Goldring 1042
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=81
Topic: Goldring 1042
Posted By: IvanM
Subject: Goldring 1042
Date Posted: 10 Mar 2008 at 10:01pm
I wonder if anyone else is using (or has used) a Goldring 1042 and if they are, I wonder if they have found it to be as fussy about VTA and bias as I have?  The bias isn’t a problem but the VTA is doing my crust in.  When I get it bang right the sparkle and presence are captivating but it seems that the difference between a thick record and a thin one is enough to take the shine off.  I don’t know if it’s the nature of the cart or just that I am being allowed to hear the difference that small adjustments make due to the extra info I get from the Reflex.  The fact that I have one of those tonearms that leaves for the centre of the earth immediately the grub screw on the centre pillar is released is not helping much iether.  I am happy that the alignment is correct so I’m beginning to wonder if I’m getting over fussy but the sweet spot seems remarkably small and the difference surprisingly noticeable.
I'd like to agree with you but then we'd both be wrong.
Date Posted: 11 Mar 2008 at 1:17am
Hi Ivan,
The 1042 is noted to have a slight hump in the 2kHz region where our hearing is quite sensitive. This may be in part due to its relatively steep high frequency roll-off that I feel is almost an attempt to be CD-like. A steep filter is always characterized by in-band ripple - hence the 2kHz hump IMO. CD is also considered to have a more restricted sound-stage.
A notable cartridge for really room defying sound-stage is the Cartridgeman Music Maker III, which I have heard on two different speaker systems in different locations, and by room defying I mean whole building defying too, as placement of different sounds have appeared to come from the street, people's back yards, etc. The MM3 can be a fussy cartridge (but not in the VTA department in my findings) but Len Gregory who makes them gives guidance on their successful usage. However, for this standard you'd be paying much bigger bucks than the 1042.
There are two affordable cartridges that once stood out for delivering a serious sound-stage: the Ortofon VMS20EII (now out of production), and the ridiculously cheap Audio Technica AT95E. John (John C) may fill you in on our Hendrix experience...
In the 1042's defence, if you forget about the sound-stage, I'm sure you'll agree it's a very musical cartridge, and very engaging particularly in identifying and separating performers, which may be an artefact of its slight midrange hump.
Posted By: Guests
Date Posted: 11 Mar 2008 at 9:33am
Interesting ! How do you set VTA when the arm tapers towards the cartridge, as it does on my Technoarm ( Rega 250 ). I have been running the ERA Gold V solo in for several weeks now, but not had a lot of listening (  work ! ). It seperates the instruments more, is very listenable, can hear more detail ( I think ), makes me want to put on more vinyl, but it appears to me that the vocals are set back in the mix more, not quite so forward. This is with the 1042.
Been thinking of asking Ian if he has any technical equipment to help set up my arm properly, he could do it for me when he drops off the power supply LOL
Adrian.
Date Posted: 11 Mar 2008 at 10:42am
Hi Adrian,
I am not sure if it will help you (even less sure it is correct) but it seems to work OK for me.
I use a tecnoarm though not a 1042, I have set the arm as low as is not inconvenient.
By this I mean that with a heavy (thick) record on the platter the stylus will barely (>1mm) clear the surface when raised with the arm lift mechanism.
I am not particularly obsessive about VTA (I also admit that the Denons I use are reputed to be not particularly sensitive in that respect)
I did have one interesting session with a DL103 (which should be the least sensitive due to its conical stylus) - listening to a Pavarotti recording and adjusting the VTA by significant amounts - I did discover the point at which his voice sounded the most natural and others not as much so - IIRC that coincided with the usual recommendation of "between level and a little tail down"
If it is possible to vary the height of the arm lift mechanism on the RB250 I have not discovered it although other arms I have owned allowed this.
One way of testing a few settings with minimal grief is using different thickness mats (if you have a few to try) and listening for the difference and then adjust the arm accordingly.
Posted By: IvanM
Date Posted: 11 Mar 2008 at 3:51pm
Hello Adrian
I don't think that you can set the VTA by looking at the arm unless you have both a parallel arm tube and a cartridge that is correctly aligned when the arm is parallel to the record.  In the case of the 1042 the instruction says to set the bottom surface of the cartridge itself, parallel to the surface of the record, when the recommended tracking weight is applied.  When the 1042 is aligned this way in my arm (which does have a parallel tube) it is noticeably higher at the pivot end than at the cartridge end.
