Accession MC connected to pc
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5557
Printed Date: 24 Apr 2024 at 6:37am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Accession MC connected to pc
Posted By: Vincenzo
Subject: Accession MC connected to pc
Date Posted: 25 Nov 2022 at 9:37am
Hello, I wanted to connect my Accession MC to the pc to store some songs on the computer. What do I need to do this? Thank you.
------------- Amp. Musical Fidelity M6si,Turntables VPI Scout Signature, Cartridges Ortofon Cadenza Bronze, Graham Slee Accession MC, Speakers Triangle Esprit Antal Ez, Cables VAN DEN HUL D-502 Hybrid,ATLAS Equator
Date Posted: 25 Nov 2022 at 11:37am
The output of the phono stage will be an analogue signal at line level. You could feed this straight into the line-in of an analogue-to-digital converter for recording to the computer.
Posted By: Mikeh
Date Posted: 25 Nov 2022 at 11:42am
You need an ADC (analogue to digital converter) to take the variable output from the Accession and give a usb connection output to the pc. I use a Focusrite Scarlett as the ADC which works quite easily. Connection from the Accession to Focusrite uses a phono to jack plug lead. Recording the vinyl to store on the pc could use free software such as Audacity or Vinyl Studio by Alpinesoft which very easy to use. Hope this helps.
------------- Mike
Technics sl1210g with Victor U-2 Accession MM, Majestic + Proprius, Solo ULDE Cambridge Audio CXC CD player Lindemann Limetree Bridge streamer Harbeth P3ESR XD paired with 2x REL t5x
Date Posted: 25 Nov 2022 at 11:53am
"Audio interfaces" are typically an ADC and a DAC, all in one product and used for both recording and monitoring/playback.
Date Posted: 25 Nov 2022 at 12:05pm
Ash wrote:
"Audio interfaces" are typically an ADC and a DAC, all in one product and used for both recording and monitoring/playback. |
Bring back tape!
Date Posted: 25 Nov 2022 at 6:38pm
Graham Slee wrote:
Bring back tape! |
I agree. It was so much easier to record vinyl to tape.
Date Posted: 25 Nov 2022 at 6:55pm
Tape did need a bias setup and levels being right. Now we can just use a portable digital recorder.
Date Posted: 25 Nov 2022 at 7:53pm
Fatmangolf wrote:
Tape did need a bias setup and levels being right. Now we can just use a portable digital recorder. |
And with the variable output from the Accession there's no need for additional attenuators to prevent clipping the input (the one thing that isn't possible to fix in post production) of the portable digital recorder
Date Posted: 25 Nov 2022 at 11:20pm
Musicians use audio interfaces to record instrument performances to a computer. With analogue instruments, plug in a microphone and set the gain level. With digital instruments, plug the instrument into the line input by cable and set the gain level. I've never done it but I think I would be able to work out what to do.
