newbie needs advice
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5457
Printed Date: 19 Apr 2024 at 1:58am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: newbie needs advice
Posted By: notwelshyet
Subject: newbie needs advice
Date Posted: 28 Apr 2022 at 6:44pm
Good evening all
Hope you are keeping well - having completed my integrated amp (leema tucana anniversary) and speaker (focal kanta 1) shopping, to go with my technics 1210gr i now need a phono amp and interconnects - my initial thoughts are the reflex m (i have MM cartridge), with Lautus interconnects - any thoughts? Also, the lautus interconnects are 1.5m long at minimum - can i get them shorter, my kit isn't that far apart - or do they need to be that long?
many thanks for any help/advice - i am completely new to this, and i will be honest i started off with a budget for all components that ended up to be less than i spent on the speakers - my wife calls it specification drift!
charlie
Date Posted: 28 Apr 2022 at 8:02pm
The Reflex M is great. If you want to try before buying, you can look into the loaner program. I would email using the contact form to inquire about shorter cables. Maybe take a measurement and figure out what length you need.
Date Posted: 28 Apr 2022 at 8:03pm
Hi Charlie and welcome. The Reflex M is a very good starting point, I have one myself but I have the PSU1 power supply as for the cable (Lautus) it has to be that minimum length to work at it's best "I think I'm correct in saying that" I'm sure if I'm not someone will put me right. You don't say what cartridge your using? This may help others here in giving you advice.
Date Posted: 29 Apr 2022 at 7:49am
good morning and thanks both
i currently have an AT VM750SH cartridge on a totally unmodified technics 1210gr.
I shall see if i can get a loan reflex
many regards
Date Posted: 29 Apr 2022 at 10:24am
The loan program is great way of hearing the product in your own system and surroundings, I used it to try out new cables as I wonted more bass for my headphone listening, It was not a big improvement but enough to make me happy and the end result was I made the purchase. All the loan costs you is P&P
Date Posted: 29 Apr 2022 at 3:02pm
If it's 1m you need the Cusat50 phono cable is great.
Date Posted: 03 May 2022 at 6:23am
Thanks all - had a couple of very helpful chats with John and an Accession is winging it's way to me now, as well as a CuSat50 interconnect and some spatia cables.. looking forward to the indulgence of just sitting and listening to my collection for the next few days!
Date Posted: 03 May 2022 at 6:01pm
Charlie. Going all out on the cable front, Should make for an interesting listening session with the Accession.
Date Posted: 03 May 2022 at 7:24pm
Agreed. it's good to hear the music right. Happy listening!
Date Posted: 10 May 2022 at 4:12am
Speaking (typing) as a lover of the Tucana and current owner of Kanta No2, the Accession is a worthy companion. I owned the Relfex M for some time before purchasing an Accession, which I felt was easily justified but the Kanta’s revealing nature. I could hear the difference reasonably well on my older PMC Twenty5.22, but the buckets of extra resolution offered from the Kanta was a shock. Enjoy the listening, Mick.
Date Posted: 13 May 2022 at 7:45am
Hi Mick, i would have loved the kanta 2s, but my room just wasn't big enough - and my wife said the yellow ones were too banana like to be allowed! The kantas are amazing, they even make my old roksan amp sound good (with the in built phono amp), but when i put the turntable through the accession and then the leema the change is amazing. clarity is brilliant, and it actually made me feel that the sound is taller vertically - the soundstage is just much bigger. even an ignoramus like me can tell that this amp - and the cables - work brilliantly.
thanks to all for advice and a special mention to John who has the patience of a saint and has helped me tremendously...
Date Posted: 23 Jun 2022 at 9:43am
just as an update, i've had my accession now for a couple of weeks - bought the enigma psu at the same time - utterly brilliant... i am spending hours every day just listening, great way to relax.
many thanks to John again..
------------- technics 1210gr, leema tucana anniversary, focal kanta 1s, accession mm
Date Posted: 23 Jun 2022 at 6:08pm
notwelshyet wrote:
just as an update, ... i am spending hours every day just listening, great way to relax.
Another happy GS owner.
