cartridge match advice
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5551
Printed Date: 27 Mar 2026 at 2:30am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: cartridge match advice
Posted By: Vinyl Reader
Subject: cartridge match advice
Date Posted: 17 Nov 2022 at 5:40pm
Hi I have just bought the Gram Amp2 I have a Systemdek IIX with RB250 arm and a Naim Nait 5i. Monitor Audio GS10. Any cartridge recommendations please.My budget is about £300.Thank you
Posted By: Cyreg
Date Posted: 17 Nov 2022 at 6:55pm
Well,I can tell you that for about 8 years, I play with a Gramamp2 Communicator with PSU1 I do use a Michell TecnoDec and RB250 with Michell TecnoWeight (big improvement)
My cartridge is a Nagaoka MP110 (GBP 150?) and I just have my fourth stylus in use ;-) So....I am very content with this combination!!
Oh yes and welcome to GSP
------------- TecnoDec/RB250/MP110>GramAmp2C/PSU1; Cyrus CD8SE; > Exposure 3010S2D INT > Harbeth C7ES-3 '35th Anniversary' cabling: IC 2x DNM V3; LScable Exposure DMF-two; Furu TP60 + MWaY and BlackCable pc's
Date Posted: 17 Nov 2022 at 7:35pm
Charles. Welcome. Jon
Date Posted: 17 Nov 2022 at 8:57pm
Thank you for joining us Charles. I have s Goldring 1042 fitted to the Origin Live Zephyr arm on my SL1210/II but it's more than £300 now The 1012 was pretty good too if that helps.
Date Posted: 18 Nov 2022 at 6:35am
Thanks i was planning to get the technoweight so perhaps I split the budget and get a MP 110. Any platter mat suggestions currently on the glass as the old felt is static and hairy.thanks
Date Posted: 18 Nov 2022 at 11:59am
Leather works well for me, although most say that a platter mat is not needed on a acrylic platter, but I find it give's me a smoother bass.
Date Posted: 18 Nov 2022 at 12:26pm
I tried leather but I still had a a lot of static. My platter is glass not acrylic. Is there any reason why using a matless glass platter is inadvisable ?
Date Posted: 18 Nov 2022 at 2:26pm
They do make glass platter mats so I can't see there being any problems. I have not had any problems with static with my leather mat but I do know that it can be a problem. You can get acrylic platter mats, There are also Rubber & cork combination mats, these mats are said to offer high levels of static prevention, sound dampening and vibration absorption. The most popular mats are made of cork. The trouble with platter mats is, what works for someone may not work for others ie the sound, as all mats are going to have an effect on the sound you are going to get from your record playing.
Date Posted: 18 Nov 2022 at 6:30pm
It's worth trying without a mat to find out if you like the sound.
Date Posted: 18 Nov 2022 at 11:09pm
The tough part about suggesting a cartridge is that everyone has different tastes and priorities. Almost any high output cartridge suited for a medium mass arm (I think that's what you have) will work with the GA2SE. So you really just have to narrow the choices and decide what you like best.
Re: mats, I've never used a glass platter so I can't really suggest the best mat. Usually I would go with whatever the manufacturer suggests.
IME any mat can generate static - because the very act of playing a record involves friction. The best cure for static is to get at the source, which is usually air that is too dry. An easy thing to try is turning the thermostat down slightly, and no socks on carpet. Some folks that live in very dry environments will use a humidifier in conjunction with a hydrometer, or even an anti-static floormat.
Good luck.
Date Posted: 19 Nov 2022 at 9:32am
I agree with patientot - the arm is medium mass, so it should work well with many cartridges. Just stay away from high compliance ones.
It should work well with something like the AT-VM95ML https://www.audio-technica.com/en-gb/cartridges/type/moving-magnet/at-vm95ml - https://www.audio-technica.com/en-gb/cartridges/type/moving-magnet/at-vm95ml I have one and it does a good job.
I used a Deflex Platter Mat when I was running a Systemdek IIX - I found that the added mass of the mat improved rotational stability. When I bought the deck it had a felt mat, which I didn't get on with. I'd experiment with rubberised mats
Date Posted: 26 Mar 2023 at 5:01pm
Thank you for your advice everyone;So time has passed and I am finally ready to upgrade my AT VM95E. Systemdek IIX RB250 arm with Michell technoweight & VTA adjuster.(cork/rubber mat)Origin Live DC motor & ultra speed control.GS communicator 2+ PSU. Naim Nait 5i. Monitor Audio GS10.
