Phono Cartridge Loading For Moving Magnet?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=992
Printed Date: 27 Mar 2026 at 1:05am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Phono Cartridge Loading For Moving Magnet?
Subject: Phono Cartridge Loading For Moving Magnet?
Date Posted: 10 Oct 2010 at 4:13am
Thousands ask the question "What is the correct loading for a moving magnet phono cartridge" and never get a straightforward answer.
IEC (CEI) 6-1938 gives the answer as being 47k Ohms and 420pf. IEC (CEI) 6-1938 is usually promptly "trashed" by all and sundry!
I mean, how do they have the nerve to suggest anything contrary to the forum masses?
It's obvious that a collective of any number will concur the correct answer is that put forth by the most prominent/strongest member... isn't it? Hang about! That's not very scientific!
Plugging in the IEC values to my phono cartridge model (see http://www.gspaudio-community.activeboards.net/forum_posts.asp?TID=964&PID=7158#7158 - http://www.gspaudio-community.activeboards.net/forum_posts.asp?TID=964&PID=7158#7158 for some background) the -3dB high frequency response is only just 15kHz! But most moving magnet cartridges specify at least 20kHz - that can't be right?
And this is exactly where the "little knowledge is a dangerous thing" goes on the rampage thinking the wrong thoughts.
Taking a look at the first page of the aforementioned topic a chart can be seen showing response curves for different capacitive loadings of an average moving magnet cartridge - the resistive load maintained at a constant 47k Ohms. It can be seen that with increasing capacitive load the response kicks up (there's a peak in the response) just before it starts cutting (falling off). To the uninitiated any peak in the response is wrong, but delve into filter design and it will be noted that the steeper the roll off, the greater the peaking prior to roll off. If we were talking about a simple RC network giving a single pole filter with slope -6dB per octave we wouldn't expect a kick, but capacitive loading of an inductive source results in a double pole -12dB per octave (LCR) filter - a kick in the response is inevitable.
So what else can we deduct? My old mentor Dr Jones always said "from what we know...". So what do we know? Well, if we knew something about history, we would know that old father hi-fi - real high fidelity of yesteryear, had a frequency response of 30Hz to 15kHz.
15kHz? Yes, 15kHz, the -3dB frequency you'd get for a 420pf (with 47k) capacitive load. So maybe the IEC standard 6-1938 has a point?
But in that case how can a moving magnet cartridge manufacturer claim an upper frequency response of 20kHz or more? Either he breaks ranks and dictates a different load - and a few "newbies" to the cartridge scene seem to get away with this - or there's something more we need to understand?
And the answer is yes, we need to understand stylus resonance (more correctly put as stylus cantilever or stylus tube resonance). Stick a stylus on the end of a tube (which you have to do anyway, to give some distance between the cartridge body and the record surface) and every time the stylus moves there will be some reluctance for the stylus tube to bend so that the power transfer is optimised in the cartridge coils. The stylus tube is considerably stiff, but its reluctance will give at some point. To get a frequency response higher than the yesteryear's 15kHz the manufacturer's only serious approach is to make the tube's resonance happen in such a way it carries the response above 15kHz.
Reluctance is a word also used to describe the behaviour of an inductor, and therefore the resonance could very well be arranged to mirror the LCR behaviour of the electrical load - the 500mH inductance of the average MM cartridge (L), the 47k load resistor (R) and the 420pf capacitive load (C). It would make sense if it did. And if that were to be the case, the up-kick in the electrical response would be countered by a down kick in the electro mechanical response, making the actual response flat!
If this did not make sense then loading a 600mH cartridge such as the old Ortofon VMS20E II moving magnet cartridge with Ortofon's suggested 400pf would be crazy. But if you don't load it like that you'll find this quite brilliant cartridge will hiss a spit like a rattle snake!