There are apparantly special tools to set VTA using a mirror arrangement (I think - I have read descriptions but haven’t actually seen one) but I don’t have one.  So what I do is fold a small piece of white card into an inverted V and place this behind the cartridge on a record that is A. flat and B. doesn’t have a raised outer edge.  It is important that the edge of the card is parallel to the side of the cartridge body and that you view from 90 degrees off the cartridges other side.  This sounds more complicated than it actually is and does allow you to see, quite easily, if the bottom of the cartridge is parallel to the record.
Posted By: Guests
Date Posted: 12 Mar 2008 at 7:21pm
Thanks for your advice guys.
I'll try the white cardboard trick this weekend Clap but the bottom of the cartridge has 2 slightly different planesConfused and my eyesight is getting dodgyLOL
I have heard the rear end up theory before.
Adrian.
Posted By: IvanM
Date Posted: 20 Mar 2008 at 11:41am
I am intrigued by the Music Maker cartridge it seems to offer the quality of output usually associated with costly MC's but with the benefits of MM (according to reviews at any rate).  The thing is though that my original plan was to take a lower cost route back in to vinyl.  However, since reviving the LP12 with the Reflex I have played just 1 CD.  I have now decided that upgrading my vinyl replay system is a good way to spend my hard earned. The first thing to go will be the 23 y/o LP12.  It has served me well but is, with the best will in the world, not worth spending more money on, especially the latest stupidly priced Linn mods.  The Ekos arm will go next, then the cart.
My heart’s desire is a Michell Orbe/Origin Silver/Music Maker 3.  I have briefly heard the Orbe/Silver set up with an Ortofon MC and it sounded very, very good.  Haven't been able to hear much else yet though but I am going to try to and get to hear the new Clear Audio and Origin Live decks too.
It has taken me some time to come to this decision or more accurately, come to terms with this decision.  I had thought my romance with vinyl had pretty much come to an end or at least would be an on/off, low rent affair.  The Reflex is largely to thank/blame for my change of heart but this has been a positive influence and has actually rekindled my love of hi-fi gear and music (unlike some I will admit to taking pleasure from the kit as well as the music).  Another big influence on this decision happened a few weeks ago, when I had the opportunity to listen to Ivor Tiefenbrun espouse the wonders of Linn’s latest digital offering and listen to the actual kit in a system costing around 60 - 80k about 25% of which went on the digital source (NB best guess didn’t get exact prices).
As a long term Linn user and fan, you can imagine that I listened to both his words and the sound of the kit with eager anticipation.  The fact that neither his words nor the sound rang true was a genuinely bitter moment for me.  I was hoping to be astonished, I was but not in a positive way.  I won’t try to review the event or the sound but even allowing for a poor room, it was, to my reasonably practiced ear and practical mind a huge disappointment for a ridiculous amount of money.  The whole thing revolved around the fact that the new bit of kit sounded better than the old one.  The fact that was overlooked though, for me at least, was that at this price it should have been astoundingly good: it wasn’t’.  It wasn’t even the best Linn set up I had heard, not by some way.
When I got home that night I put on my old LP12 with new low cost Reflex phono stage and MM cartridge and was more delighted than ever.  Although it didn’t strike me at the time, I have come to conclusion that vinyl replay hasn’t’ survived because of die-hard fans or even because it is ultimately the best sound you can achieve: I think vinyl replay remains popular because it is in fact the best value for money route to a truly satisfying, hi-quality sound.
Date Posted: 20 Mar 2008 at 1:50pm
Ivan,
owning the Reflex is like that I think Wink - first came the Era Gold V (out on trial with a friend ATM) then the TT upgrades, then the Reflex - now you have started me on I/Cs Cry
- the VDH D 102 arrived yesterday - had my first serious play with them this evening - they are staying (at least until I try the First Ultimate)
I considered the OL Silver before buying the Tecnoarm which I considered to have better wiring and be otherwise at least equivalent if not better.
The Acoustic Signature tables, particularly the Final Tool, having been getting some good raps from users out here in the antipodes.
Paul Szabady who gave Grahams gear a really good review liked it a lot too.  http://www.stereotimes.com/turn041101.shtml
Me, I can probably avoid that particular temptation (for another 12 months or so anyway)
Posted By: IvanM
Date Posted: 20 Mar 2008 at 6:17pm
Hello tg
Glad the cables are OK, I'd be curious to know what difference they make over what you were using before.
