Yet another new member
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5474
Printed Date: 27 Mar 2026 at 5:07am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Yet another new member
Posted By: PhonoPhan
Subject: Yet another new member
Date Posted: 01 Jun 2022 at 12:42am
Hi All, I recently signed up for this forum, which I discovered while researching Graham Slee’s phono preamps. I am contemplating an Accession MM for a somewhat unique application. I have one turntable (Clearaudio Concept with an Ortofon 2M black cartridge) which I want to serve as a vinyl front end for two systems: a big rig featuring Dali Helicon floorstanders powered by a Pass Labs amp and a 300B SET integrated amp powering small, highly efficient monitors TBD. My thought is I can wire the variable output from Accession to the Pass Labs amp and the fixed out to the 300B amp. If I want to listen to the big rig, I’ll keep 300B turned off. If I want to listen to the 300B, I will turn the volume pot all the way down (because the Pass Labs amp is always on). So will this work, or not? Will appreciate members thoughts on this. Meanwhile, I am enjoying browsing the forum topics and expect to be weighing in on some of them. Cheers! Dick
Date Posted: 01 Jun 2022 at 2:14am
Welcome aboard Dick.
I replied to your PM.
Date Posted: 01 Jun 2022 at 3:15pm
Welcome.
Date Posted: 01 Jun 2022 at 8:16pm
Thank you for joining us here, Dick. I haven't tried going direct from my AccMC or AccMM phonos to amps or active speakers so would interested in how you get on.
Date Posted: 01 Jun 2022 at 8:42pm
Welcome Dick.
Date Posted: 01 Jun 2022 at 10:25pm
PhonoPhan wrote:
Hi All, I recently signed up for this forum, which I discovered while researching Graham Slee’s phono preamps. I am contemplating an Accession MM for a somewhat unique application. I have one turntable (Clearaudio Concept with an Ortofon 2M black cartridge) which I want to serve as a vinyl front end for two systems: a big rig featuring Dali Helicon floorstanders powered by a Pass Labs amp and a 300B SET integrated amp powering small, highly efficient monitors TBD. My thought is I can wire the variable output from Accession to the Pass Labs amp and the fixed out to the 300B amp. If I want to listen to the big rig, I’ll keep 300B turned off. If I want to listen to the 300B, I will turn the volume pot all the way down (because the Pass Labs amp is always on). So will this work, or not? Will appreciate members thoughts on this. Meanwhile, I am enjoying browsing the forum topics and expect to be weighing in on some of them.Cheers! Dick |
With your Ortofon 2M black cartridge outputting 5.0mV, the Accession MM should produce about 0.595Vrms at full output, that should be able to drive with your amps well.
Date Posted: 01 Jun 2022 at 11:47pm
Thanks. I will certainly let you know how it works out. Dick
Date Posted: 13 Jun 2022 at 8:32pm
Now that I have had the Accession loaner for a few days, hooked up via the direct outs to a 300B integrated amplifier and the variable outs to a solid state PassLabs amplifier, I can declare a complete success. The sound on both systems is superb. Played through the 300B with small, highly efficient monitors, there is a tremendous separation of instruments and voices, both are tight and articulate, with a wonderful sense of space and depth. Played through the PassLabs with full range speakers, I am hearing bass that I had never heard before. The clarity across the frequency spectrum is astonishing. Two thumbs up!