What is happening by unloading the capacitance is that the highs are increasing beyond 15kHz due to stylus tube resonance. By unloading the capacitance the electrical response peak is "cured" (more likely negated much more) but the response doesn't fall at the expected rate until say an octave above so the surface noise headroom of the preamp is compromised by 6dB ensuring that the noise will cause good wide-band preamps to clip on really loud passages. Furthermore, just like any generating system, without any load (expected in this frequency range) the cartridge output rises compounding the problem.
By rejecting common sense such as the IEC 6-1938 matching system standard (to which many European manufacturers comply), we again, through use of uneducated ears, run the risk of mob-enforcing tone controls where we say "there are no tone controls".
Yes, it's amazing where a little treble boost leads... Without proper understanding we in hi-fi often end up trying to milk the bull!
And often it results in the same...
Date Posted: 10 Oct 2010 at 6:00am
I am glad you have cleared that up for me
I knew there was a good reason to use MCs - I can work them out (mostly)  Seriously though, more good info - thank you. Perhaps a little harder for the average bodger to readily utilise. BTW, WRT the VMS20, does this go any way to explaining the difference you have noted elsewhere between the performance on the Rega vis a vis the Technics ? - thinking here of the possibility of differing tonearm cabling capacitance contributing.
Date Posted: 11 Oct 2010 at 12:56am
tg wrote:
...BTW, WRT the VMS20, does this go any way to explaining the difference you have noted elsewhere between the performance on the Rega vis a vis the Technics ? - thinking here of the possibility of differing tonearm cabling capacitance contributing. |
Possibly but...
However, the VMS20EII was bought to replace a high output moving coil of which I cannot remember the name (that was 1979 when the Planar 3 was bought). The VMS20EII wrought an improvement, taking away the bass lightness and forceful treble to a degree. In 1979 aged 24 and back living with parents I was unable to provide the Rega with the hefty shelf the Hi-Fi press were suggesting. It was not until around 12 years later I was able to furnish it with such a shelf. On that "long journey" the RP3/VMS20EII saw numerous phono inputs most of them self-builds (but not all) of one design or another. Eventually I bought the Roksan Tabriz arm, and the removal of the Acos Lustre meant inflicting fatal damage to it because it was never intended to be removable (this gave me the impression that the RP3 was a toy...), so I was never able to test it further. The Roksan arm wrought a further improvement. So by that time I had the RP3/Roksan Tabriz/VMS20EII/Hefty Shelf. I splashed out on some tiny JPW speakers after tiring of my Goodmans DIY bass reflex "monotones" in a bid to get greater three dimensionality. I'd purposely bought the most bassy sounding "book-shelfs" then available, but still tonally, the results were only just balanced. What I did achieve was getting Hendrix walking around the listening room as my pal (and now co-director) John C will vouch for.
A bit of a lengthy reply, but I'm getting to the point. It was then I stumbled upon the Audio Technica AT95E (moving magnet again) which proved to be the icing on the cake, and much better tonally balanced than the VMS20EII. Having since measured the Roksan arm lead capacitance, and also since, the Technics arm lead, I found them both in the 100pf region, so I assume the original Rega arm was in the same ball park. Most of my phono inputs were 100pf or 220pf, so the total capacitive load would have been on the light side for the VMS20EII anyway. And that tends to suggest I was not giving the VMS20EII the optimum loading conditions, and I'm still not. At roughly 300pf total cap load the VMS20EII fairs better than 200pf. On the Technics there is no hint of 8-10kHz peaking that the simulation suggests, which tends to bear out the argument that stylus tube tuning mirrors the electrical output. I shall have to find a couple of wide bodied phono plugs and make a 100pf load plug set and for the first time hear the results of 400pf loading.
I shall report back on this.
Date Posted: 11 Oct 2010 at 5:39am
These plugs would have the capacitor across the plug as for a load resistor ?
Perhaps a nice Panasonic 1206 film cap would fit nicely ?
Date Posted: 11 Oct 2010 at 11:12am
A web search suggests these are surface mount?
Date Posted: 11 Oct 2010 at 12:46pm
Yes, they are - 3mm x 1.6 or thereabouts - should fit in almost any plug.
