Modded SL1200's
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=588
Topic: Modded SL1200's
Posted By: Andy9672
Subject: Modded SL1200's
Date Posted: 11 Aug 2009 at 8:52pm
I was wondering who uses a SL1200 standard and who uses a modified version.
Oh and if so what mod's and what differences did they make?
I have a SL1200 MK2 and have so far put a Goldring 1042 on and upgraded the phono cable to a double screened cable with decent plugs.
The deck i found locally had no cartridge and had a very destroyed cable so i cant say how these changes have helped/hindered.
Anyway lets hear from everyone else with a Technics wonder.....
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Posted By: less
Date Posted: 11 Aug 2009 at 9:30pm
Hi Andy(?)
I have a Mk5G deck which I will have modified to play 78s. This will include having an outboard psu fitted at the same time.  The power supply can be used without the speed upgrade.
I intend to use SoundAudio in Dartmouth, Devon though a lot of people have used Kabusa in the states.
Lots of people have changed the arm on the Mk2 some going as far as putting a SME V on the deck together with ££££££ cartridges.  I guess the options depend on your listening preferences and the depth of your wallet!
However many people find the standard arm with a reasonable decent cartridge gives good levels of reproduction.
Sorry if some of this sounds a bit vague  but I'm sure other forum members will add their twopenny worth.
Posted By: Andy9672
Date Posted: 11 Aug 2009 at 9:48pm
Les,
Vague is good, and i do hope other members will add anything they want!
More interested in tweeks that others have done and there views on there own tweeks.
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Date Posted: 12 Aug 2009 at 5:58am
I use a standard SL1200 MkII.
I use standard "other manufacturers" products to replicate the results most non-technical users would get.
The only fault I can find is its magnetic field, which could be its transformer, and that only manifests itself when using poorly shielded cartridges - otherwise no hum.
It means I cannot use the Music Maker Classic moving iron cartridge on it, which could indicate that some Grados could pick up hum too.
My favourite budget cartridge, the Audio Technica AT95E (which sadly we can no longer offer due to Audio Technica UK reducing our margin - unbelievable Angry) is dead-quiet.
Also their moving coil OC9 is quiet on my standard SL1200 II.
And that's the last time AT get any recommendations from me.
Date Posted: 12 Aug 2009 at 7:30am
Hi Andy,
I have fooled around a fair bit with one of these, no idea what headshell you are using, but you might find the AT-MG10 headshell to help the Goldring some.
Mats are another area many tinker with and alternative feet often get a mention.
Many have also fitted this deck with a Rega arm, either the RB250 or RB300, some seem to have thought it an improvement, others not so.  Depending on the cartridge being used the Rega arm may transmit too much energy into the alloy plinth and be better for being decoupled, probably not such an issue with your Goldring but it was with some of the cartridges I hung on one.  Using an RB250 on a Technics removes all the advantages of the stock arm, easy VTA, simple VTF setting, interchangeable headshells.
Many believe power supply modification/upgrade to be very worthwhile, I have yet to try that.
Of the readily available arms for the Technics, only the Jelco 750 offers most of the advantages of the stock arm (VTA is adjustable - just somewhat fiddly) - but - fitting one of these will set you back the cost of the deck or more - perhaps to no great gain unless you wish to run some particularly difficult cartridge (read low compliance).
I liked the combination of an SRM tech 2mm silicone mat on the platter (trimmed to fit inside the lip) with a 3mm Funk Achromat on top and a Michell clamp.
Others like heavy rubber, felt or cork, the Herbies "way excellent mat" has had good reports and some have preferred the SDS or Origin Live mats, or you could try the tnt-audio Janus mat.
Foculpods can be fitted in place of the stock feet although I was not impressed with the results of that - YMMV
Others have tried screw in speaker spikes in place of the feet and isonoes are another  (though rather pricey) option.
One rather interesting (to me at any rate) modification to an SL1200, involved fitting a trans-fi terminator air-bearing linear tracking tonearm and an AT OC9 cartridge (I believe the owner had also done the power supply mods) - he reported great satisfaction with the results - still, he could have bought another 3 SL1200s for the cost of the upgrades.
Have fun.
Posted By: Andy9672
Date Posted: 13 Aug 2009 at 9:41am
Well i have fitted a Sorbothane mat so far and am very impressed with the reuslts, the only problem is the residue on the record, so another thin top mat is required.
After that i may look at the arm but i like the Technics arm as you can easily adjust everything without much fiddle.