Thanks for the steer on Acoustic Signature TT's, never heard of them to be honest.  I'll check them out though.  Final Tool is a bit of a worrying name though, can't decide if it makes me think of a murder weapon or an insult!Smile
I also hear what you are saying about the Tecnoarm and it makes sense that it should work on a Michell deck.  I'll try to get some sort of comparitive listen but it isn't easy these days.  It's well reviewed and seems like good value for money too.
Thanks for the info.
Posted By: Guests
Date Posted: 20 Mar 2008 at 7:02pm
Ivan, I have read your recent postings with interest.
For too many years I lusted after a LP12, but couldn't justify the expense ( and was slightly put off by the hype ! ), so I went through various other permutations of Michell Synchro, various Thorens, Rega Planar ( even a secondhand Roksan Xerxes which succumbed to the droop! )etc.
Last year I finally bought LP12 and spent £200.00 on new motor, belt, springs, grommets, oil and professional set up, only to be disappointedCry. One of the biggest problems was the slightest knock on the rigid equipment rack, sent the arm across the record. Not good with a dog in the house! It was fitted with 1042. And worse, apart from the bass, it didn't sound a great deal better than the Planar 3Confused
At the back end of the year, I was perusing evilbay when I noticed someone fairly local selling a mint Michell Gyrodec with Tecnoarm. I was able to see it and listen to it, so bought it! It has a 1042. I contacted Michell, who were very helpful, and I bought the updated springs, belt, oil and QC power supply. It is now set up to the best of my ability and I think is brill ! It is also so much more resistant to knocks than the LP12.
When funds permit I may take the Orbe upgrade ( don't tell the boss ), but I have also invested in the ERA Gold V. I have bought a shelving unit from Ikea and rescued my vinyl collection from the back of the spare bedroom. They are now in the lounge.
Life is bliss, but I'm sure the TT could be improved by being set up even better !
Sheffield isn't too far from me,  I'm at the end of the M62, near North Cave, why not pop across and have a listen ( bring some ICs with you too Wink
Adrian.
PS I also play with airguns, professionally of course !
Posted By: IvanM
Date Posted: 21 Mar 2008 at 12:36am
Adrian
Pest contol and airguns, yep that's gonna work.
Just about to leave on a weeks break so no time to reply properly now.  I'll pick up when I get back.
IvanM
Posted By: IvanM
Date Posted: 29 Mar 2008 at 12:49pm
Adrian
Thanks for the offer of a listen, I may take you up on that.
I have to say I love the look of the Gyro, it's a work of art, the SE looks especially dramatic.
Since I no longer use a wall shelf, I also suffer a bit of wobble when anyone walks heavily by the stand and though the arm doesn't skate, it does make a horrible noise. If the Gyro is more stable it may stop me having to put a shelf up which I was considering.
Does your Gyro have the NC power supply?
What arm do you use?
Posted By: Guests
Date Posted: 29 Mar 2008 at 2:50pm
Hello Ivan,
Hope it was a good trip !
I have a Michell Gyrodec with an early Tecnoarm ( without the holes ) and yes it has the QC power supply. Cartridge is of course the Goldring 1042. Phono stage is the ERA Gold V, which will soon have the upgraded PSU.
I am bi-amped with ( original ) Audiolab 8000S and 8000P, into Quad L22s ( latest model ).
Sounds OK to me, but I could do to play with some leads and better extension sockets.
You are welcome to pop across, it ain't that far ! The wife make agood cup of cappucino!
Adrian.
PS I have solid floors and the Linn LP 12 was on a Soundstyle stand and was still affected by bounce !!
Posted By: Darren/Audio Elevati
Date Posted: 30 Mar 2008 at 8:54am
Hi guys,
If I can throw a friendly spanner in, we have the Acoustic Signature brand here and I think there are no more than 7 dealers in the UK so we're pretty lucky.  Currently set up is the Manfred turntable with the fully upgraded RB250 arm from Origin Live and fitted with Shelter 201 cart.  Using a Herbies mat at present, though have the Thorens (cork/rubber) mat as an alternative.  Tricky that comment about swapping mats to suss out the VTA as they affect the sound itself - one answer would be using the Thorens mat as there are 2 mats, each of the same thickness that sit one on top of the other.   (We are dealers for Thorens too - try finding another dealer anywhere nearby!).
