Speaker recommendations for Proprius?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5213
Topic: Speaker recommendations for Proprius?
Posted By: RichardSwan
Subject: Speaker recommendations for Proprius?
Date Posted: 03 May 2021 at 7:15pm
Hi there,
Grateful for advice on potential speakers to get....
I have a pretty high end Origin Live Turntable system, going through the GS Accession MC phono amp and the Solo Ultra Linear Headphone amp.  I have been super-impressed.  I have now taken the step of ordering a pair of Proprius, based on numerous recommendations.  I assume I will come out of the variable output on the Accession MC, straight into the Proprius, and use the volume pot on the Accession?
I'm looking for some speaker recommendations.  I have a very healthy budget, a few thousand quid, but would (of course) be happy only spending an appropriate sum :)
I understand power rating is only 25WPC into 8 ohms, but John has kindly said that the amps will drive pretty much anything.  I have my eyes on Kef Reference 1's on stands, maybe Sonos Faber Sonetto V's.
I'm keen on floor or stand mounts.  I'm in a room that is 18' x 18' with a 10' ceiling height.  Speakers would be circa 8 to 10 feet apart.
Grateful for any suggestions you might have.
best, Richard
Origin Live Sovereign, Origin Live Enterprise (12"), Lyra Kleos, Accession MC, Solo Ultra Linear DE, Proprius x 2
Date Posted: 03 May 2021 at 7:40pm
What do you have now?
My advice would be to find a friendly dealer, audition some speakers, and try the shortlisted ones in your own home.
Date Posted: 03 May 2021 at 7:46pm
As the KEF Reference 1 are £6.5k, is the recommendation a few £k, or similar price to the Reference 1?
Posted By: Godra
Date Posted: 03 May 2021 at 10:45pm
If you are already interested in KEF, I would take a look at Tannoy or Fyne speakers also.
Clearaudio Performance DC with Clarify tonearm + Virtuoso V2, Tannoy Legacy Eaton, Accession MM and BAT VK300Xse
Date Posted: 03 May 2021 at 10:51pm
reference fidelity components?
I know nothing, but I’ve read good things.
Date Posted: 03 May 2021 at 11:04pm
Take a look at this
https://amcoustics.com/tools/amroc?l=18&w=18&h=10&ft=true&r60=0.6 - https://amcoustics.com/tools/amroc?l=18&w=18&h=10&ft=true&r60=0.6
Posted By: Sylvain
Date Posted: 04 May 2021 at 6:18am
My feelings and experience cause me to believe that  ''Wattage'  is only relevant for Volume but also dynamics and transients. I use Proprius with Focal ARIA 936 metre tall 5 drivers @92db but also to it's Focal 726 stand mounted in a 4 x5 metres lounge and flat surface ceiling and corners to be redecorated with battens.
25 watts and CD 2.5 output requires attenuation but Elton John Rock Saturday night and Sarah Vaughn and Harry Bellafonte  or Harry Connick Jnr sing true natural and with depth. However, I have three different sets of speaker cables to add a small but good tweak to output.
Posted By: Bags
Date Posted: 04 May 2021 at 8:29am
I'd get the amps first and get used to them with your current speakers before looking to replace your speakers.
In my recent experience with a loaner scheme pair and three different pairs of speakers I'd say that while they could drive most speakers they sounded best with more efficient speakers so I'd steer clear of less efficient options.
Date Posted: 04 May 2021 at 9:28am
My concern is your square room. It cost me dearly to realise just how much influence room shape has on the tonal response. I was aware of acoustics but didn't think it would have such an impact as it did. I'd had an extension built to the workshop, but I'd lost one foot off the width due to the construction method I'd asked for. The extension was to be my office where amongst other things, I could audition my work. I could not audition a thing! The almost equal height to width caused boom. My posh new office ended up being workshop space, and the workshop got partitioned off to become my office. Being a foot wider with the ceiling height six inches lower solved the boom problem. I used the Amroc calculator to find where to place the partition wall, which gave a room ratio that fitted the "Bolt" area and the "Bonello" response. I went considerably further than most would do to absorb the room mode pressure zones using BBC absorber homemade clones. The room modes are still audible but not as prominent.
There is little that can be done in a domestic situation, and I'm not suggesting you go to the extremes I had to go to. However, if your aim is for good sound, which I think it is, I would seriously look at ways to improve your acoustics. I would be thinking about losing three feet off one floor area dimension - perhaps by fitting something like this?
If you can't, then I'd go for a bass reflex whose port resonates anywhere but the strong frequencies shown on the calculator, somewhere between 70 and 90 Hz.
Date Posted: 04 May 2021 at 2:59pm
Hi
  I run Accession MC direct to Proprius to drive a pair of PMC Twenty5.22. It’s fabulous! I agree with Graham about the square room, I’m sorry - just a month ago a I moved from a 6m x 6m room to a 8m x 5m rectangle. Holy cow! My system sounds a great deal better in every way.
