Turntable or tonearm change?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5643
Printed Date: 27 Mar 2026 at 2:48am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Turntable or tonearm change?
Posted By: Vincenzo
Subject: Turntable or tonearm change?
Date Posted: 30 Jul 2023 at 6:15pm
Hello, I wanted to upgrade my turntable, I currently have a P******t 2Xperience SB and I wanted to upgrade to something more particular in order to make the most of my Ortofon Cadenza Bronze. I was thinking of two solutions: 1- Modify the P******t by replacing the arm with an Audiomods Series Six. 2- By purchasing a Clearaudio Performance SE. I would like to know what you think. Thank you.
------------- Amp. Musical Fidelity M6si,Turntables VPI Scout Signature, Cartridges Ortofon Cadenza Bronze, Graham Slee Accession MC, Speakers Triangle Esprit Antal Ez, Cables Rotrwell The River,ATLAS Equator MKIII
Date Posted: 30 Jul 2023 at 7:31pm
What is the change in sound you are looking for, Vincenzo?
Posted By: Vincenzo
Date Posted: 30 Jul 2023 at 7:47pm
Better, in every way
Date Posted: 30 Jul 2023 at 7:52pm
Then I would buy a new and better turntable. How did the Clearaudio sound to you?
Posted By: Vincenzo
Date Posted: 30 Jul 2023 at 7:55pm
I have no idea, I know they are good turntables at a still affordable price
Date Posted: 30 Jul 2023 at 8:17pm
Could you borrow one to try in your home system?
Posted By: Vincenzo
Date Posted: 31 Jul 2023 at 7:11am
I find it very difficult for a shop to make me do this.
Date Posted: 31 Jul 2023 at 5:51pm
Ah. I see you want to try before you buy, but cannot. I haven't heard that Clearaudio turntable so can't help. I hope others here may.
Posted By: Vincenzo
Date Posted: 01 Aug 2023 at 7:37pm
Right now I have a Rega Planar 8 in view. I would put my Ortofon Cadenza Bronze. What do you think?
Date Posted: 01 Aug 2023 at 7:48pm
Although I admire the 8 and 10, I stopped at the Rega P3-24 which I still have. It depends on your preferences, particularly the ideal sound you are after from records.
Posted By: Godra
Date Posted: 03 Aug 2023 at 5:52pm
Hi! I've been using a Clearaudio Performance DC with the clarify tonearm for 5 years now. I really love the Clearaudio turntable; solid engineering, manufacturing and performance. Too bad the price keep going up!! My turntable is dead silent, the wow and flutter are really low. I would summarize the sound signature in two words : neutral and detailed. I don't know about the performance se, but I think it is the predecessor to the current Performance DC.
Hope it helps!
------------- Clearaudio Performance DC with Clarify tonearm + Virtuoso V2, Tannoy Legacy Eaton, Accession MM and BAT VK300Xse
Posted By: Vincenzo
Date Posted: 04 Aug 2023 at 7:06am
Many thanks to you, I'll think about it, in the meantime I've already set my sights on a good used VPI Scout. I hear good things about it but I don't know it.