Anyway, all that is finding it's way to the Era Gold V with PSU1 (ABPest - what are you waiting for!) then Cusat 50 ICs to whatever amp we fancy.  At the moment, it's the Shanling MC3000 (have a look, lifestyle fans) and into the Usher S520s via Black Rhodium Salsa biwire.
No springs on the Acoustic Signature - no jumps either!  Sitting pretty on a Target wall bracket, dead level.
Guys - come and have a coffee and a listen - appointments only please.  If you want to hear things sounding really good, I'll get the Luxman amp and Gershman speakers on the go.  You've never heard bass like it!
Here are a few links in case you want to have a look at some of these things....
http://www.realhi-fi.com/images/mc3000l.gif - http://www.realhi-fi.com/images/mc3000l.gif  - Shanling mc3000.
http://www.audioelevation.co.uk/CartV3/Details.asp?ProductID=50 - http://www.audioelevation.co.uk/CartV3/Details.asp?ProductID=50   Acoustic Signature Manfred
2 final things...
check out Acoustic Solid turntables too - we can get them!
http://www.hiaudio.co.uk/AS_prod.htm - http://www.hiaudio.co.uk/AS_prod.htm   Acoustic Solid
and
All this about VTA - have you tried slightly toe-ing the cartridge in?!  The AT95E doesn't seem that fussy but the Shelter is a case where you set up the cartridge alignment so it's spot on and it sounds fine.  Then (as tweakers we all love this sort of thing!) try to toe it in/out slightly and listen again.  Get it right and it sounds even better!  A case of letting your ears decide but it's something I've found helpful in certain cases.  Would be interested to know if anyone else has thoughts on this.
All the best guys.
http://www.audioelevation.co.uk - Audio Elevation - taking your hi-fi to another level.
Posted By: Guests
Date Posted: 30 Mar 2008 at 12:23pm
Typical of a "dealer" to jump in and flog his wares Wink
Ian, when Ivan pops across, I'll get him to pick you up on the way. You can bring the PSU to try out and some Cusat cablesLOL
Seriously, I can't try the different mat method with the  Michell, 'cause it don't use matsSmile it relies on the LP "mating" ( should that be bonding? ) with the platterStar
I do enjoy this site, but 60% of it goes way above my headLOL. One thing I have learned in life though - never, ever, believe in advertisingConfused
I read in a Hi Fi mag recently that they never use equipment to test new products, just listening tests. Question - how do they know how my ears work?
Date Posted: 30 Mar 2008 at 5:46pm
yes, apologies for the sales pitch - try to ignore it - we're hard up northerners!  Come and have a look at the Ac Sig anyway.  Bring one of your wife's cappuccinos!  Ian can arrange to lend you the PSU1 and cusat50 anytime. No problem. You can then post a review of each on this support community for the benefit of others.
Posted By: Guests
Date Posted: 31 Mar 2008 at 9:42am
No apology necessary, BUT do you sell airguns as well?Wink
Posted By: stuxter
Date Posted: 04 Apr 2008 at 11:12am
Hi AB pest
but are you that Saxondale fella on the tv ???
Posted By: Guests
Date Posted: 04 Apr 2008 at 1:02pm
It's close.........................................very close LOL
The only difference is my second car, you know, the one for fun !...........................
.........................it's a mini Embarrassed ( A real mini ! ).
Adrian.
Posted By: IvanM
Date Posted: 04 Apr 2008 at 5:10pm
Wow things are getting weird around here Smile
Thanks for the input Adrian + Darren. After a tough week at work I have just put my hand up for a Michell Orbe SE.  This decision has been made after no listening at all but I am strangely relaxed about my decision.  This will take up most of the money that I had put to one side for hard liquor, soft drugs, loose women and ladyboys so it had better be good!  I should have it next week but don’t know when I’ll get it set up as I am travelling quite a bit.  It is going to receive the Ekos arm off the LP12, which according to a helpful chap at Michell, should at least be tried before spending money on a new arm: good!  I’ll set it up with the Goldring 1042 but will then take up John C’s kind offer of a loan of an Elevator and see how it sounds with the Troika.   Then I will take some time out to enjoy the music and perhaps think of a good way of explaining this to my wife.
As an odd twist I actually do have an air rifle to sell, check my myspace site http://ivanm44.spaces.live.com/ - http://ivanm44.spaces.live.com/
Posted By: Guests
Date Posted: 04 Apr 2008 at 6:10pm
Hello Ivan, I think you have made a good choice, only wish I could afford the OrbeSmile
The Ekos should work well . I saw on evilbay some one selling a GyroDec with SME arm. They stated any GyroDec with Rega arm is an ornament !!! Lot of ornaments out there!LOL
I'm much happier with the GyroDec than I was with the LP12, and Michell are great to deal with. Nice personal touch.