A friend built a false wall in a square room (made it a storage space) so as to have a rectangle for his hifi and it looks great. Cheaper I suspect than upgrading components or speakers to achieve the same improvement.
Good luck!
Date Posted: 04 May 2021 at 5:48pm
Date Posted: 04 May 2021 at 5:51pm
Thanks for your response. I don’t have a particularly good dealer near me, so I’m trying to short list based on recommendations and other factors and then sort out how to audition. The KEF Reference 1’s would be right at the top end of budget. Half that price would be better, but I would spend £6.5k if it was clear that they were my speaker of choice.
Date Posted: 04 May 2021 at 5:54pm
Thanks for this. I will investigate....
Date Posted: 04 May 2021 at 5:59pm
What do you mean by more efficient and less efficient....? Where do my suggested speakers fit within this criteria?
Date Posted: 04 May 2021 at 6:09pm
Thanks, Graham. I don’t have much flexibility to change room dimensions, so it seems I will have to try to audition a selection in the space I have, and then choose..... There might be an option that I can explore.... What would be your opinion if the room was 18’ x 13’6” x 10’ high, with the speakers along the long wall?
Date Posted: 04 May 2021 at 6:16pm
A
Originally posted by Aussie Mick Aussie Mick wrote:
Hi
Good luck!
Thanks very much, Mick.... I had no idea that room shape could make such a huge difference....
Those PMC Twenty5 22i speakers could be a real contender and at a great price point....Smile
Posted By: Bags
Date Posted: 04 May 2021 at 7:59pm
To answer the question what do I mean by efficient, two of my pairs of speakers are resistive 8 ohm loads, a typical valve speaker if you will.  The third pair are a more like a real world 6 ohm load.  They typically respond well to biamping (4x Proprius rather than 2 is a consideration on your budget.)  The less resistive pair sounded good whereas the more resistive pairs really sounded great.
Of the resistive pairs one was 93db efficient whereas one was only 88db efficient.  As expected, the 93db speakers were louder at any given volume setting, but both were dynamic like real music is.
Bear in mind that other folk on this forum use speakers that are less resistive with propriuses and are very happy with them. I'm sure Graham also tested them with a wide variety of speakers in development..  However, to my ears the more resistive load allowed the amps to perform at their considerable best.
Date Posted: 04 May 2021 at 8:37pm
Good points well made. I liked Bags' earlier advice about using the new amps with your existing speakers. That allows you to start from a sound you know, then experiment with speaker positions and where you sit. Graham is right as I've written many times... room dimensions are the starting point, I have a nearly square room and it took some figuring out on the positions for hifi and furniture, then I added some bass traps.
If it helps I have used a lot of different speakers with my Proprius amps in my listening room. I suggest it will be about matching your preferred sound and the speakers you try.
Date Posted: 04 May 2021 at 9:11pm
Much better!
With speakers set apart 7 feet you can afford them to be 3 feet out into the room, and you would be 3 foot 6 away from the 'back wall'. Just try and keep it symmetrical.
See for yourself  https://amcoustics.com/tools/amroc?l=18&w=13.5&h=10&ft=true&r60=0.6 - https://amcoustics.com/tools/amroc?l=18&w=13.5&h=10&ft=true&r60=0.6
Posted By: Bags
Date Posted: 24 Jul 2021 at 2:26pm
My Proprii are installed and running in and I'll leave it a few weeks with my current speakers before deciding on something new.
That said, I picked up a pair of one owner Kef Q35s with broken terminals for a tenner on eBay.  Having replaced the speaker terminals I tried them on the front of my Proprii, and I have to say they were a fine investment for a tenner.  They are pretty lightweight so some additional mass should help but I have a fine 3d soundstage, natural sounding bass, excellent mid range and better treble than I was expecting.  A lot of fun for a tenner and I'll make a few bob on them if I decide to sell them on.
Date Posted: 24 Jul 2021 at 6:00pm
I went for PMC Twenty5 23i in the end….. Lovely…..
Date Posted: 24 Jul 2021 at 8:14pm
Mark Audio drivers in cardboard boxes produces high quality sound. Recommended.
Posted By: Sylvain
Date Posted: 25 Jul 2021 at 12:23pm
Proprius for the concept of ''Mono amps'' attached close to speaker diagram
Proprius for the balance of all frequencies and of all my 4 amps ...the lead Vocals of Harry Belafonte or Sarah Vaughn or '''' seen'' leading in front
Proprius for the natural tone that reflect the instrument timbre
But speakers of 88 db or above and larger boxes which relies on natural air acoustic without the large flare port to accentuate bass.
My BW620 of  1985 or Focal Choral or ARIA had never been driven better to produce music ...
Date Posted: 25 Jul 2021 at 1:43pm
Very happy listening Richard. I've heard the Twenty5 23 speakers in a demo room and they were very good. I believe the changes in the 23i model will have taken it some way forward.