I may try s different headshell as i am using the standard technics one at the moment and was wondering about having a cheep cartridge for junk shop treasure and a proper cartridge for my clean vinyl.
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Date Posted: 13 Aug 2009 at 10:31am
Some of my best music is on Junk shop vinyl.
I play it with my best cartridges.
The stylus is made of one of the hardest substance on earth: diamond.
The vinyl is one of the softer substances found on earth.
My geatest worry is for the vinyl - and the great music it contains.
I have hundreds of Long Players.
I have only two 180 grammers.
Music? or Technophobia?
Use tools as tools, not as "orbes" and "sceptres" - or should we blokes dress as Cardinals, bow and worship to the hi-fi altar, and wave incense....???
Or should we just stick the needle on the record and jive?
Yes! Let's jive - Alleluia !!!!!!!!!!!!!!!!!!!!!
mind you it says that in the bible but man wanted the church just like his other toys... [Rev 21:22]
Date Posted: 13 Aug 2009 at 2:27pm
Quote Use tools as tools,
Having spent most of my life making things and working many different materials, there have been few but the simplest of tools that were not the better for careful setup, tuning and adjustment.
Even the simplest, such as hammers and axes, are not made equal, the best will be recognised by those accustomed to their use and appreciated for the subtle qualities that make them more apt to their task than the lookalikes.
A skilled and experienced craftsman will take the time to learn the subtleties of his tools and how best to tune them to his purpose.  The work will teach you how it must be done.
To everything there is a season, a time to sow and a time to reap.
If I should desire a better crop of music, should I not take extra time to well prepare the ground for it to grow in ?
Date Posted: 13 Aug 2009 at 5:03pm
I have no problem with that.
I just feel there is too much unnecessary pain in the pursuit of listening pleasure.
Posted By: Andy9672
Date Posted: 13 Aug 2009 at 6:15pm
Diamond may be harder than vinyl but it is the stylus that will require replacement over time. And yes i do understand the reasons behind this!
Although having tried the sorbothane mat i feel that my goldring 1006 will stay a while longer, the reason for the possible upgrade to a 1042 was for the musical difference of the stylus.
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Date Posted: 13 Aug 2009 at 10:33pm
Hi Andy,
My point is that to really enjoy the music a vinyl front end should be capable of playing old records because in this sad old world they're not exactly churning out new vinyl records, and if they are, I'm not into American Idol stuff.
Therefore most people's records will be old records, and in a very similar condition to the junk shop's better condition offerings.
Tot up the value of such a collection. 100 LPs at £3 (which is what I used to pay in the 70s) is £300, but by inflation they would now be £2,400.
A magnetic cartridge then was £5 - £20 (before money-fi) so expect to pay £40 - £160 today (Goldring 1000 series territory).
The stylus wears out I do accept, but after playing up to 5000 sides of average LPs (about 2000 hours) and the stylus is almost the price of a new cartridge.
But £160 is a better sacrifice than £2,400 so the records are more valuable.
This is the "ballpark" I "hang out" in - it's what I call "real"
So why do I do phono stage preamps that can cost up to £530 (plus Tax)? It is because I believe that a moderately priced cartridge (£40 - £160) can be made to extract nearly the same or even the same depth of performance as the really expensive gear does and that has always been my belief.
But £530 is a lot of money? Yes, but in proportion it's very little when you consider that at 5 times the cost of the average replacement stylus it lasts a lot longer than those replacment styli. The value of the records are still the largest investment.
And then again you can get near to that performance with a £120 Gram Amp 2.
I would class some into hi-fi like the kids the FBI released from the Davidian Sect - very brainwashed, and very distressed at the mere thought of using a Technics SL1200 series turntable. But I've tried a few turntables in my time and I can get the same experience as the best I owned from a bog standard SL1200 Mk II, without all the mucking about and fitting a new motor every three months (as I had to), or faffing about adjusting an arm that won't stay in adjustment (won't mention which).
What I want is to pick a favourite record out of its sleeve, stick it on the player and play it, so that I enjoy it fully.
I maintain what I've said for years - provided the cartridge was designed right (the £40 - £160 variety) and the turntable does its job of turning properly, then it's all in the electronics.
And that's why I do this job, and to this day it's about 10 years since the first GS commercial phono stage, and I'm still doing this job because I guess it fulfills what's required, so I get my wages.
That's my take on things for what it's worth.