So you have to sell your Theoben "TOY"Big%20smile, well it is .177 Wink
I am in the market for a .177, so how much is it? I can p/x a very nice Musical Fidelity integrated amp ( with phono input Tongue).
How much and what comes with it? And is it to appease the wife ?
Adrian.
Date Posted: 04 Apr 2008 at 6:13pm
I really should stop reading your posts Ivan - it is too expensive Wink
I think I am having a jealousy - not so much for the Orbe (though that is very tasty) - but for living close enough to "the source" to borrow an Exp for a trial.
I am sure I need one Tongue but have just blown my budget out of the water with damn cables.
thanks chum Ouch
I do hope you enjoy it all the same Thumbs%20Up
Posted By: IvanM
Date Posted: 05 Apr 2008 at 11:04am
Adrian + tg
Thanks for the positive words guys.  I am quite excited about the new deck.
tg - wowShocked, just checked your location on your profile, I see now why "popping round" for a test model, isn't really on for you.
Adrian - I have replied to you directly re the gun as I think it would be innaproriate to go that far off topic on this BB.
IvanM
Posted By: Guests
Date Posted: 05 Apr 2008 at 12:48pm
Reply sent Ivan,
Re: inappropriate, I'm sure Graham finds pest control an interesting divergence from phono stagesLOL
How are the bags of water suspended from the ceiling by the way, Graham?
Adrian.
Date Posted: 06 Apr 2008 at 5:39am
Originally posted by ABPest ABPest wrote:
Reply sent Ivan,
Adrian.
One of them burst.
Unfortunately a good friend was standing under it...
Posted By: IvanM
Date Posted: 09 Apr 2008 at 11:21pm
Got the Orbe.  Built and set up from scratch in 4 hours - way easier than LP 12.  It's as black as the devils do da and sounds very good.  First impressions (all in comparison to LP12) very detailed, crisp sounding, bigger picture, deeper soundstage, metronome timing, less bass but goes deeper and has intense drive.  I wasn't sure just how much difference the bit that spins the record would make: it makes a lot of difference.  I am in my happy place now Smile.
Posted By: Guests
Date Posted: 10 Apr 2008 at 8:54am
First time on the site for a couple of days!
And I'm damn jealous. First post I read is Ivan's new OrbeTongue keep us updated about the new things you can hear on your LPs Ivan, and how do you find the suspension, is it better than the LInn ? and are you using 1042?LOL
On Tuesday I was working by the side of a road when I suspect a passing vehicle threw up a foriegn object, it hit me in my right eyeOuchOuchOuch. Has caused a lot of damage, been to hospital every day since. Can't drive myself, relying on liftsSmileso been listening to a lot of music, CD though ( sorry Ian the trial of PSU is not progressing well ! ) can't see to cue the needle up very well. The left eye is watering in sympathy.
Down side is in being self employed, no sick payOuch Working for the council had 1 advantage!!!
Adrian.
Date Posted: 10 Apr 2008 at 1:30pm
Get well soon.
No worries about the PSU1.  Just means I can't hear my new 180g Eagles - Hell Freezes Over lp.  Don't feel bad or anything...Cry
Had to get the lp from the US.  Strange thing is, it was cheaper than it would be from UK source but when it arrived, you immediately noticed the "Made In England" sticker.  I kid you not.
Posted By: IvanM
Date Posted: 10 Apr 2008 at 1:38pm
Adrian
The eye injury sounds like a serious do, I hope you have a qiuck recovery and that there's no permanent damage.
I'll report more on the sound when I have got over the initial excitement.
Regarding the suspension it is an absolute dodle to get right. For a start you don't need to get under the deck but in fairness to the LP12 there is no plinth or furnishing element as such; it is just pure engineering - which I like.  The whole plot is much more stable too as you said about the Gyro.  I can boldly stride past the deck without troubling the cartridge, even though it does visibly move a bit, it's so bang on that everything moves together.  Again, in fairness to the LP12, on a full moon with the wind in the right direction, it will also do this but it takes for ever to get right and 'goes off' for no apparent reason.
Hope you are feeling better.
