Interconnect from Accession M to Amp
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=5090
Printed Date: 28 Jan 2021 at 6:35am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Interconnect from Accession M to Amp
Posted By: mitmat2
Subject: Interconnect from Accession M to Amp
Date Posted: 16 Nov 2020 at 6:42pm
Hi all ,I am trying to get an opinion as to whether or not a set of LAUTUS RCA Interconnects would increase the bass from my system. I am only looking for a slight increase without losing any detail. My system is as listed below in my signature At this time from Accession M to my Amp (Arcam A49) I am using an Atlas Hyper Duo and Hyper 2 speaker cable. If they would then I hope I can have a loan pair. Looking forward to replies.
Thanks
------------- Martin, Gyro deck, SME309,2M Black, Accession mm, Arcam fmj A49, Audiovector SR1 Arrete.
Date Posted: 17 Nov 2020 at 5:51pm
If you PM John_C he can help. My experience is a better cable lets the music through unaltered if that helps.
Posted By: mitmat2
Date Posted: 17 Nov 2020 at 7:46pm
Hi Jon, thanks for your reply, I phoned John and he recons the Lautus cables should work. He is sending me a loan pair to try. I will post the outcome when I have them.
Posted By: Philmack
Date Posted: 18 Nov 2020 at 9:51pm
Hi there,I am actually using the Lautus cables from the Accession M to my power amp, I also have the Atlas Hyper Duo interconnects and I did a comparison. The Lautus are better all round IMO, not that the Atlas cables are bad, the Lautus are just better.
Phil
Posted By: mitmat2
Date Posted: 19 Nov 2020 at 8:50am
Thanks Phil, That's the answer I was hoping for. The Atlas cable is good but I need to bring out the bass more than the Atlas can. I am going to ask John C if I can also have a loan of a PSU1 Enigma to hear the difference to my PSU1, Hopefully he can send both the Lautus & Enigma together.
Martin
Date Posted: 19 Nov 2020 at 10:34pm
Sensible move Martin. From personal experience (and expense with no regrets!) I think you'll soon be a happy customer with one or two new products to enjoy in the years to come.
Posted By: mitmat2
Date Posted: 20 Nov 2020 at 11:17am
Thanks Jon, I have spoken to John C and he is going to send me both loan Items together. I will post the outcome.