Posted By: Andy9672
Date Posted: 14 Aug 2009 at 10:30am
Graham,
you have a very good point, i had never thought that it would be the periferal electronics that could be the issue, i had been partly brainwashed into believing that the 1200 is not a hi-fi turntable!
I may have to try tinkering with the phono stage when funds allow.
Well another weekend of vinyl and cd is upon us, thank goodness for rain, i dont feel so guilty not being out in the garden!
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Posted By: Chivas
Date Posted: 28 Sep 2009 at 5:20pm
[I maintain what I've said for years - provided the cartridge was designed right (the £40 - £160 variety) and the turntable does its job of turning properly, then it's all in the electronics.
Guided by the Sound HiFi upgrade options and trying to keep within reason, I added the cost of upgrading my std Techie 1210, everything std incl tonearm, cabling, feet, mat etc. and DL-110 (HOMC 1.6mv, about £120) and GASE2. I already have the Timestep PSU for the 1210 (got it with the 1210 when bought from a member on another forum). To summarise, upgrade would cost circa £1800.
AT-OC9ML/11    £400
Jelco SA 750D   £450
New Arm plate £80
Tonearm cable £80
Relfex C £615
Audiophile Mat £90!!!!
Record weight £95!!!!!!
Cheap sorbothane feet £20
Consideriing that I paid about £650 for my current setup (incl cart, Timestep PSU and GASE2) I will have to spend about 3 times the amount to "upgrade"....? Something doesn't add up? Especially considering that I am quite happy with the sound I'm getting.
I would stick my neck out and say that keeping everything as is, including the "rubbish DJ feet and mat" and spending the 33% on the Reflex M2, will probably give me a much bigger improvement than the other 67% in tweaks. Should be interesting to see...
Chivas
Posted By: ramsay
Date Posted: 07 Oct 2009 at 8:30pm
has anybody had a chance to compare a mk5 to a mk2? just wondering if there is much difference in design or sound - they only mention braking adjuster, new led, pitch reset button and range of settings..
Monday you're the pigeon, Tuesday you're the statue, Wednesday you're the pile of sick that mysteriously disappears from the pavement overnight..
Date Posted: 08 Oct 2009 at 7:36am
FWIW the differences most likely to affect SQ are in the arm.
It uses a different armtube, better internal arm wiring and better external cabling and connectors.
All of those are available from Kabusa as separate items and can be fitted to a Mk II, since you are in Glasgow it might be cheaper to have J7 of audio origami work the arm for you.
For a cheap tweak for the Denon HOMC you might like to try using a "T" adaptor with a 1K loading resistor in the branch.
This has been discussed elsewhere on this forum and to my ears it does make a difference to the sound of the DL-110 when used in the stock arm on the Mk II.
Posted By: ramsay
Date Posted: 08 Oct 2009 at 5:08pm
ah its all good, i have a mk5 anyway.. got a git of saving to do but quite happy with it atm. just waiting on a phono stage from Mr Slee and associates..
time is an illusion, lunchtime doubly so.
Date Posted: 08 Oct 2009 at 6:07pm
They're working on it as I type Smile
Posted By: ramsay
Date Posted: 08 Oct 2009 at 6:15pm
now thats what i call customer service Thumbs%20Up next step : webcam!Lamp
Posted By: Chivas
Date Posted: 23 Nov 2009 at 6:16pm
I finally took the plunge.. The itch just wouldn't go away and I bought the Jelco 750D for my 1210 mk2. All in the name of research and science for this forum of course...it's a pleasure.. Thumbs%20Up
I got the Jelco for a very good £210 on Ebay (new), an armplate for £45 and also bought the Jelco JAC 502 arm lead. So basically upgrading the arm cost circa £320. Not too bad.
I (tried) to install it this weekend, but am unfortunately unable to report back accurately as I believe my setup is not quite right. If it works, it works really well, I hate doing this, because it sounds so cheap (very few (commercial) reviews don't irritate me, it sounds like everyone is regurgitating meaningless words from some template...a template normally aligned to some preferred brand or price point), but everything seems clearer, more rhythmic, greater soundstage, darker background, there is just more air between all the instruments and much more detail and that is where the problem comes in.
Up to now on my standard setup, my system has been relatively insensitive to cartridge alignment, tracking force, VTA and bias (anti-skate), but for the life of me I cannot get it to work right now. Everything sounds fine/great until I get to the high frequencies or the music gets loud, it then distorts heavily.
I know the mounting distance is right and the tracking force is right, I've measured both, but am not sure what to use to set the arm up correctly or what protractor is best for this particular combination.
