How important is the damping factor when choosing an amplifier? For example, will an amplifier with a damping factor of 400 sound better than one rated at 100 or 200?
I got the impression that a high damping factor is desirable, but what i am curious to learn is what audible differences one will be able to detect between two amplifiers that have low and high damping factors, respectively.
I was reading the entry on damping factor on Wikipedia and became slightly confused about the matter.
http://en.wikipedia.org/wiki/Damping_factor - http://en.wikipedia.org/wiki/Damping_factor
It says:
"A high damping factor (which requires low output impedance at the
amplifier output) very rapidly damps unwanted cone movements induced by
the mechanical resonance of the speaker, acting as the equivalent of a
'brake' on the voice coil motion (just as a short circuit across the
terminals of a rotary electrical generator will make it very hard to
turn). It is generally, though not universally, thought that tighter
control of voice coil motion is desirable as it is believed to
contribute to better quality sound.
A high damping factor indicates that an amplifier will have greater
control over the movement of the speaker cone, particularly in the bass
region near the resonant frequency of the driver's mechanical resonance."
But then further down it says:
"...high "damping factor" values do not, by themselves, say very
much about the quality of a system; most modern amplifiers have them,
but vary in quality even so. Given the controversy that has long
surrounded the use of feedback, some extend their distaste for negative
feedback amplifier designs (and so a high damping factor) as a mark of
poor quality. For them, such high values imply a high level of NFB in
the amplifier. Tube amplifiers typically have much lower feedback ratios, and in
any case almost always have output transformers which limit how low the
output impedance can be. Their lower damping factors are one of the
reasons many audiophiles prefer tube amplifiers."
This is confusing. First it is implied that a high damping factor is desirable and then it says some people prefer valve amplifiers because they have lower damping factors??? So is a high damping factor good or bad?
Graham, I hope you can shed some light on this matter.