IvanM
Posted By: IvanM
Date Posted: 18 Apr 2008 at 4:39pm
I have had a few weeks with the Orbe now and I have to say it is delighting me, no post purchase depression at all (despite still not having the heart to put the LP12 on ebay as that feels like betraying an old friend).
After a couple of changes (which I’ll mention shortly) I now have the most realistic sounding vinyl replay I have ever had, sometimes it’s eerily ‘present’.  I won’t go on with the usual rose tinted views of how wonderful everything is but there are a couple of things that are worth a mention e.g. The Orbe is much quieter surface noise and scratch wise than the LP12, despite using the same arm and cartridge.  I can play music at lower levels and still get a full sonic/acoustic ‘picture’.  It presents very different soundstages from record to record and even track to track.  It doesn’t’ ‘paint’ everything with its own colour and isn’t as forgiving of poor recordings as the LP12.  This can be a shock at first, almost every record/track that I play on the Orbe comes with added detail, drama and scale but occasionally it seems to say: “I’m sorry that’s just plain bad, nothing I can do and here’s why” and makes a point of showing the shortcomings.  The worst example of this is what I can only describe as reduced bandwidth recordings.  The best analogy for this is that it’s the audio equivalent of watching a 19” picture on a 50” screen; you can almost hear the unused frequency/dynamic space around the music.  I suspect the high bandwidth of Reflex has a hand in this, the fact that it’s doing a brilliant job of letting me hear the benefits of the new deck also means it’s going to let me hear what’s missing.  Again this tends to be the odd track rather than whole records but a couple of 70’s live albums have been found wanting.  This is a shame, because until most of them stop being dead, there’s little chance of a Ramones come back tour or a new live album.  It’s still a small price to pay though for a very big overall improvement.  In contrast, this is the first time I have played classical albums and really felt as though I have “got it”, presentation wise.  An odd point is that the G1042’s sensitivity to VTA (which started this thread) seems much reduced, though small changes in down force and bias can be very easily heard.
The two changes I have made have both been on the advice of the helpful people at Michell.  The first was to replace my MDF shelf with a 1” thick piece of slate.  Initially this made everyone sound like Kate Bush but then I noticed it was actually touching one of the uprights on the rack (I’d had it cut a tad bigger to give me more room - clumsy).  After repositioning it the slate brought noticeable gains in bass pace and generally sharpened things up.  The second change was new decoupled fixings for the arm board which came from Michell, at their recommendation, for £19.  I didn’t like the look of these as to me it looked like they would soften things up, perhaps at the cost of some detail:  wrong.  Noticeable gains in detail and soundstage depth.   Also and I don’t like to use indefinable terms but hey ho – this mod added what I can best describe as a good dose of ‘boogie factor’.  Whatever that is, the LP12 when ‘right’, was good at it and although I hadn’t missed it; I had noted that the ultra-stable sound of the Orbe, was sometimes a little robotic.  Despite not being able to say what this is, it it something I definitely hear and like and in the past, have gained and lost by degrees, when setting up the LP12.  Psychoacoustics? “Psychobollox - more like”, I hear you say!  I’m not sure either but I noticed it straight away; it was as if the musicians had just nodded at each other, grinned and gone: “good one”.  Well worth £19, choose what……….
Posted By: Dave Millier
Date Posted: 18 Apr 2008 at 10:17pm
A fascinating description; glad you're happy with your upgrade. I'm sad to report that these sorts of subtle improvements seem to elude me.  I recently replaced my PT Little Pink Think with a Pink Triangle PT Too. The improvement is there:  a lighter, quicker bass with less bloat and overhang but to be honest I would only really be able to describe the difference as "just discernable with concentrated effort". I do think it's great that someone is enjoying the music anew, though.  In the end, that's what it's about.
ps
I used to own a Ramones LP in fetching yellow vinyl...
Date Posted: 19 Apr 2008 at 12:25pm
Ivan,
you do realise of course that it is exactly this sort of nebulous flim-flam extolling the praises of your latest acquisition that will inflame the passions of the terminally gullible (such as myself) and lead to a case of "I have to have this thing NOWWink
Well, perhaps. Tongue
On a more Sirius note, sounds good, glad it is working for you, interesting your observation on the arm damping fixings, I have read elsewhere of similar mods for the Gyro from a Danish engineer that reportedly have similar effects.
One wonders if the apparent reduction in surface noise might be attributable to the acrylic platter - this is pure speculation on my part.
Interesting also your observations WRT classical pieces and to the variations between recordings becoming more apparent.