Any suggestions will be greatly appreciated! Once I get it right, I will report back on my findings.
Next stop is hopefully the Reflex...and hopefully along with that the itching will stop.... Ouch
Chivas
Date Posted: 23 Nov 2009 at 8:25pm
The above graph not only represents phono stages but all amplifiers.
The hi-fi press started talking about it in the 70s.
The hi-fi industry forgot about it almost instantly, and after measuring flavour of the month equipment (as far as other forums go) I can see most get off on such phase modulation - the loonies!
Here's a picture of some more loonies...
and some more...
(from Terry Gilliam film Jaberwocky... "If he kills the beast we're finished" Wink)
Date Posted: 24 Nov 2009 at 4:18am
Graham,
for those of us struggling to understand the relevance of the graph and what exactly it indicates, perhaps a little elucidation ?
Chivas,
I assume you are still using the DL-110 ? - still no matter, the following still applies to setup regardless of cartridge.
IIRC the 750D uses 2 grub screws in the pillar mounting collar to allow adjustment of VTA, back them off until you can just gently raise/lower the pillar, with the stylus resting on a record, hold a small, say 50mm square of carefully cut graph paper behind the headshell with the bottom edge resting on the record surface, use this to set the headshell top horizontal/parallel to the record surface, tighten the grub screws to lock your VTA.
The other possibility that immediately occurs to me WRT the behaviour observed, is that that arm uses fluid damping and should have come with a bottle of silicone fluid and instructions on its use, lack of fluid in the damper or incorrect adjustment of the damper knob would almost certainly have the effect you describe.
If you did not receive the instructions, the manual can probably be downloaded from vinylengine and silicone damping fluid purchased online.
Incorrect mounting distance or overhang should not have the effect you describe.
Did you check the VTF using a scale of some sort after zero balancing the arm and setting VTF ? -  too low a VTF or severely misadjusted Bias might also have those effects, though less likely than the damping issue.
Incorrect overhang should result in increased distortion varying according to the distance of the stylus from the centre of the record, similarly with misalignment of the cartridge in the fore and aft direction in the headshell, incorrect azimuth will spoil channel separation on all points of the record and incorrect bias will bend the cantilever relative to the cartridge body during play, tend to favour one channel over the other and if severe may cause skipping and distortion more noticeable on heavily modulated sections of track.
Hope some of this helps.
Date Posted: 24 Nov 2009 at 8:32am
tg, I stand corrected Embarrassed
Let us take a single valve, or a configuration of transistors, or an operational amplifier (op-amp) - they're all amplifier stages whether they be for power or pre amplification: the output of a DAC for example (and a jolly good example...)
Question: would you believe any of the above keep amplifying the further up in frequency they go?
Answer: no: none of them do.
Why? A thing called miller effect: there is a "gate" in the universe at the end of a narrowing path. I guess it's what keeps it all together...
At some point all amps start to stop amplifying.
From a very low frequency upward they can all give a "flat" output, but very soon they start sloping off - as can be seen from the graph (two examples are shown). These represent open loop gain - amplification without any control - amplification without negative feedback.
By applying negative feedback the frequency range upwards, is extended. Simply draw a horizontal line at say 20dB on the graph and you'll see where it intersects the slopes will be at a higher frequency.
Now, where the (original - no negative feedback applied) curve is flat the phase is zero degrees, and negative feedback (of your 20dB line) is -180 degrees, so that's fine. But where the curve is falling, the phase is -90 degrees, so the negative feedback is now -270 degrees - not as fine. This is the area of a kind of distortion known as phase modulation. The amp isn't out of control, neither is it in control.
This is the compromise all amps have.
I'll have to break off now as time is marching on, but will return later and explain a bit more.
Date Posted: 24 Nov 2009 at 9:35am
OK, I'm back, I'll continue.
With a single valve or transistor suitably configured (and not the non-linear schoolboy textbook twaddle), the "corner" (where the graph curves start to fall) is quite a bit higher - good?
Not good, because there is insufficient gain (gain being the amount of amplification required), and, or, the output impedance is so high it is incapable of driving anything - a valve being very conspicuous in this respect.
Therefore, to pull-off the amplification necessary for most things in life, more than one device is necessary.
To match the input to the source, the first device is operated at lowish gain (otherwise its input impedance would be tending toward a short circuit), and that is done by localised negative feedback.
The next device is therefore the "big bruiser": the device that runs without local negative feedback (or very little) - the one that does the big gain.
