Pop
Forum Name: Amplification
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5553
Printed Date: 27 Mar 2026 at 2:55am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Pop
Subject: Pop
Date Posted: 20 Nov 2022 at 8:52am
Why do I get a loud pop from the speakers wherever I turn the power off, or if there is a power cut, even with volume turned right down on my Majestic?
Date Posted: 20 Nov 2022 at 9:06am
It's probably produced by the amp's output stage as its power supply voltage falls.
Date Posted: 20 Nov 2022 at 10:26am
Is it normal? I just turned down the volume on the Proprii pair before switching off and there was silence.
Date Posted: 20 Nov 2022 at 12:41pm
I use to get it with my old amp but with MF M2si I don't. I normally leave it powered up, I did try it out today but still no pop.
Date Posted: 20 Nov 2022 at 4:02pm
ICL1P wrote:
Is it normal? I just turned down the volume on the Proprii pair before switching off and there was silence. |
Most amps I owned did this unless they had a muting circuit/relay.
Date Posted: 21 Nov 2022 at 9:06am
Thanks.
