Lautus cables
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5508
Printed Date: 28 Sep 2023 at 2:23pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Lautus cables
Posted By: bmbrown911
Subject: Lautus cables
Date Posted: 26 Aug 2022 at 9:29am
I’ve been into headphone audio now for a long time. Owning the solo ultra linear diamond for at least 5-6 years now. Always happy with what came out of it. I’ve never had much interest in upgrading cables because it’s just not an exciting purchase for me. Several years ago when I got into digital audio i decided to purchase the lautus usb cable. Pleasantly surprised with it I finally decided to try the lautus rcas. Since getting them I’ve been completely blown away. Having no idea I would hear this much of a difference. Without going into to much detail everything just sounds so much more open and easier to listen to. Completely shocked. Good on graham for such a worthwhile upgrade without breaking the bank. Will definitely be adding more in the future for the rest of my components and also plan on trying out the balanced cables he has for my balanced components. Cheers!
Date Posted: 26 Aug 2022 at 10:07am
Thank you Robert