However, in doing this, it has miller capacitance - more of it than a low gain device - and the laws of the universe dictate that it's there.
Which means that the first device finds it easy to drive the second device at lowish frequencies, but it gets progressively harder with increasing frequency as the miller capacitor (the one you don't see because it is intrinsic) is that "narrowing path".
The third device is a current device, which has a "stiff" output and can drive loads and also a negative feedback loop. This third device has no voltage gain, but has current gain - it does not have a miller problem (although it does have input capacitance that can disturb things further) - it's just a "follower".
Now, the problem being that the miller capacitor in the second device can severely limit the entire configuration, sending it "miles" out of phase, so they use a thing called "compensation": a real capacitor in parallel with the miller capacitor, which negates much of the miller capacitor effect (unless that is, the designer is a complete numpty, as can be seen in a minority of modern valve amps).
The result is the shape of the curves of the graph.
A configuration that has high open loop gain will always have a lowish "corner". A configuration that has a lower open loop gain will always have a higher "corner".
If only we could move that corner so it was above the audio band: above 20kHz. But there would be insufficient gain for things that need gain!
So that corner is in the audio band, and that means that the high frequencies suffer because of that corner. The lower the corner, the worse for wear become the high frequencies - the distortion Chivas was refering to!
Part three coming up...
Date Posted: 24 Nov 2009 at 9:44am
Ah, but, I hear you say: Chivas was refering to player distortions? But was he really?
I believe he thinks so and who can blame him. That's what it appears to be. Read carefully though, and you find that what he's done has improved the SL, but now he's got these distortions...
He's now exposing the limitations of the electronics.
That's why I've gone down this track.
Part three still to come...
Date Posted: 24 Nov 2009 at 9:48am
OK so far, I sort of guessed that was the area you were indicating, but could not make a or t of the graph to follow your line (of thought).
waits patiently for next instalment.   Approve
Date Posted: 25 Nov 2009 at 5:18am
See above.
The resistors and capacitors networks R23, R24, C11 and C12 feed into one of the other grids on each output stage valve (grid stop circuit). This is frequency compensation and leads to a similar graph as above/on a previous page (wherever it is).
Just thought I'd throw this in as some people believe valves are magic...
The negative feedback via R2 thus has to cope with the phase modulation just like solid state.
We have now dealt with the reason for distortion on highs - next part is on distortion on loud passages.
(edit: just had a search on the 'net and found absolutely no explanation on these stability components, only absolute trash! There must be quite a lot of valve oscillators out there that were once valve amps...LOL)
Posted By: Chivas
Date Posted: 25 Nov 2009 at 8:58am
Tony
Thank you for the advice. Yes, I have set the VTF using a scale (the Shure mechanical one) and have also played around in a range. It definitely gets worse the lower the VTF, but I don't reach a point where it completely dissapears.
VTA I have set using a spirit level on the headshell whilst the stylus is resting on a record. Cart alignment using the Stupid Baerwald protractor and also tried a couple of others.
The only thing that was set up by the seat of my pants was the tonearm position (not mounting distance) but rotation angle. There is a cutaway in the arm base for the arm rest, this gives you a few degrees of play (say 20-30 deg) with the arm rotation. What is the correct method of setting this up? Although (I assume) the spindle is theoretically on the circumference of a circle drawn by your stylus with the pivot at the centre, the combination of where on this circle the record starts and spindle ends and the cart angle in the headshell (azimuth) will impact the tracking ability of the stylus.
Unfortunately haven't had much time to listen this week, but in the 5 min session before bed time last night it did appear to me that distortion seemed least when bias set at max.
At Graham
Thank you for the interesting teach in and I follow your reasoning, but I still believe however that the distortion I am experiencing is too severe to be only electronics, unless they were bought at Tesco and they weren't... I firmly believe that dynamic level also has a part to play (i.e. also experience distortion when the music gets loud) which makes me believe that it must be player distortion.
What is still a mistery is that on a scale of 1-10 (max distortion) I am experiencing the following: Goldring 1042 (8) DL-110 (4) AT95E (2)...?
Out of interest: Are the Slee products designed with synergy in mind, i.e. will one component be able to drive another into distortion, e.g. Reflex driving Solo/Novo into distortion?
Chivas
Date Posted: 25 Nov 2009 at 9:49am
Chivas,
WRT the arc traced across the record by the stylus, the spindle is not on the circumference.
The arc passes beyond the spindle by the amount of the recommended overhang.
2 point alignment systems usually select inner and outer points as specified in mm from the spindle, usually with reference to one or another nominal standard for inner and outer limits for recording.
