Phone in plug in
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5292
Printed Date: 27 Mar 2026 at 2:27am
Topic: Phone in plug in
Posted By: Bradders
Subject: Phone in plug in
Date Posted: 20 Sep 2021 at 4:38pm
Hi there I was just wondering if it’s alright to have my headphones plugged into the to the solo ultra linear with it switched out so they are not being used .
Will they be have any electrical power to them in this mode.
Date Posted: 20 Sep 2021 at 6:44pm
Not sure about the power question, but my Audio Technicas have been plugged into solo for the last couple of years switched out so I hopes its ok, no smoke yet.  Smile
Date Posted: 20 Sep 2021 at 6:56pm
A good point you bring up. I always leave my headphones plugged in to the Solo and when I wont to listen I switch the amp over to INPUT (from MUTE) about an hour before, as I find the headphones sound better warmed up so I'm guessing no power is getting to them.
Posted By: discrete badger
Date Posted: 20 Sep 2021 at 8:28pm
Based on my experience of constant headphones connection and constant power up for years on two Solos, absolutely fine.
In theory there will be at least a very small signal across the headphones whenever the amp is powered up, whatever the position of the volume control and source switch. Probably not enough to have any effect though.
