New Posts New Posts RSS Feed - ULDE Volume Question
southall-1998 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote southall-1998 Quote  Post ReplyReply Direct Link To This Post Topic: ULDE Volume Question
    Posted: 23 Oct 2021 at 12:51am
Got a second hand ULDE, sounds very good.
My question is about the volume.
I'm using 300 ohm Sennhesier HD600 Headphones. These are the latest ones (2019).
Comfortable listening volume on ULDE is at 9 o'clock, I get plenty enough sound at this level.
But I this find odd. I thought ULDE with high impedance headphones, you had to adjust volume after 12 o'clock?
My ULDE is connected straight to a Marantz PM6006 (UK Edition) CD Player.
Thanks.
S.
Shane Lonergan.
Telling it as it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 4:15am
Yes, that's for a range of sources that comply with IEC 61938, but at 2.2 volts rms, your CD player outputs about four times that, so you would turn the volume down, as you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 2:54pm
The Solo dial position will depend on the signal level going into its input as well as the impedance/sensitivity of the output load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote southall-1998 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 5:22pm
Alrighty! Thanks chaps.
S.
Shane Lonergan.
Adytiger View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Adytiger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2021 at 7:55pm
Trialling the ULDE at the moment through the loan programme ( currently listening to Peter Gabriel Sledgehammer as I type!) with Beyerdynamic DT 880 edition ‘phones, 600 ohm. Volume control set at between 9 and 11 o’clock seems to work for vinyl and cd inputs.
