Turntable Wobble
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5639
Printed Date: 26 Mar 2026 at 7:25pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Turntable Wobble
Posted By: Speculator66
Subject: Turntable Wobble
Date Posted: 04 Jul 2023 at 4:52pm
Hi all.
I have been using a P******t http://www.henleydesigns.co.uk/Xtension-9-p1366 - Audio Systems Xtension 9 Super Pack for some years.
Of late it seems to have developed a very slight wobble which obviously sends rumble like sound through the system.
Having paid a lot of attention to the P******t wall mounted shelf that it sits on to ensure that it is level, I find that it seems to go out of level from time to time. Also, the board that the t/t sits on seems unable to hold the weight.
What material might I use to ensure that the base board doesn't go out of true - the T/T is very heavy. Are there other things that I might check/renew, e.g. the belt. ?
Thanks for any suggestions.
Speccy
------------- Pjct Xtension9 Superpack, Ortofon Quintet Black, Accession MC, Arcam A39, Celestion 66
Date Posted: 04 Jul 2023 at 8:10pm
How far out of level, please?
Date Posted: 04 Jul 2023 at 9:16pm
Hi Not very far at all as far as I can tell.
It may well turn for a long time before the wobble starts - say a whole lp side.
John
