Class D
Forum Name: Amplification
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5799
Topic: Class D
Posted By: Help with bass
Subject: Class D
Date Posted: 23 Mar 2025 at 2:03am
Good evening and kind wishes to all.
I write as owner of a cherished Accession MM, driving my (other brand) power amplifier, which has recently expired.
On the point of purchasing Proprius amplifiers to replace it, I am distracted by a great deal of noise and claims about 'evolved' Class D amplifiers, e.g. 'GanFet', e.g. 'NCx500 modules'.
Based in the view that great amplifiers occur through a synergy of technological developments and skilful application (design and engineering) my question is, has GSD any interest in or plans to produce a Class D amplifier?
Date Posted: 23 Mar 2025 at 7:01pm
I've not heard anything about HFC developing a class D amp but I do have a pair of Proprius amps I enjoy. They are powered by efficient switched mode supplies, have low power consumption and run cool in standby if that helps.
Date Posted: 23 Mar 2025 at 7:49pm
Many thanks for your reply Fatmangolf.
I do expect my ampli journey is moving inexorably towards the Proprius amps. My ideal scenario post-record player is to be 'fully Slee'd''.
It's just that it's a bit of money to lay out and that's why I'm hesitating when there's allegedly, apparently cheaper 'alternatives'  on offer.
Best,
D
Date Posted: 23 Mar 2025 at 8:41pm
If you want to try a Class D stereo speaker amplifier, I suggest the Nobsound NS-01G. It costs less than £30 with power supply on Ebay from Douk Audio. I made a pair of speakers in cardboard boxes for my girlfriend. I covered them in white bed sheets and put in Markaudio CHR-90 drivers, powered from this handheld amp using primarily the Bluetooth input. The sound quality is surprisingly good and we both love them. Not bad for less than £200 altogether. However, they are no Proprius. Proprius are Class AB and are monoblocks. If I totally Slee'd her speakers, the performance jump would be significant.
Date Posted: 24 Mar 2025 at 8:02am
Thank you Ash for your helpful and informative reply.
In fact my previous amplifier was a Class AB design and I was very happy with the sound. Unfortunately it failed despite having undergone an expensive repair five years ago, and so I had to let it go.
It's remarkable that you can put together a decent sounding system for such a modest outlay. I gather that, while Class D technology has been around for some decades, it has only more recently been developed and fully embraced in the 'audiophile' world.
It is for that reason that I came to wonder what potential there would be if the same ingenuity that produced the patented technology in the Accession phono amp was applied to a Class D design power amplifier.  When funds allow, I will indeed go ahead and invest in the Proprius amps, as I expect that will be the complete antidote to my questioning 'what if..?' :)
Thanks again,
D.
Date Posted: 24 Mar 2025 at 8:01pm
Majestic DAC into a pair of Proprius monoblocks is the reference point for me. Enigma PSU1 and Lautus/Spatia cabling will provide some further improvements. My speaker driver choice would be Markaudio CHR-90 or CHP-90. These drivers scale well with the driving electronics and are exceptional value. They make exotic headphones look extremely poor value for money.  Just have to put them in boxes.
Class D amps have good power efficiency so generate less heat and can have very compact form factors, but they generate a lot of electrical switching noise that can compromise the fidelity of the output signal.
Class A amps have poor power efficiency so are wasteful of energy, generating a lot of heat and causing the components to run hot, diminishing their usable lifespan and resulting in inconsistent performance. The power availability means lots of voltage swing though and less noise than Class D.
Class AB seems to balance the strengths and drawbacks of the different amp types.
Date Posted: 24 Mar 2025 at 8:10pm
I think lowering power consumption is a big factor in the class D designs. Good for your electricity bills and good for the environment. Unless you live in a huge house my opinion is a smaller hifi amp with less watts may be plenty and cheaper to run.
Date Posted: 25 Mar 2025 at 2:57pm
I don't have a huge listening room and not outlandish power consumption would be a definite plus for me.
The Majestic DAC/pre is a much admired product and I've seen the many reviews citing the great sound and pretty unique flexibility in use.
My particular system is vinyl-based so I connect a power amp directly from the Variable output on the Accession MM.
This unusual facility on a phono stage was a massive incentive to purchase for me as I try to keep the signal path as short a possible. The Accession was a game changer in my system and I'll never purchase another phono stage (except perhaps an Accession MC!)
On the odd occasion when I play CDs I'm happy enough to switch cables on the power amp (though any thoughts or advice on avoiding damage to the input sockets through wear and tear over time would be welcome).
My speakers are PMC GB1, which I like a lot, and I gather from the forum are a manufacturer fairly widely used with GS equipment with positive results.
Only thing missing now, in the absence of a GS design Class D alternative, are the Proprius, and a CuSat 0.6M cable, so they're next on the list.
Thanks again for the helpful replies,
D.
Date Posted: 26 Mar 2025 at 8:47pm
I have run the Proprius amps directly off a phono preamp using phono leads and it sounded very good. I use the DAC in the Majestic as well as connecting the phono preamp which also sounded very good. I hope that helps you.
When switching cables I would loosen any clamps and slide them out of the source component. There may be a better way...