Budget:400€
NAGAOKA MP200 GOLDRING 1042 AUDIO TECHNICA VM750SH GRADO Gold 3
From what I can gather the phono amp is lean,Amp neutral light on bass thump but defined.These statements please contradict etc; I listen to rock blues jazz acoustic and world little classical. Warm cartridges Grado Goldring , Punchy Nagaoka, AT clinical detailed ???????
Thank you for time
Date Posted: 26 Mar 2023 at 5:27pm
If the records are in reasonable condition and clean, the easiest upgrade you can perform is to keep your cartridge body and replace the stylus with a VMN95EN, VMN95ML, or VMN95SH. Of those the ML would be my personal pick. If you don't have a real record cleaning system I would choose one of the others, probably the EN.
Your phono preamp should be dead neutral so if you're getting a "lean" sound it's likely down to some other factor. I do think (subjectively) the VM95s sound a bit better on a slightly heavier arm though an 11g arm like a Rega arm should theoretically be fine. I don't know anything about your speakers, room acoustics, or the records you are playing. Those can be big factors. FWIW most speakers will have peaks and valleys in the response and folks are often quick to blame these things on the cartridge.
I am personally not a fan of Grado cartridges but a lot of people like them.
The AT 4 coil designs like the VM500 and 700 series really need careful loading (both resistance and capacitance) to get a neutral-ish sound. Otherwise they will be tipped up by +3dB or more at 10K or so. Many aren't willing to make loading plugs and the like so they should avoid these cartridges. The AT VM95s are a totally different design and don't have this problem.
The Nagaoka should work fine on your arm. Not my personal favorite, but again very popular. They have gotten fairly expensive in recent years.
The 1042 is considered a classic cartridge in many circles but I didn't love mine and moved on from it. You might like it though. Also commonly paired with medium mass arms and GS gear.
My 2 cents.
Date Posted: 28 Mar 2023 at 2:32pm
Thank you all for your advice ! I have chosen a Goldring 1042 because the quality of the stylus and a good price (378€) Furthermore I am guessing this cartridge will be a better match for my Gram amp2 and Nait5i. Should I be thinking of upgrading the arm to an Audiomods Classic III tonearm (£695) or a better GS phonostage:Reflex (£695).I am curious as to what you think is the weak point in my system ? a cheaper option would be an Incognito re-wire. I have read that I may have upgraded the cartridge beyond the capacity of my set up to fully realise the cartridges potential. Thank you for time, much appreciated.🙏
Date Posted: 28 Mar 2023 at 3:27pm
Hi Charles,
The RB250 is a fine arm but the Audiomods Classic 3 will be a significant improvement on it.
You'll notice the superior bearing quality the 1st time you hand cue. Wiring & counterweight mods can improve the RB but the Audiomods is a major redesign with only the arm tube left, which is the Rega's strong point. I did something similar a few years ago & was surprised at the overall sound improvements.
Date Posted: 28 Mar 2023 at 3:32pm
I can't speak to the differences between an AM arm and a Rega arm, but if upgrading the arm and/or getting the existing arm rewired, I would try to make sure the shielding on the arm cable is as good as possible.
I know that sometimes Rega arms have less than ideal shielding on the stock cabling. If you check some old threads here you may find some topics on cable shielding.
Posted By: HiFiForMetal
Date Posted: 26 Sep 2024 at 12:51am
I had a question about cartridges for the Reflex, I am getting a clearaudio Air concept with carbon fiber arm. I Really am torn between getting a clearaudio artist Moving magnet or the New Sumiko Bluepoint, I know the Bluepoint Evo iii pretty well and used it with a project RPM-9 With Graham Amp 2SE and loved its fleshed out Spot lit character as a HOMC, but is the clear audio Possibly better or have better synergy with The arm and the phono stage? Any help would be appreciated By the thread.
Date Posted: 26 Sep 2024 at 2:04am
HiFiForMetal wrote:
I had a question about cartridges for the Reflex, I am getting a clearaudio Air concept with carbon fiber arm. I Really am torn between getting a clearaudio artist Moving magnet or the New Sumiko Bluepoint, I know the Bluepoint Evo iii pretty well and used it with a project RPM-9 With Graham Amp 2SE and loved its fleshed out Spot lit character as a HOMC, but is the clear audio Possibly better or have better synergy with The arm and the phono stage? Any help would be appreciated By the thread. |
The Bluepoint carts have been around a long time. Made by Excel, IIRC. If you know you like them then they are a good bet for you. From what I can tell the Evo series was discontinued and now Sumiko is mainly selling the Songbird as a replacement. They still have the Blackbird which may be similar to the Evo series. IIRC the BB comes in either high or low output.
