Change phono preamp or cartridge?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5499
Printed Date: 23 Apr 2024 at 7:29pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Change phono preamp or cartridge?
Posted By: Vincenzo
Subject: Change phono preamp or cartridge?
Date Posted: 02 Aug 2022 at 6:11pm
Ciao, posseggo un Reflex M Graham Slee e voglio ad Accession, pensa che le differenze sonore sono tali dare il prezzo? Ho una testina Ortofon Quintet Black, forse per apprezzare un cambio di qualità potrei passare a una Cadenza Black? Cosa ne pensate?
------------- Amp. Musical Fidelity M6si,Turntables VPI Scout Signature, Cartridges Ortofon Cadenza Bronze, Graham Slee Accession MC, Speakers Triangle Esprit Antal Ez, Cables VAN DEN HUL D-502 Hybrid,ATLAS Equator
Date Posted: 02 Aug 2022 at 7:13pm
Sorry Vincenzo but could you put this post into English.
Date Posted: 02 Aug 2022 at 7:49pm
Here's the post through Google Translate:
Hello, I own a Reflex M Graham Slee and I want to Accession, do you think that the sound differences are such give the price? I have an Ortofon Quintet Black head, maybe to appreciate a change in quality I could switch to a Cadenza Black? What do you think?
If I understand correctly, Vincenzo wants to know whether it would be best to get the Accession, or keep his current preamp and upgrade his cartridge to an Ortofon Cadenza Black.
I can't really answer this question, but I know that the Accession MC model is highly praised by those who use MC carts. Myself - I only only use high output, MM or MI cartridges.
Now, I have heard the Cadenza Black once in someone else's system. It sounded good and very detailed. The guy that had it since upgraded his cartridge to a very expensive Lyra model. I have never heard the Quintet carts so no personal opinion on them. Obviously the Cadenza range is higher in the Ortofon Hierarchy and more expensive.
I think it would be best for OP to trial the Accession MC through the loaner program. That would give Vincenzo the answer. They can decide from there whether to keep things as is or upgrade the phono preamp.
To me personally, cartridges are consumable items (they wear out, they come and go) and other equipment tends to stay in the system a lot longer. At 500-800 hours the expensive cartridge styli will be worn like any other cartridge. At that point you'll have to trade in, get a rebuild through the manufacturer, or send the cart to a third party retipping specialist.
A good article here:
https://thevinylpress.com/the-finish-line-for-your-phonograph-stylus/ - https://thevinylpress.com/the-finish-line-for-your-phonograph-stylus/
Posted By: Vincenzo
Date Posted: 04 Aug 2022 at 8:12pm
Ciao, ho fatto la mia scelta, non so se è giusta o sbagliata, ho comprato una DYNAVECTOR DV XX2 MKII, volevo cambiarla ha un suono Ortofon e volevo capire come suonano le altre testine. Quindi tengo il mio preamplificatore fono e vedo cosa succede.
Posted By: Vincenzo
Date Posted: 04 Aug 2022 at 8:15pm
Hello, I made my choice, I don't know if it is right or wrong, I bought a DYNAVECTOR DV XX2 MKII, I wanted to change it has an Ortofon sound and I wanted to understand how other cartridges sound. So I keep my phono preamp and see what happens.
Date Posted: 05 Aug 2022 at 12:33am
Vincenzo wrote:
Hello, I made my choice, I don't know if it is right or wrong, I bought a DYNAVECTOR DV XX2 MKII, I wanted to change it has an Ortofon sound and I wanted to understand how other cartridges sound. So I keep my phono preamp and see what happens. |
Enjoy your new cartridge!
Posted By: Vincenzo
Date Posted: 08 Aug 2022 at 6:03pm
Hello, in the data of the DYNAVECTOR DV XX2 MKII I cannot see how much the value of the lateral tracking force is.
Date Posted: 08 Aug 2022 at 6:38pm
Sorry Vincenzo, I haven't owned one but I'd try 2 grammes and adjust from there.
Date Posted: 08 Aug 2022 at 7:49pm
Vincenzo It says on their website Tracking Force is between 1.8 - 2.2g Hope this helps.
Posted By: Vincenzo
Date Posted: 08 Aug 2022 at 8:07pm
Actually I am referring to antiskating
Date Posted: 08 Aug 2022 at 8:25pm
Not knowing your turntable I would suggest looking at the manual, On my TT it has three settings each setting is to do with the tracking weight now if your turntable has a turning dial it should have tracking weights marked on it, you then set it to the tracking force you are using. Putting it simply The antiskating setting is the tracking weight. someone here should be able to put it into better words but I did my best.
Date Posted: 08 Aug 2022 at 8:45pm
Vincenzo,2 gram downforce is 20mN, so for your TT the thread should be on either the 2nd (up to 19mN downforce) or 3rd (20mN or more) groove of the bias stub. It will need some listening tests to see which is best. The inner grooves are most sensitive to the bias setting.
Good Luck and Happy listening, Ian
Posted By: Vincenzo
Date Posted: 09 Aug 2022 at 6:51am
Hello, basically, you are telling me to set the anti-skating strength to the same extent as the tracking one, therefore more or less also 2 gr.
Date Posted: 09 Aug 2022 at 7:14am
That's right. Based on Ian's observations I think you'd using the first or second notch on the anti-skate.
Posted By: Vincenzo
Date Posted: 11 Aug 2022 at 2:56pm
Fantastic, across the entire sound spectrum. The anti-skating left it in the first notch near the arm. Compared to the Quintet it seems less warm, brighter and the background noise of the record less evident. I like.
Date Posted: 11 Aug 2022 at 3:17pm
Glad to hear you like your new cartridge. After some hours of use it should improve, might be worth some fine tuning of downforce and bias setting after 10 or 20 hours of use.
Happy Listening Ian
Date Posted: 11 Aug 2022 at 6:17pm
Great stuff!
