Downloads
Category: Music
Forum Name: Music!
Forum Description: Because it's #AllAboutTheMusic
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5206
Printed Date: 23 Apr 2024 at 6:08pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Downloads
Subject: Downloads
Date Posted: 17 Apr 2021 at 4:25pm
Yesterday I got the new album by LONDON GRAMMAR on vinyl and it came with a download code so today I tried to redeem it. No luck the 1st time I tried so I tried again and again the 3rd time it said that the code has been used, but I don't have the download so I'm not happy. This is not the 1st time this as happened to me and when I connect the company by Email I some times get a reply and a new way of doing it But not always, but when I do I still don't get my download I then just give up. Has anyone else had this trouble. Now this may have been covered before (may be by me) but I could not find it so SORRY if it has.
Date Posted: 20 Apr 2021 at 3:06pm
lfc jon wrote:
Yesterday I got the new album by LONDON GRAMMAR on vinyl and it came with a download code so today I tried to redeem it. No luck the 1st time I tried so I tried again and again the 3rd time it said that the code has been used, but I don't have the download so I'm not happy.This is not the 1st time this as happened to me and when I connect the company by Email I some times get a reply and a new way of doing it But not always, but when I do I still don't get my download I then just give up. Has anyone else had this trouble. Now this may have been covered before (may be by me) but I could not find it so SORRY if it has. |
I've had issues with download codes when I buy an album a year or more after it came out. Typically download codes are only going to work for a limited amount of time, because the record company doesn't want to pay for the server space.
It sounds like you're having a technical issue though. Is your internet connection spotty by chance? Before I had my old router swapped for a new one by my ISP, I had constant problems with random WIFI dropouts. If you redeem a code, and your connection drops out during the process, you typically will run out of attempts after 1 or 2 tries because of the way things are set up on the label end.
If the artist has their own website, maybe try contacting them instead of the label.
IME indie labels are much more responsive when it comes to issues like this vs. the majors. I've even had indie labels give me FLAC downloads simply by showing them I purchased the record, even if was never meant to come with a download code in the first place.
Date Posted: 20 Apr 2021 at 6:52pm
David your probable right on this occasion, I do have internet problems at the moment. You are also right about indie label I don't seem to have as many problems with them and also they tend to give you the better quality downloads too. there is one label I have had a lot of records off (can't remember off hand) that even store what you have had off them so that if you lose your music you can download it again, I think it's only once more but it's better than nothing. IT seems to me that the small indie labels appreciate you more for spending that bit extra on vinyl records. I have even had a CD put in with the RECORDS that I have bought too which I would prefer more than a download, again indie labels. Putting a CD with the Vinyl to me says how cheap CDs must be to manufacture.
Date Posted: 20 Apr 2021 at 7:11pm
lfc jon wrote:
Davidyour probable right on this occasion, I do have internet problems at the moment. You are also right about indie label I don't seem to have as many problems with them and also they tend to give you the better quality downloads too. there is one label I have had a lot of records off (can't remember off hand) that even store what you have had off them so that if you lose your music you can download it again, I think it's only once more but it's better than nothing. IT seems to me that the small indie labels appreciate you more for spending that bit extra on vinyl records. I have even had a CD put in with the RECORDS that I have bought too which I would prefer more than a download, again indie labels. Putting a CD with the Vinyl to me says how cheap CDs must be to manufacture. |
I would talk to your ISP about troubleshooting the internet issues. Over here my building was wired for fiber optic connection, so we switched to that service from a cable modem service. The problem was the routers they initially gave everyone were total junk, and half-crap rigged with an adapter box to work with fiber optic. After complaining regularly to the ISP I eventually figured out they were giving new customers a new router specifically designed for fiber. I demanded one of those routers, but it was a pain getting them to agree. Everything works so much better now it's not even funny.
RE: CDs as extras with records, I do appreciate that and wish more labels would do it. How much it costs to make a CD depends on the quantity. The more manufactured, the cheaper they are to make. Of course I am talking about making the physical product only, not mastering, graphic design, extra special packaging, or royalties/licensing paid to the rights holder or artists. All those other costs will far exceed the cost of making a plastic and metal disc.
Anyway, one thing you may notice is that some newer CDs by small scale indie artists aren't glass mastered CDs at all - they are professionally duplicated CDRs. Sometimes certain labels will hide this by using a black surface at the bottom or even a silver surface instead of the blue-greenish dye. One of my friends does the pro-CDR thing for his limited releases which are usually done in copies of 25-50.
Making vinyl is a lot more expensive, and he's doing that now also. However, it's not the cost of pressing each record that drives things up, it's every part of the process that you need to do in order to get each record pressed. Mastering, lacquer or DMM cutting, plating, jackets, etc. all drive up the cost before we get to royalties or license fees. The actual raw cost of just pressing each record is only a few dollars. However, you can't make a record without all that other stuff.
That's why it will cost you around $3,000 on the low end to get say 200-250 single LPs made before a single cent of royalties/licensing fees are paid. This is a bare bones deal. Add in a "name" mastering engineer, a real lacquer cut instead of assembly line DMM, tip-on jackets, etc. and the cost quickly goes up. Better plants also charge more than the budget places.