WRT the radial setting of the arm, I do not feel it critical provided the arm can be parked well clear of the platter and freely move to the label edge then that should be OK.
As to setting VTA with anything resting on the headshell - not good, this compresses the cartridge suspension and gives a false reading.
The Goldring, due to its stylus profile is reportedly much more sensitive to VTA and alignment generally than either of the other two with their less radical elliptical profiles.
The Goldring is also probably the most compliant cartridge and least suited to the mass of the 750.
Note that the major advocates of this arm on the SL1200 are running much less compliant MC cartridges
I would have expected the DL-110 to be the most suited to this arm.
WRT the DL-110 and the Shure Stylus guage, the Denon has very strong magnets which will be attracted to the metal of the guage and may also give a false reading on that account.
I use a relatively inexpensive digital stylus guage which does not have this problem, it is a Canrong and cost around $AUD70 - it may be sold under different names, I am not sure.
I would not consider it a problem to increase the VTF on the Denon by 0.2gm above the recommended max.
If you do not have a Technics overhang guage, you could try setting the stylus back from the front edge of the headshell by about 2mm.
The angle of the cartridge within the headshell in a fore and aft direction when viewed from above is part of the offset angle which is largely determined by the arm bend on this arm.
Azimuth is the verticality of the cartridge and particularly the stylus when viewed from the front of the cartridge, eg whether it leans to the left or to the right or is normal to the record.  Sometimes this is adjustable by loosening the headshell collar near the bayonet fitting, sometimes only by shimming between the cartridge and the headshell on one side or the other.
One other factor that occurs to me, do you have capacitance figures for the DIN to phono cable you are using ?
You do not mention the fluid damping - is this all set up correctly ?
regards,
Date Posted: 25 Nov 2009 at 10:08am
Over my dead body!
(actually I got your meaning Wink)
Date Posted: 25 Nov 2009 at 10:17am
Didn't mean to suggest that, but a lot of high-end does exactly what I've been rambling on about here - I've actually measured some of it.
In my experience the last item in line, if it does not consider synergy with the "unknown", can cause such problems as this. Then again, it could be anything in the line up. And yes, it can be a problem at the turntable.
When I get a little more time I will continue with my train of thought, which could help others, and I'm sorry it hasn't helped you in this instance. Embarrassed
Posted By: Chivas
Date Posted: 25 Nov 2009 at 11:03am
Not a problem at all, I did not perceive your comment as suggesting that I bought from Tesco - especially as you know half of my Audio equipment hails from Slee Towers... Wink
Your teach in does help and the electronics (and in my case I believe speaker) distortion can very well play a big role here, but my point is you get distortion (something doesn't sound quite right) and you get DISTORTION (makes you sick)... I am experiencing the latter!!
Posted By: Chivas
Date Posted: 25 Nov 2009 at 12:13pm
That is what I thought, but surely as the angle of the stylus changes in relation to the distance from the spindle, the radial setting of the arm must have a big impact on this angle and more importantly change of angle as the stylus tracks across the record?
Is there any way of calculating this? A significant adjustment of counter weight is necessary in order to obtain the same VTF, which obviously suggests a big change in mass with the Goldring, so I cannot expect the same response to the arm mass by the Goldring, can I? But can it be that bad?
I do, but is it still applicable to this arm?
No I don't, tried to get them from the vendor, but was unable to provide. I will do some research on the Internet. I assume the total capacitance from headshell to phono must not exceed 200pF?
This is the std Jelco cable designed for this arm and is 1.2 m long, so I would assume everything would've been worked out by Jeclo, unless it's fine for MC but not for MM...? As you said, most users of this arm on the 1200 run MC....Shocked
Nope, you mentioned that it might make a big difference, but two things:
1. I would like to get the setup as near perfect as possible without having to compensate by using things like the fluid damping. Jelco mentions that it is optional to use the fluid damping so I assume it shouldn't be a necessity. I did play around with the damping cap by loosening, tightening etc, but seems to have no effect (as can be expected) without any fluid in.
2. I expect to be moving soon, so would rather use the fluid when my TT has found its new home.
regards,
[/QUOTE]
Many thanks for all the help and advice!!
Posted By: Chivas
Date Posted: 25 Nov 2009 at 12:14pm
Over my dead body!
Thought so... Wink
Date Posted: 25 Nov 2009 at 3:05pm
Chivas,
from your questions re the "radial setting" of the arm and their phrasing, I am left wondering if we are talking about the same thing here.
