Post Reply | Page <1 910111213 16> |
Drewan77
Hi Richard, interesting findings & it looks like any differences are very subtle (familiar 'audiophile' words…. 'perhaps, possibly, slightly, maybe, marginally' are used, sometimes frequently!).
Your posts suggest that most likely my Accession M & Reflex M wouldn't benefit from one of these.
Richardl60
from my experience probably not Andrew though sure system to system and ear to ear my result in slightly different opinions. Will see if the DC lead makes any difference to the enigma. From others comments likely to be different with the Accession MC
I think the dc lead helps and recommend comparing the combo with the standard PSU1. Most of my testing was with the AccMC, then I used the Enigma and its lead with my EXP. More noticeable on either than the AccM in my system. The Majestic definitely benefitted when I tried that later.
DeadWax
New Member Joined: 18 Jan 2014 Location: Lincoln, UK Status: Offline Points: 25 |
Am I understanding that here you are saying that you've upgraded/changed the electrical outlets in your house?
Andy R
Lincoln, UK |
Richardl60
yep furutech
That's what I originally told people, but some thought it did.
DeadWax
Blimey, was this in response to a specific interference problem you were having, or is this a fairly standard practice to get the best out of a system?
Andy R
Lincoln, UK |
