New Posts New Posts RSS Feed - Technics linear trackers like SL-7
 Post Reply Post Reply Page  <1 1819202122>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2022 at 5:25pm
Excellent news on the SL-7's homecoming. Happy listening Ifor.
BlueMountain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlueMountain Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 2:56pm
I highly recommend the Technics 310MC cartridge for this deck. It was designed for a closely related model and the detail extraction from the boron tube cantilever is almost beyond belief. A good example costs about the same as a new Goldring 1042, and it’s a lightning bug vs lightning difference between the two (to my ears). Plays great with the Reflex C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlueMountain Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 3:41pm
Btw, another great thing about these decks is that you can use a stack of records as an isolation base. Works great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 7:07pm
I may try that a some point...
Post Options Post Options   Thanks (0) Thanks(0)   Quote lfc jon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 8:09pm
Just make sure you use old records you don't like.Evil Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlueMountain Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2022 at 4:41pm
Here's my SL-6 (flimsier than the SL-7, but this one sounds lovely) on the easiest isolation base I've ever built. I'm on the eighth floor of an old building that has a major subway line running directly underneath it. This stack of records eliminated the rumble I was getting like magic. That said, if it hadn't been a problem to begin with I wouldn't have bothered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2022 at 7:43pm
Thanks Stephen. The prismatic rainbow looks very good, nice photo. It is interesting how the combination of records and cardboard can absorb the vibrations.
Edited by Fatmangolf - 01 Sep 2022 at 8:09pm
