RCA cable sequence (phono stage)
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5840
Printed Date: 27 Mar 2026 at 3:31am
Topic: RCA cable sequence (phono stage)
Posted By: Jethro
Subject: RCA cable sequence (phono stage)
Date Posted: 10 Nov 2025 at 5:55pm
Hi all,
Quick question for you.
I have a turntable, phono stage and amp, and 2 sets of RCA cables.
I understand that any system is at the mercy of its weakest link, but was wondering if there is any appreciable difference in which order I use the cables (of different brands/qualities).
My assumption (always dangerous) would be to use the higher quality cable first (TT > Phono stage) to get the best signal in at the start.
The cables in question are
(1) Chorus Straight wire interconnects (natty purple, 100cm)
(2) Fisual S Pearl phono SPPH (serious grey, 75cm)
So, my questions are:
A - which cable is better?
B - does it make a difference re the order?
C - are they letting the side down?
(Hypothetical last question as I'm done spending for now!)
Any comments or inputs greatly appreciated
Many thanks,
Jethro
Ortofon 2m Blue (MM) > Argon TT4 mk2 > GS Gram Amp 2 > Audiolab 6000A mk1 > Tannoy Mercury M2's
Date Posted: 10 Nov 2025 at 6:47pm
Rather than focusing on the brand name of the cable or how much it costs, you need to focus on the technical specs.
For any turntable cable, the cable needs to be well shielded with shields connected at both ends. Good cables have multiple layers of shielding.
For the electrical loading of an MM cart, the cable that matters the most is the one that goes out the back of the turntable into the phono preamp INPUT. That cable should be low capacitance. If you do not know the capacitance spec then I would ask the manufacturer to provide it. Worst case you can try to measure it but that's more of a hassle.
I do not recommend people use "mystery spec" cables, no matter the brand.
Date Posted: 10 Nov 2025 at 6:59pm
Sage advice indeed!
Posted By: Jethro
Date Posted: 10 Nov 2025 at 7:07pm
Hi,
Thanks for the info, i'm not very tech savvy on these things yet.
I found this info about the Chorus (On google) - i don't think they are a current model
  • Insulation: Sintered foam PTFE
But no idea what that really means in practice.
The capacitance specifications for the Straight Wire Chorus interconnects are not explicitly detailed in the provided search results. However, the cable is known for its low capacitance design, achieved through specific materials and construction methods to ensure optimal signal integrity
again, google AI was the source...
Date Posted: 10 Nov 2025 at 8:20pm
I share David's views on manufacturers (not) sharing their cable specs and on turnable to phono stage considerations. Low capacitance is good for MM because you adjust from there. Too much and you get a peak in the treble that can't be fixed later in the chain. However shielding is also important to keep interference out.
In the absence of published cable specs you could try swapping their order in your system. Note any change in the sound like high/mid/low balance, hum and other noise.