As I have upgraded my system I seem to find that each significant improvement in resolution and reproduction results in the discovery of yet more less than perfect recordings (whether big black disc or small silver one).
Yes, it has also become very easy to tell the compilation albums from the recorded all at one time ones.
Dave,
over 18 months ago I had two turntables, one a Sansui SR-525 (reasonable quality direct drive) and a fairly normal P2 - the differences between them were as you describe - not marked. I decided to embark on a program of upgrades to the P2, of all those, only a couple made obvious improvements, immediately and undeniably better, most of the rest were of the barely discernible variety.
The first was a change of arm and cartridge, the second was a combination of 3 different things, a different phase splitter tube in my preamp, replacement of the main volume control with a stepped attenuator and yet another cartridge upgrade.
I recently revisited the Sansui and placed it in the system for a day and spent quite a time optimising it for best performance using B's 7th symphony, a good tuning piece with plenty of crescendos, lots of dynamic range and a variety of instumental timbres for reference.
I listened to the entire piece when I was happy with the setup and then replaced the hotrod P2 in the system and replayed the piece.
It was immediately apparent that none of the upgrades had been wasted, the cumulative effect was significant, and note that the Sansui had the benefit of the improved preamp also.
Interesting, to me at least, was that that preamp upgrade also allowed me to distinguish differences between CD players that I had not been able to definitively separate before, I think that in this the stepped attenuator was the major contributor.
In fact, first up after fitting it and spinning a favourite CD, it sounded like a major CDP upgrade.
Has it been worthwhile? - for me yes, I have had a lot of fun and surprised myself with what I can hear the difference in and increased my pleasure in listening.
Not having great expectations to start with, unsure of my own listening abilities and ability to reliably discriminate, unsure if I would make any improvement at all that I would notice, aware only of what I did not like and that I was sensitive to distortions of certain types.
With some understanding of mechanical engineering I have been able to correlate what I hear with what one theoretically should be able to observe from various tweaks and hence to formulate and test theories as to where the next improvement might be found or where might be the cause of any observed problem.
The stepped attenuator was rather serendipitous, in that I would not have troubled had not the original volco been being naughty, but its immediate contribution was undeniable, it seemed to lift the entire system to another level and independent confirmation came from a visiting friend with many years of audio phoolery who immediately asked what I had changed and then sat enraptured as we spun some big black things.
disclaimer - I have never owned a Goldring 1042, a Ramones LP or anything yellow other than a flotation vest and a spray jacket. LOL
Posted By: IvanM
Date Posted: 19 Apr 2008 at 1:36pm
Hello Dave
Ramones - yellow vinyl - glory days mate!
To be honest subtle upgrades elude me, I try to take the view that if it’s not obvious I am probably kidding myself on.  Another test is if my wife can hear the difference.
The thing that strikes me about your post is that I have listened to bog standard PT’s and I thought the sound was very good.  Admittedly its a few years ago but the first thing I would want to establish is what the real problem is before doing any more tweaking.  IE Is the system already sounding so good that tweaks just make it different rather than better?  Or is the deck not performing to the very best of its abilities (are you sure everything is tight/level/aligned/earthed correctly)? Or If it is working well, is something downstream stopping the sound getting to your ears e.g. wrong support, interference, bad room acoustic, other kit?
I have never had a PT and I don’t know if they ‘go off’ but the LP12 definitely did and I'd get that ‘just not happy with it’ feeling.  I found that sometimes the only cure was a complete strip down and rebuild, a tedious way to spend a day - but always a rewarding one.  Once I found that one of the suspension legs was slightly bent, god only knows how it had got bent or how long it had been bent but it worked better with a straight one.
Hope you soon get things sorted.
IvanM
Posted By: IvanM
Date Posted: 19 Apr 2008 at 3:48pm
Hello tg
No yellow Ramones albums eh?  Mmmm.... perhaps now is the time to get one! Tongue  Not a lot of call for flotation vests of any colour here and the only use I'd have for a spray jacket would be keeping the bloody rain off me.Unhappy
Re the reduction in surface noise, like you I think the mass of the platter and also probably being clamped is something to do with this.  How does it know what's rubish and what's music though?  I also think the more rigid arm board helps the arm hold the cartridge more rigidly, allowing the cartridge to track better (and it does acording the HFN test record).  Some of the reduction may also be relative as in the wider bandwidth/greater dynamic it becomes a much less obtrusive feature.  I have just read this before hitting Post and it's tripe: really I haven't got a bloody clue why!  Posting anyway as I don't want to waste the typing.Smile
Posted By: Guests
Date Posted: 20 Apr 2008 at 4:53pm
Interesting comments Ivan, I am pleased you like the Orbe.