The Artist moving magnet cart looks like a typical CA MM job where they are scant on detailed info but are really just using an AT VM95 or 95 series generator with "elliptical" diamond then stick it in a wood or metal outer shell. My guess it is a cheaper bonded diamond, since they don't mention that it is nude. If it were they'd be harping on that fact. I'd rather just buy a cart direct from AT so you know exactly what you are getting.
In terms of the arm could you be more specific? Looks like CA makes more than one carbon fiber arm. There is the standard one which is 9g and the "Satisfy" which is 7g effective mass. They have more arms still. I would choose a fairly compliant cart on the lighter one. On the 9g arm you could go either way, but I'd probably avoid any cart with a very stiff suspension when it comes to either of these arms.
Date Posted: 26 Sep 2024 at 10:41am
It is a satisfy Carbon Arm
I plan after the purchase to get Stack Audio Auva EQs as well if that info interests you.
Yes the blue point is still made, they now have it in A covered aluminum body and have damped the resonances More so it’s the same old cart as the EVOiii but With better dampening. I’m afraid the blackbird is no more I wanted that cart for a long time about 17 years ago. And I’m not sure I like the songbird.
I think the clear audio artist cart is made by them with AT Parts and it could be a VM95 generator but they wind Their own coils there so my guess is they are modifying it Significantly and of course adding an ebony shell,
The current bluepoint iii does look a lot like an Umami Blue by Excel, I think though the Bluepoint may be better In terms of channel separation and frequency range alone than the Clearaudio, I was just wondering if the Clearaudio Artist was particularly good with A graham Slee phono stage Since obviously Graham’s stages do miracles With moving magnets.
Thanks for your advice
Date Posted: 26 Sep 2024 at 11:23am
This one?
https://www.musicalsurroundings.com/products/clearaudio-satisfy-cf-carbon-fiber-tonearm - https://www.musicalsurroundings.com/products/clearaudio-satisfy-cf-carbon-fiber-tonearm
Effective mass is 7g.
OK. Odds are it's not that much different than whatever they were selling years ago with the same Excel generator. If you know you like the cart already, then it should be a safe purchase.
A simple test with a multimeter to measure resistance and inductance would tell the truth. As for "winding their own coils", with an MM cart, that is highly unlikely. Virtually no one hand winds MM carts or high output MI carts because there are too many winds of coil to do. The process is usually automated and done on a machine. Of course dealer/salespeople will talk a lot of bunk so maybe that is where you heard that. I wouldn't buy it for a second. LOMC carts are a different story and usually have to have the coils hand wound. Of course those have very few turns of wire in the coils.
As for CA's "mods" when the carts have been taken apart and the diamonds put on a microscope the truth is revealed. Their basic MM carts are nothing special and have cheap diamonds on them. The higher end ones usually have much better diamonds and cantilevers but they are often murky about what you get. Lot of marketing talk and bunk in the cart world with very few companies actually making cartridges, cantilevers, and diamonds at the OEM level.
Excel is the OEM for those Sumiko HOMCs. Sumiko is just a brand name/marketing company. Excel makes MC carts for several brands and has for decades.
The Artist will work. Not a particularly good value in my book for the reasons stated. If you want an alternative I would be looking at the AT VM500/700 series, Ortofon OM or 2M series, maybe Nagaoka. Any of those should match well with your CA tonearm. The AT 500/700s will be trickier to load electrically for the best frequency response...I recommend short low capacitance phono cables and parallel resistive loading for those.
The Blue Point will also work. Western compliance at 10Hz will be much higher than the Japanese 100Hz spec as seen in tests done years ago by Miller Audio Research...
Date Posted: 26 Sep 2024 at 1:23pm
Yes that is the tone arm, the satisfy carbon It’s the main one that comes with the concept air, Other than the tracer which is more expensive.
I appreciate your feedback, I know Prima Facia Evidence seems like the clearaudio cart is just a rebadge
If you watch Michael Fremer or pursuit perfect systems factory Tour they show them doing coil winding at clearaudio they do make LOMC carts with original parts, like the Goldfinger. As far as what’s inside them maybe it’s to hide proprietary methods of modding, maybe it’s that they are just taking these carts modding the exterior and doing very exacting matching, or Just rebadging and rehousing them I don’t know. I’m not fond of AT carts except their LOHC and I’ve been told by people their carts do in fact sound different than ATs, but I digress.
As for excel and Sumiko my guess is Sumiko is also designing carts as well I don’t think the Hana stuff and Sumiko carts sound the same, I don’t like Hana carts till you get to the umami blue or even red. At which point I would probably buy a gold ring ethos anyway, that cart is sort of my end goal.
Thanks for your input I will go with the blue point iii And hopefully the new one has improved a bit since the Evo iii version
All the best…cheers.
