[/QUOTE]
I wish I had an easy answer for you, but I don't. I would say if you are unsure of what model to buy, the loaner program is the best way to figure out what will work best for you. Now, IIRC the loaner Reflex I tried did not have a mono switch (maybe I'm misremembering?) but when I bought mine I went for that option. I can tell you the mono switch works very well and has made an improvement in my mono playback for both old and new mono records. So if you have mono records, definitely get a mono switch no matter what model you buy.
RE: the power supply - I started using my Reflex with the standard "green" supply. It sounds fine with that, but I think the unit was really designed to work with the PSU-1. When I did do the upgrade, I noted that the noise floor was lower and everything sounded better overall. My power is pretty good here, but I do have the occasional problem. Thankfully, not recently. I think this is the area where you have to assess your current budget. If you can't swing the PSU-1 now, no big deal. You can always get it later. That said it's cheaper to buy everything at once to avoid incurring multiple shipping charges. [/QUOTE]
DT999 wrote:
Hi Frank
I also previously had a Rega Fono/Elex-R with my P3. I initially trialed a Reflex-M to compare; you can see my review here:
https://www.hifisystemcomponents.com/forum/another-new-member_topic4849_page3.html - https://www.hifisystemcomponents.com/forum/another-new-member_topic4849_page3.html
The loaner Reflex I had did not have a mono switch, so when I ordered my new Reflex I also got it fitted with a mono switch. I don't have a lot of mono recordings, but the cost of the switch is really not very much so I though I might as well get it. It does improve mono record play back.
I only ever trialed with the PSU-1 so can not comment on the green power supply.
I would say that the best thing to do is try the different models in your own system at home.
Cheers Derek
Cheers both - very helpful responses! It sounds like a mono switch is a complete no-brainer whatever I opt for - and that the loaner programme is the way to go to assess system synergies and the PSU-1 effect - so that's what I'll do. Derek - your review of the Reflex M + PSU-1 was very informative - that might be my loaner benchmark in starting out, though I know the Era Gold V has its partisans as well! Many thanks again - will add my own thoughts when I'm properly "in the GS loop"!
Frank