Don't sneeze while they are loose on the bench though.  Chosen by a consensus of DIYers on SQ grounds as bypass caps for a TDA1545 DAC chip. Bit more pricey than ROTM caps but considered worth it. (in that application at least) I suppose any kind of film could be OK - it was the size issue I was considering.
Date Posted: 13 Oct 2010 at 12:05am
Well tg, good idea but I have to wear two sets of specs (spekky six eyes... ) as it is...
My choice for the load plug set (something I've been trying to put together now for the last 12 months) includes the Switchcraft phono plugs (picture on its way soon), and I'd thought my favourite PFR's wouldn't fit, but lo and behold, tried it today, and they fit a treat, and I only had to wear one set of "bottle-bottom" spectacles!
I fitted a 100pf and put it in parallel with the input to a Reflex M which now has 220pf loading, using a Tee adapter (per channel) and it made a difference. The total loading is now near the recommended 400pf for the old VMS20E II with arm cable capacitance factored in.
I'd previously been increasing the tracking weight to try and rid it of the slight bit of spit it had operating into roughly 300pf, but currently the additional 100pf has enabled me to set it to 1 gram (0.8-1.2g specified) - quite amazing, especially considering this is a bog standard Technics arm!
So here we have a case of increasing capacitance to rid a treble peak (instead of what you'd expect). The hunch paid off with this cartridge.
The clarity is staggering and the tonal balance quite fantastic. It's smooth too. Not bad at all for a cartridge of its age - and an MM at that!
Date Posted: 13 Oct 2010 at 12:54am
A double win then, your fave cap fitted in and the result was what you hoped for, or at least had a reasonable expectation of achieving.
I use a big illuminated magnifier to deal with a lot of circuit work these days myself. Interestingly, Terratec marketed a phono EQ for computer soundcard input a few years back that included 3 different capacitance settings and 3 gain levels. Cap levels were 100, 200 & 425pf - did not use it a lot, but IIRC, the 200 loading sounded rather better with an Ortofon OMB 10 that I used with it at that time. I think there has been some discussion on and experimentation with, various loadings, over at vinylengine for anyone who is interested in reading further.
Date Posted: 15 Oct 2010 at 7:07pm
If it sounds right, it probably is the right value. But I would also trust a reputable manufacturer to state the electrical loading and arm setup that best suit their cartridge.
As I wrote elsewhere in these forums I have my 2500 at the top end of Goldring's 150-200pF combined load and it does sound very good. But thanks to Graham I now think the type of capacitors is a key big factor in the sound.
Posted By: jupiterboy
Date Posted: 13 Oct 2011 at 8:11pm
Hi. First post. Found this thread while searching today. I don't have a Slee product, so please don't throw rocks. I'm also in way over my head, but have enjoyed experimenting with alternative loading for MM carts. I've had some difficulty getting solid specs on my cart, and made some initial errors based on incorrect data.
I'm now running a AT 150MLX happily at 54.7K loading and 117pF capacitance. I have RCA splitters with some Radio Shack resistors soldered in series to get that load, and wonder how much capacitance I've added with the splitters, and also wonder about a final implementation and a better quality resistor than what I now have (5% error).
Anyway, great thread. Thanks for letting me post. Cheers.
Posted By: jrhughes
Date Posted: 14 May 2012 at 12:34pm
The Ortofon 2M bronze has the following specs:
| Frequency response | 20-20.000 + 2 / - 0 dB |
| | Internal inductance | 630 mH | | Recommended load resistance | 47 kOhm | | Recommended load capacitance | 150-300 pF |
if the Reflex M has 220 pF input capacitance and my arm/cable (it's an OEM RB300) has about 100, the I'm on the outside or just over the recommended limit. I must say that it's an education reading all this, even though I don't understand it all, since there's so much more to matching components that I'd thought. Should I be doing something (?) to try to get the total capacitance a bit lower? It certainly doesn't sound spitty, nor dull. Would sounding dull be a sign that total capacitance was too high?
