 Post Reply Post Reply Page  <1 910111213>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drewan77 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 1:48pm
Hi Richard, interesting findings & it looks like any differences are very subtle (familiar 'audiophile' words…. 'perhaps, possibly, slightly, maybe, marginally' are used, sometimes frequently!).
Your posts suggest that most likely my Accession M & Reflex M  wouldn't benefit from one of these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 4:00pm
from my experience probably not Andrew though sure system to system and ear to ear my result in slightly different opinions. Will see if the DC lead makes any difference to the enigma. From others comments likely to be different with the Accession MC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 4:08pm
I think the dc lead helps and recommend comparing the combo with the standard PSU1. Most of my testing was with the AccMC, then I used the Enigma and its lead with my EXP. More noticeable on either than the AccM in my system. The Majestic definitely benefitted when I tried that later.
DeadWax View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DeadWax Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 4:45pm
Originally posted by Richardl60 Richardl60 wrote:
In this context all my mains feeds have been highly upgraded, from dedicated consumer unit, 10mm twin and earth feed to upgraded wall socket, power HUB and leads to individual devices oh and an earth rod too - suspect the effects may be cumulative.
Am I understanding that here you are saying that you've upgraded/changed the electrical outlets in your house?
Andy R
Lincoln, UK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 6:10pm
yep furutech
Telling it as it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 7:12pm
...Your posts suggest that most likely my Accession M & Reflex M wouldn't benefit from one of these.
That's what I originally told people, but some thought it did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DeadWax Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 11:14pm
yep furutech
Blimey, was this in response to a specific interference problem you were having, or is this a fairly standard practice to get the best out of a system?
Andy R
Lincoln, UK
