New Posts New Posts RSS Feed - Reflex M power plug size
audioDtek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioDtek Quote  Post ReplyReply Direct Link To This Post Topic: Reflex M power plug size
    Posted: 29 Jun 2020 at 10:04am
Hello,
I would like to know the type and dimensions of the power plug on the Reflex M so that I can find a match on mouser.com or any other online store. The other one is to buy one from you if possible and arrange it through the dealer.
Edited by audioDtek - 29 Jun 2020 at 10:09am
Laptop → M2Tech HiFace2 → Audiogd DAC-19MK3
Thorens TD160 Super → Rega Elys2/Rega RB300 → NAD PP2, AKAI GX-630DB, AKAI GX-75mkII
Meridian 501 → Meridian 556 → B&W 685, Matrix M-Stage, Senh. HD580
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 12:56pm
It's an IEC C7 also known as Figure of 8.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioDtek Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 1:08pm
I think you mean the PSU1 connector. I am talking about the connector on the Relex M.
Which male plug should I buy to fit there?
Edited by audioDtek - 29 Jun 2020 at 1:09pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 2:03pm
Sorry, misread and misunderstood your question. Measuring the ones on my redundant green PSUs I get 5.5/2.5mm.
Hope that helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioDtek Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 2:18pm
Thanks! And as I see the jack has Swc on it which probably means Switchcraft. I see they make good quality products.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioDtek Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2020 at 7:32pm
The socket uses the inside as a (+) and the outside and a (-)?
Post Options Post Options   Thanks (2) Thanks(2)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2020 at 7:45pm
Correct.
This page was generated in 0.141 seconds.
