won't work in Bobs' amp but it might still produce moo-sick, ouch
Possibly the right answer but x-rays aren't as much fun! |
BackinBlack
Not got a clue about AI, but each to his own....
As for X-rays not being fun, remember those machines in shoe shops where you stood with your toes in an aperture and looked down into a screen to see your feet (bones) within your shoes? Edited by BackinBlack - 24 Jan 2016 at 6:07pm |
Martin1
Regular Joined: 19 Feb 2013 Location: Berks Status: Offline Points: 87 |
Yes I do ,which shows both our ages . They still got my size wrong so was not exactly fool proof
still wondering why the nurse is smiling ,must be my natural innocence . Martin |
Novo Solo SRGII PSU1 Cusat 50 Senn:250 Senn: 540II & Big Wish List
Moderator Group Joined: 23 Dec 2009 Location: Middlesbrough Status: Offline Points: 9001 |
When I last logged in we were talking about anodes and cathodes. I come back and it's bovine gynaecology and proctology . Yes it's good to share experiences but I thought we'd be onto cathode bypass caps or something similar!
Yes, it has gotten out of hand a little and I must admit my sense of humour got the better of me, but the question was asked Now, cathode bypass caps are an interesting subject too: They're there to couple the cathode to ground for ac signals. At DC the resistor is required to lift the cathode voltage which makes the grid voltage negative with respect to the cathode. This biases the anode to somewhere between HT and ground. Just the right amount of voltage cathode to grid will bias the anode at half HT voltage allowing it to swing the full ac signal between HT and ground. If the bypass capacitor weren't there the gain would be reduced and would be the ratio of anode and cathode resistors (given a proper HT rail which many "new" designs don't), so for maximum gain from the valve, the cathode bypass capacitor is required. It needs to be large enough to do the lowest bass frequency expected and the formula F=1/2pi.RC is used for that. Rearrange to give C = 1/2pi.FR This particular bypass capacitor is where a lot of tweakers spend a lot of effort on. They seem to try lots of different types of capacitors and often bypass the bypass cap with all sorts of wonderful schemes. Instead, why not just put a high voltage GP 85 degree electrolytic there? 63V to 100V should work really well. Just ensure it's given sufficient ventilation to keep it cool. Beats Blackgates IMO! Edited by Graham Slee - 25 Jan 2016 at 7:07am |
The "story" of the valve (tube) is related quite well here:
http://www.allaboutcircuits.com/textbook/semiconductors/chpt-13/the-triode/ http://www.allaboutcircuits.com/textbook/semiconductors/chpt-13/the-tetrode/ http://www.allaboutcircuits.com/textbook/semiconductors/chpt-13/beam-power-tubes/ http://www.allaboutcircuits.com/textbook/semiconductors/chpt-13/the-pentode/ keep clicking next page for more in-depth stuff. The very first page shows that valves have the same problems as transistors... capacitance. However, the Tetrode and Pentodes came into being to "solve" the problem whereas different techniques are used with transistors. Those techniques do not work for high powered high frequency circuits (like some radio transmitter power amps) where valves hold the monopoly. A good page for determining bias and gain of valves is: http://sound.westhost.com/valves/bias-gain.html |
