Phono Stage Squared!
Category: Administration
Forum Name: NEWS
Forum Description: Details of things like site maintenance, downtime, site upgrades, flood, famine and earthquakes.
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5562
Topic: Phono Stage Squared!
Subject: Phono Stage Squared!
Date Posted: 02 Dec 2022 at 10:05am
I've been meaning to write this for a long time but I keep forgetting to do it.
I'd like it to be understood by all, that plugging the output of a phono stage into an amplifier or receiver input called phono might seem right to some, but is bloody stupid!
"Well, it's called a phono stage so I connected it to the input saying phono"
The phono input (if your amp/receiver has one) IS TO AN INTERNAL PHONO PREAMP!
I'm pretty sure all our instructions say not to do this, but who the hell reads instructions? Instructions fall into the same bracket as the Bible!
A phono stage equalises a magnetic cartridge, and also an RIAA record. By not understanding that you will not realise that a phono input then does the same again.
"Oh, the noise it's making. Your phono stage is faulty"
The phono stage has a gain of about 60dB (x1,000) at 20Hz (lowest bass), and the built-in phono stage does roughly the same.
The result? 120dB of lowest bass gain, that's times one million, which is one thousand squared.
At 1kHz (the mid reference frequency) it's usually around 40dB, so you get 80dB or ten thousand times, instead of one hundred (100 x 100 is 100 squared, which is 10,000).
At the highest audio frequency, 20kHz, the gain is normally about 20dB (that means 10), so here again we get double the dBs, that's 40dB, which means times 100, and 10 squared is 100, yes?
So one million times the output of a phono cartridge at 20Hz. What's that?
Well, the cartridge because of its constant velocity outputs 1/10th of its 1kHz output so if it's 5mV at 1kHz, it's 0.5mV at 20Hz.
So, one million times 0.5mV is half a million mVs. Which is 500 volts!
Now, admittedly you'll turn the volume down, and another little known thing is that no transistor amp can do 500 volts, and I'd be surprised if a domestic valve amp can do 500 volts r.m.s.
So it clips hard, and what do you get when it clips hard? A square wave!
So what you're getting is a square wave the size of the amp's front end power supply voltage.
"But it's crackling like crazy"
Well, of course it is!
"And the amp has shut down"
Well, that's it's protection circuit!
Or worse, "the fuses have all blown"
Well, what do you expect?!
I'll not bother explaining the mid and high frequency levels this causes, because hopefully it will have sunk in by now?
Plug the phono stage output into a line-level input like aux, and all will be fine.
Date Posted: 03 Dec 2022 at 11:08am
People really do this? Wacko
Date Posted: 03 Dec 2022 at 11:57am
If you don't know what you're doing, you either refer to someone who does or you sit and read the instruction manual until you are familiar with the inputs/outputs?
The stupidest things I've ever done with hifi are connect speaker drivers directly to a laptop headphone socket with no amp (many years ago; damaged the laptop sound output over time but it was fun while it lasted) and connected headphones directly to Majestic line-out and a small pair of speaker drivers directly to Bitzie headphone output; no harm done but didn't perform as expected.
Date Posted: 03 Dec 2022 at 4:51pm
I once had a biwired speaker out of phase on the high side  No damage but a weird stereo image which is when I realised my mistake. However running a phono stage into another phono stage is surprising. To get more gain some guitarists deliberately did this with guitar amps, leading to multistage preamps ans lots of sustain. Very high gain as Graham said so some filtering/EQ is needed.
Date Posted: 03 Dec 2022 at 6:11pm
If you have a phono stage with a variable (line-level) output like the Accession MM, you could turn the potentiometer right down to attenuate the signal level enough to put it into a phono input without clipping?
Date Posted: 03 Dec 2022 at 7:28pm
That is how cascading gain stages in guitar amps work. Cutting the output of the Accession would help but in the phono squared scenario you'd still have the problem of the RIAA  equalisation being done twice.