Date Posted: 26 Sep 2024 at 1:49pm
As I said coils have to be hand wound usually on LOMC carts. That can be done in house or by a third party OEM depending on the specific product we are talking about.
When a manufacturer works with an OEM, they typically have a "menu of options" they can work from but often the selection off that menu often doesn't justify the heavy markup in my view. Witholding basic technical info is usually a red flag.
Pick and mix off a menu is certainly a long way off designing a cartridge from scratch. Very few companies do the latter.
Date Posted: 26 Sep 2024 at 2:12pm
I don’t know if magnet winding machines Are hard for them to get, or maybe they Are just doing a great matching and resonance Modding job. I don’t know it would be worth a call To them to find out.
I agree with you there a different level levels To design work, some companies manufacture their own Speaker drivers and are able to engineer bespoke parts Because they are vertically integrated, the best of all Worlds. No doubt but not possible for every manufacturer Wilson audio uses scanspeak drivers which I find rather plain however I do think they make a great product, not one I would buy, but I have heard them sound good. It’s because of The surrounding execution that makes it great.
Not all companies have the means of production and tooling to Be vertically integrated like that. I respect both approaches immensely.
Date Posted: 26 Sep 2024 at 2:37pm
You can see how automated coil winding works in the link below. This is done for high output MM and MI carts in any factory making things at scale. Doing that many winds of coil by hand manually, with no machine involved would be stupidly inefficient. Machines have been involved for decades now.
In the same link, you can see LOMC carts with the coils being wound by hand under a microscope.
https://blog.son-video.com/en/2016/06/we-visited-the-ortofon-factory/ - https://blog.son-video.com/en/2016/06/we-visited-the-ortofon-factory/
Almost no cart company, even the largest ones, make their own diamonds and cantilever assemblies. Those typically come from Fritz Gyger AG, Orbray (formerly Namiki), and Ogura. Expert Stylus also makes a smaller amount of diamonds and Nagaoka produces some as well. If you don't believe me you can ask someone that works on carts for a living or visit the websites of the above companies and then look at their patent documents. It is also possible to purchase loose diamonds with no cantilever but few companies do that.
I have no problem with companies sourcing parts from third parties. Most will be forced to on some level. What I have a problem with are bunk marketing claims, withholding basic information, and wild markups relative to value.
Date Posted: 26 Sep 2024 at 8:59pm
I agree with you, bunk mark ups are bad It’s the last thing high end audio needs, There are already too many accusations Of this in other sectors like in cables.
I’m just saying that I don’t always rush to judgment I don’t know what’s inside nor have I done an ABX shootout with a VM95 type. I personally Think based on guitar pickup manufacturers or small Scale producers like Grado who are doing MM winding of coils it is possible, just watch Steve Guttenberg’s tour of Grado they show that they are Winding their own coils and Grado has less machinery to do So than clear audio by far, they are using the same winding Machines that guitar pickups use.
In this factory tour of Clearaudio he points out the MM Coil winding machine which is automatic.
https://youtu.be/ivCW8ooMoeA - https://youtu.be/ivCW8ooMoeA
It’s at 37:50
So I think we are in the case of a hybrid design Maybe they use AT bobbins or Sylii, but probably the Coils and compliant suspension, dampening materials And case are theirs. This is my guess.
But I agree their is too much stuff that should be More transparent and or not marked up.
Date Posted: 26 Sep 2024 at 9:16pm
It’s at 37:50
Notice how they focus on the machine only for a few seconds and don't really go into much detail. Personally I'm very skeptical that every CA MM is wound on that.
AT 95 and VM95 styli are also a perfect fit on many of their MM carts, though some do require trimming plastic off the stylus housing. This can be done with a nail clipper or X-acto knife, though I'm sure CA doesn't want people to know that. Instead they tell users the stylus is not replaceable at all and that you must buy a whole new cartridge.
It was exposed years ago with pictures so I have no doubt that several of their carts are based on AT 95 series generators of some sort. What's even funnier is that the diamond they put on the lower end models is a very cheap bonded stone as I said, and some CA users that received CA MM carts with their turntables noted that their carts tracked better with a new nude stylus or advanced tip from AT rather than the stock one. Put the stock one under a microscope and you'll see it is cheap stuff. Even a 30X loupe will show the bonded shank on those. If they were up front they would just say what the major and minor radii of the stone were and whether they are bonded or nude. But they don't do that...gee I wonder why.
As for Grado they are a small company and don't have the same economies of scale as bigger companies like AT and Ortofon. They will still use a machine of some sort to aid in winding...just as many "hand wound" guitar pickups are wound on a rig that uses a sewing machine or some other device to wind things much more quickly then wrapping everything 100% by hand.
Anyway I've made my point so no more posts from me on this topic.