Date Posted: 20 Apr 2021 at 7:15pm
Me again David Just read my Emails and the label have asked me to send them Pictures of the album cover and download code so I have, so I'm hoping this issue will be sorted
Date Posted: 20 Apr 2021 at 7:52pm
David My internet issue is down to the router, I am waiting for my internet provider to send me a new one but if they are anything like my old provider this may take a while. Over here in UK company's are quick to take your money but not so quick to sort out any issues you have. I am not saying they are all like because when I had a problem with my mobile phone last year the company sorted it all out and sent me a new phone with in less than 48hrs, They may not be the cheapest but when I have had problems they have been quick to sort it out that's why I have stayed with them for many many years, Not that I have had many problems with their phones or service
Posted By: jwatson
Date Posted: 22 Apr 2021 at 8:03am
If problems persist, it may also be worth trying a different browser. For myself, Firefox tends to work for most sites but I've had a couple of occasions where I've had to switch to Chrome. You may also want to allow popups for the site in question.
------------- "I bought some more old vinyl today 'cos old vinyl won't ever let you down" Majestic DAC -> {Proprius -> Tannoy Stirling | Solo UL -> HD820}
Date Posted: 22 Apr 2021 at 8:10pm
Thank You James I'll take your advice if it persists but I'll wait till I get the new router 1st. I am sure this is my problem.
Date Posted: 23 Apr 2021 at 10:30am
If we are talking UMG websites I have had issues with Web browsers , I tend to use opera but I have to switch to a Microsoft browser lots of time for download codes as I have have problems logging in and download otherwise.
------------- Steve
Date Posted: 11 Dec 2021 at 4:15pm
Today I went and collected my albums I had ordered. Here is a big up for "Merge Records" The "Torres" album came with a download. First of all it was easy to find where to redeem it and second They gave you the choice of mp3 or FLAC now you don't always get this. All music I have had from this label has come with a choice of music file, pity the all don't.
Posted By: TimW
Date Posted: 11 Dec 2021 at 9:06pm
I second that “big up” for Merge. Great label. They’ve released two of my favourite albums: “In the Aeroplane Over The Sea” by Neutral Milk Hotel and “69 Love Songs” by The Magnetic Fields, which has, as suggested by the title, 69 songs on it and they’re about love.
------------- L*nn LP12, Jelco 750D, AT440MLb / Technics 1200 MKII (Various Carts) / GS Gram Amp 2 SE / Audiolab and Arcam Amplification / Mission 752 Freedom / Dynaudio Audience 42
Date Posted: 12 Dec 2021 at 12:31pm
My mate last night was also seconding this and said it's nice to have a choice but he did say it would be nice if they gave the artwork with it but maybe I'm asking too much. there is another label that gives you a choice (I think it's Bandcamp) and they store your music downloads so if you lose the file you can download it again for free. The only thing I think Merge Records could improve on is giving a good inner sleeve. there is one other thing all the vinyl I have had off them have had vary little surface noise and been super flat no warping. So their QC is vary good (I've been talking about this on another post on this forum) It's nice that some labels do go the extra mile when you buy vinyl off them it's a pity they all don't.
Date Posted: 29 Jun 2022 at 7:32pm
Not happy with Jagjaguwar as a album I just got came with a download code and not for the first time I have had problems with downloading it, all of the last times I tried I've just given up. I did once or twice get in contact with them about it but still no luck, I have sent them another email but I'm not holding my breath as the last time they told me the album was too new try again later which I did & still no download so I gave up. If I don't get my download this time I wont ever try again and I will send them another email and this time it won't be so polite.
Date Posted: 29 Jun 2022 at 8:29pm
Well it didn't take them long to get back to me that's one good thing, followed their instructions in the email and clicked on the link and still no download so now another email off to them. This will be the last time I will try downloading from them.
Date Posted: 30 Jun 2022 at 8:29pm
I put a post on another forum about my problem with downloading from Jagjaguwar and I got quite a few replies, most it seems have the same problem. One person said that he had to change his internet browser as it didn't matter what he did he couldn't get it to work, even then he had problems but did sort it out in the end, he suggested to me to try Mozilla Firefox. This seems extreme.
Date Posted: 01 Jul 2022 at 12:20pm
ServerBaboon wrote:
If we are talking UMG websites I have had issues with Web browsers , I tend to use opera but I have to switch to a Microsoft browser lots of time for download codes as I have have problems logging in and download otherwise. |
I'm using Microsoft browser but last night I downloaded opera and today I tried again to lownload still no luck and there is nothing wrong with my internet connection now.
Posted By: Bonzo
Date Posted: 02 Jul 2022 at 8:48am
I've seen loads of those download this album using this link/code flyers usually in a new album, but I've never bothered.I've always wondered what I was missing out on by not using the code. Having read through this thread it looks like all I've missed out on is a lot of frustration and disappointment, I'll carry on not bothering .
Date Posted: 02 Jul 2022 at 9:32am
Bonzo wrote:
I've always wondered what I was missing out on by not using the code. Having read through this thread it looks like all I've missed out on is a lot of frustration and disappointment, I'll carry on not bothering . |
It is only jagjaguwar that I have problems with most others I've been successful, one I had to have to set an account for my download but they keep a record of what you have downloaded so if you lose the music file you can download it again, I think for up to three times which is vary good plus it was a high quality FLAC file. Not all are so good some you only get mp3 but again most I have expereience with give a good quality download, One album I have by Warpaint even put the album cover with the file and gave you the choice of mp3, WAV or FLAC.
