One off PCB
Category: DIY AUDIO
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5208
Printed Date: 19 Apr 2024 at 1:03am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: One off PCB
Posted By: peterb
Subject: One off PCB
Date Posted: 29 Apr 2021 at 5:28pm
What would be the easiest way for me to make one, small (100 x 80 mm) PCB ?My CAD program is a bit too engineering orientated but I guess there must some free simple PCB drafting software out there, any recommendations? (I made one using Veroboard but it took up too much space!)
Thanks
Date Posted: 29 Apr 2021 at 5:49pm
I did the Accession board using this.
https://www.electronic-software-shop.com/lng/en/electronic-software/sprint-layout-60.html%20 - https://www.electronic-software-shop.com/lng/en/electronic-software/sprint-layout-60.html
It isn't free, but it isn't expensive at all. It lets you work without all the faff of doing a schematic.
You could try ABL to make you the board from the Gerber and Excellon files.
https://www.ablcircuits.co.uk/
Posted By: peterb
Date Posted: 29 Apr 2021 at 7:48pm
Thanks Graham.I was wondering about 'Fritzing' but I will explore your suggestions first.
Posted By: gwebster
Date Posted: 29 Apr 2021 at 8:33pm
Kicad is the one I use. It's freeware and supported by, amongst others, CERN.
I used to use Eagle but moved away from it once my son introduced me to Kicad. Have a look at it - https://kicad.org/ - https://kicad.org/
I've done several boards using Kicad now, both traditional through-hole ones and surface mount ones. I now prefer to build SMD. All it needs is a good soldering iron, good solder (0.5mm dia), lots of flux and decent magnifier glasses.
------------- Inspire Apollo tt, O/L modded RB250, Ortofon 2M Black, Slee Different Approach inspired Phono, Putzeys Pre, Cusat, Raspberry Pi/Volumio, Bitzie, Self Load Invariant Power, Acoustic Energy AE509s
Posted By: peterb
Date Posted: 29 Apr 2021 at 9:31pm
I saw Kicad listed on a top ten list, tempting. At the moment I only need one fairly simple board for a low current ±15V PSU and don't have any other projects in the pipeline.
Posted By: gwebster
Date Posted: 30 Apr 2021 at 10:41am
PM me - I have spare boards left over from building my +-15V (+/-17V actually) board. Minimum order qty from my Chinese PCB house was 10 @ $5 for the 10. The shipping costed more than the boards - not sure how they actually make any money on these!
If it matters, they are 100 x 80 in size (corresponds to max size for that price)