In my response I refer to the rotation of the arm pillar within the mounting hole in the armboard.
This involves no alteration in the spindle to arm pivot distance and has no effect on the geometry.
If instead you mean the positioning of that mounting hole at varying distances from the spindle then it will have marked effect - this dimension of mounting the arm is critical to the whole geometry.
With that alternative interpretation in mind I have to make the following observations :
the spindle to centre distance of the 750D is 1mm less than that of the Technics stock arm - 214mm v 215mm
the other critical measurements, effective length & overhang being respectively 229mm v 230mm and 15mm.
the Rega armboards are NOT suitable for this arm, they have a spindle to pivot distance of 222mm and effective length of 237 mm (they are suitable for my Jelco 370H or a Sumiko MMT which are centre for centre replacements for the Rega arms).
if your armboard is specifically intended for the 750D then all is well, to check it use a steel rule to verify the spindle to pivot centre distance of 214 mm.
mounting of the arm at any point on the circumference of a circle of 214 mm radius & centred on the spindle, will preserve the intended/designed geometry.
given that the intended geometry retains the original Technics overhang then use of the original overhang guage is perfectly appropriate.
the specified "null points" are 59.0/112.5 & 58.5/113.5 mm for the 750/stock arm respectively.
alignment using the stock guage does not give a standard 2 point alignment and one is left wondering if Technics intended a single point alignment similar to the Rega standard (probably Stevenson).
Your Goldring is 1.5 grams heavier than the DL-110 according to the cartridge database and providing you are not using the 1 gm mass plate provided with the DL-110. This would equate to a marked adjustment of the counterweight when zero balancing the arm.
Interestingly, in checking your cartridge specs, both the Goldring and the AT have a higher recommended VTF than the Denon, both have a max of 2.5 gm recommended.
Many setup "gurus" recommend setting VTF to max and only backing off if the sound is "sat on", worth noting here also, is that with the rather upmarket DV-XV1 with a recommended max 2.5, a number of those who can afford such toys claim it not to perform its best until run at app 2.7 gm.
The standard Jelco/Neglex cable should not create any capacitance issues and is a very good cable.
Given your intention to move, perhaps leaving the fluid out for the time being is a good choice.
Added some time later;  I have found (I think) the armboard you are using, (f1sport), if the 3 screws holding the lower plate are equidistant allowing any of 3 positions of the lower plate, only 1 will be correct (it is also not beyond possibility that the lower plate could inadvertently be mounted upside down with possibly further variations of mounting distance).
In all of these cases utilising the check measurement of 214 mm from spindle to pivot centre will reveal the correct position.
A further possibility occurs to me since the plates are only 3 mm thick and that is of  undamped resonance in the armplate which conceivably will be transmitted back into the cast plinth with undesirable effects.
The use of small diameter "o" rings between the plates around the joining screws might help here or a larger diameter one under the arm mounting collar with the screws fairly well tightened down to compress the "o" rings might also work, this sort of arm damping/decoupling varies in its success and effect and can only be tried and tested.
I found it helpful with RB 250 on mine but the effect varied according to what feet I was using as well.
Very "suck it and see" - but, cheap to try.
Date Posted: 29 Nov 2009 at 4:10am
Has this problem been resolved yet?
For what it's worth: the Acos Lustre arm which comes with a bog standard Technics SL1200/1210 is a slightly adapted original Rega Planar 3 arm which was used on the original Rega Planar 3 - the one which got all the rave reviews from every reviewer and his cat and dog back in 1979.
I bought a Rega Planar 3 on the strength of these reviews. I hated it!
I blamed the arm, bought a Roksan Tabriz, tore out the Acos Lustre and threw it in the bin.
Did it cure my Rega Planar problem? NO!
I now happily play records on my Technics SL1210, and would I ditch the arm? NO!
Date Posted: 29 Nov 2009 at 4:58am
Anyway, getting back to the electronics...
The third part of my slightly off-topic ramblings considers the distortion produced by the input stages of the phono preamp...
That is to say, before the application of negative feedback - the open loop distortion.
Taking solid-state, or more accurately, an input transistor (a bipolar transistor): these offer the lowest noise which is a prerequisite of a phono preamp input.
Unless steps are taken to avoid it, a transistor input (whether discrete or in an op-amp) is only linear for a 60mV peak to peak input voltage.
Taking the output of a moving magnet cartridge we see it's around 5mV rms, which is about 14mV peak to peak, so that should be OK? Wrong!
