Accession MM o MC
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5282
Printed Date: 29 Mar 2024 at 9:39am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Accession MM o MC
Posted By: Vincenzo
Subject: Accession MM o MC
Date Posted: 13 Sep 2021 at 11:52am
Hi, I own the Refex M with Elevator EXP for an Ortofon Quintet black cartridge and wanted to upgrade to the Accession. My question is whether acoustically the Accession MC is the same as the MM plus Elevator EXP or does something change in the sonic aspect? Thanks.
------------- Amp. Musical Fidelity M6si,Turntables VPI Scout Signature, Cartridges Ortofon Cadenza Bronze, Graham Slee Accession MC, Speakers Triangle Esprit Antal Ez, Cables VAN DEN HUL D-502 Hybrid,ATLAS Equator
Date Posted: 13 Sep 2021 at 6:50pm
Hi Vincenzo, I think the Accession MC is better sounding so I recommend that. Keeping your Elevator to use with an Accession M would give more flexibility if you wanted future options.
Posted By: Vincenzo
Date Posted: 13 Sep 2021 at 8:14pm
Was there any comparative evidence on this?
Date Posted: 13 Sep 2021 at 9:20pm
Yes, I own an Elevator EXP, and Accession (M), and an Accession MC. I did the comparisons with the loan AccMC, using the PSU1 Beta now known as PSU1 Enigma, listening to a range of records I own from blues, rock, pop, jazz, classical.
To be fair my Elevator EXP is not a standard or stock model as I added a 4n7 capacitor to the input loading of each channel. Even so the AccMC was better IMO.
My respectful advice is to borrow an AccMC and an Acc M on the loan scheme and compare them in your own system. That is always the best way for you to decide which option you prefer, Vincenzo.
Date Posted: 14 Sep 2021 at 7:25am
I borrowed the loan scheme Accession C a while ago to compare with the Reflex M/Elevator and Accession M/Elevator & the lasting impression was of more 'vivid' images and greater detail with the AccC than with the other combinations. This was with the standard PSU1, as it was pre-Enigma.
Removing the AccC & going back was noticeable - adjusting back to the slightly less defined sound took a little time, but the sound is nonetheless still very satisfying.
If it helps - my intention is to go for the AccC at some stage, having heard what it can do but Jon's advice to borrow them is the best way to find out.
Posted By: Vincenzo
Date Posted: 14 Sep 2021 at 4:03pm
Hello, thank you for the advice, I was wondering if there was a way to trade or sell the Reflex M and the Elevator EXP in order to buy the Accession MC.
Date Posted: 15 Sep 2021 at 8:26am
Good luck with sale of your Reflex M & Elevator on the forum Vicenzo.
There are places in England that will buy your hifi if you want to sell quickly - although you are based in Italy & Brexit has added complications they are worth considering. http://https://2ndhandhifi.co.uk/sell/ - http://https://2ndhandhifi.co.uk/sell/
