New Posts New Posts RSS Feed - Specks for surface mount etc
Dave Friday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Friday Quote  Post ReplyReply Direct Link To This Post Topic: Specks for surface mount etc
    Posted: 05 Jul 2019 at 6:10am
Good morning all,as above,what do you use?
Ta.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 9:12am
Do you mean as in glasses?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Friday Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 10:33am
Yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 11:31am
Well, me being well on my way to being blind as a bat (good hearing though!) I use my walking around specks and my reading glasses together, and that's sufficient to run the solder down each side of a SSOP. But to inspect the quality of the soldering I then add a x7 or x9 (depending on what I can find on the bench) "big eye" (eye glass). Obviously I can't do production.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drewan77 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 1:55pm
Two or three sets of optics at a time eh Graham?
 ....makes you sound like a specks maniac.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Firth Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 2:27pm
In the words of the song .....
My eyes are dim, I cannot see,
I have not got my specs with me,
I have not got my specs with me.
Spellchecker has a lot to answer for Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Friday Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 3:08pm
Thanks Graham,tried your trick but as all my specs(specks is wrong according to wife n daughter)are bifocal or varifocal it didn't work!
Seeing the optician tomorrow.