Your comments more or less mirror mine, albeit my comparison was with a Linn LP 12 with Basic plus arm, but it had been set up by a pro! and the GyroDec.
Your comment on surface noise certainly agrees with my listening but is one of those indefinable thingsConfusedwth regard to bass, it is not overstated, but I find it easier to distinguish different instruments and different notes. Musical it is.
I shall certainly try out the mod you have described, I had seen them advrtised on the Bay as aftermarket mods, which I tend to avoid, but Michel must be happy with them!
My hi-fi stand is glass shelved and Michelladvised against standing the GyroDec on glass, advising slate/marble/MDF I have chosen a lovely contoured 1" thick piece of MDF as my brother in law has a woodworking factory LOL I have however, aquired some marble which I shall have cut to shape!
Michell are most helpful, especially when you can talk to them by phone !
My eye is now almost back to normal, thanks to all for the good wishes. Work is returning to normalLOL
Adrian.
I have a Ramones double album, but it's black and LIVE!
Date Posted: 21 Apr 2008 at 10:32pm
My hi-fi stand is glass shelved and Michell advised against standing the GyroDec on glass, advising slate/marble/MDF I have chosen a lovely contoured 1" thick piece of MDF as my brother in law has a woodworking factory LOL I have however, aquired some marble which I shall have cut to shape!
I have a Gyrodec SE/OL1 Modded on a glass shelf never thought to ask Michell... what did they say?
Armboard mod -  talked to Michell at a show in Manchester last year and they told me it was well worth it. Got it myself now one thing to watch out for though is that there are two versions for the Rb250 arms depending on whether you have a VTA adjuster or not.
I have just bought a Ortofon 2m Black after spending many a happy year with a Reson Reca which is a 1042 in another guise.
Posted By: Guests
Date Posted: 21 Apr 2008 at 10:49pm
Michell, do not advise standing the GyroDec on glass shelves Confused
Recommend slate, marble or MDF.....................
.....................you'll have to go for it now ServerB.
Let us know how you get on.
Adrian.
Date Posted: 23 Apr 2008 at 5:43pm
Will have to look around about testing this on the cheap, hate to splashout and then get rejected by 'she who should be obeyed' for aesthetic reasons Unhappy
Posted By: IvanM
Date Posted: 09 May 2008 at 4:06pm
Getting back to the original topic of this post, I have come to the conclusion that the G1042 is a pretty good cartridge.  It is, as I originally noted, quite fussy set up wise but the little bit of extra effort does deliver ample reward (I’ll not contradict myself again by saying that VTA is critical but it is; oops - I have contradicted myself again: damn!).
Anyways, since I have had my Orbe I have noticed continued incremental gains in detail and texture which have raised my opinion of the cart.   A couple of nights ago though, I played Neil Young’s MTV Unplugged album which I hadn’t played for a year or two and it knocked my socks off.  There was a lot of new stuff that I just hadn’t heard before.  Of course the Orbe, the Reflex and the aging MK1 Ekos, also play their part in this but if the cart doesn’t collect the information in the first place it cannot be preserved or presented to the next stage.  So I reckon it’s a good bit of kit for the money.  I am therefore going to experiment with arms before looking at the cartridge.  I am also curious about the Cartridge Man Isolator.  This is mainly because I have come across nothing but good reports about it when googling for reviews on the MM3 cartridge (which I have pretty much pencilled in for future use).  I think I’d be reluctant to stick one to an exotic/expensive cartridge because of the risk of damage if it needs to be removed.  Also, it seems at odds with my understanding of the relationship between cart and arm but I might give it a go on the G1042.  If anyone has tried the Isolator, I’d be interested to hear their comments.
Date Posted: 10 May 2008 at 9:00pm
If you can make it work, get hold of the Kitchen Worktop Savers from Morrisons or other supermarkets.  £10 each (you'd prob need 2 under a turntable which is a bit of a shame but I've not seen them doing bigger versions).  Gives you the opportunity to try out the Mitchell theory for not much money.  We use them under speakers on some occasions (the missus will like them under speakers but look at you with a quizzical look anyway - you know the look I'm talking about).
I'm off to start a new thread now on the way our better halves (mis)treat us regarding our music/hi fi.