Let's look at its output at 20kHz. Due to RIAA and the fact that magnetic cartridges give an output proportional to velocity. As the frequency increases the output does also. And by 20dB per decade, which all boils down to an output of ten times that rated at 20kHz.
What will that be? 140mV p-p. Ouch!
Never mind, we have negative feedback? Just how much negative feedback will it take to cure extreme clipping? About 40dB according to Nyquist (Bell Telephone Labs). And most op-amps have that amount of gain "headroom", and a discrete stage can be arranged to do so too.
But hang on, are we not in the territory of mending something that just broke?
Yes we are. And the sound isn't going to be all that natural.
What is needed is an input stage that is more linear - that allows a larger input signal without clipping it. Then, when we apply negative feedback it is to address slight irregularities rather than glueing a broken vase back together.
This should therefore explain why - if the electronics is suspect - why loud passages and high frequencies can sound distorted, while ordinarilly everything is just sweetness and light.
This may not be the case here, but it will be in some systems.
Posted By: Chivas
Date Posted: 30 Nov 2009 at 8:30am
@ Tony
Hi Tony, many thanks for all the advice and feedback. I've been working 24/7 the last week, so haven't had too much time to fiddle around. You are right, I bought the F1Sport armplate, it looks pretty neat and like I said I couldn't get myself to pay £90 for the DC armplate, 1. cause it just feels like a ridiculous price, 2. DC.... I will try the o-ring idea, it sounds interesting.
@ Tony and Graham
All things aside, although my time has been limited, I have fiddled enough and am enjoying enough success with the DL-110 and AT95E to start wondering if I haven't perhaps damaged my 1042 somehow...?
I will try and find a dealer in London to whom I can take it and try on one of their tables, as I am a lonesome ranger when it comes to Audio in my circle of friends, not even to mention vinyl....
If the 1042 is indeed damaged I would like to replace it, because I quite enjoyed it, gave me a little bit more detail and punch than the DL-110 (although I haven't tried your 1k loading plug suggestion yet, Tony). The 1042 replacement stylus is so bloody expensive (£150 and I can get a new one for £180). Some other forums suggested a replacement for the 1042 and mentioned the Sumiko Blue Point Special which is supposedly much better than the 1042..?, but flimsy and being a novice my fingers are still a little clumsy, so this makes me nervous, don't want to withdraw from the Reflex piggy bank to keep on replacing styli!!
At this point I think it is also worth revisiting my commitment to MM/MC which will determine my next investment in cartridge and Reflex M/C. First things first, I need to find a good dealer in London.
I will come back with more on my findings and your specific suggestions as soon time allows.
PS. Thanks for the interesting teach in Graham!
Chivas
Date Posted: 02 Dec 2009 at 7:25am
Thanks for the progress report, don't forget that the DL-160 will work direct into your 2 SE and is quite a step up from the DL-110 (if the Goldring is defunct).
I considered the BPS at one time but ultimately came across too many conflicting reports.
Enjoy the music.
Posted By: Chivas
Date Posted: 05 Dec 2009 at 12:08pm
Hi Tony
I found the BPS on Ebay for quite a good price and thought I'd give it a try. I can hear it's a good cartridge, but a little too laid back for my liking. It's tonally very well balanced, soundstaging is great, but lacks the punch and energy. I think you summed the DL-110 up quite well when you said it's like it grabs you by the ear and says "Hey, listen up, music happening". The BPS lacks that for me, although I think it is better in certain aspects than the DL-110, including soundstaging. For me, the DL-110 is somewhere between the BPS and 1042 when it comes to the foot tapping factor. The 1042 definitely had its shortcomings, and could sometimes be a little edgy and fatiguing, but it had the ability to send shivers down my spine at the right moments. The vinyl experience is definitely still a novelty to me and everytime I sit down to listen it is for a focused session and I wait for the shivers... The BPS doesn't do this for me. Interestingly enough, although it has a 2.5mV output and the DL-110 1.6mV, I find that I have to turn the volume up quite a bit higher with the BPS. In my experience it is a good thing, it means everything is well balanced and in place, nothing is in your face, turning the volume down is a bad sign, but in this case I am perceiving it as a need for wanting more, some kick missing.
Just in case you were interested...
Chivas
PS. I really believe now that the 1042 is defunct as I was also able to set the BPS up without any hassles, so don't think it is the tonearm setup anymore. I still don't know how I managed this. Is it easy to damage a stylus with a stylus brush?
