Pairing with Reflex C
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4921
Printed Date: 27 Mar 2026 at 4:28am
Topic: Pairing with Reflex C
Posted By: humanhands
Subject: Pairing with Reflex C
Date Posted: 03 May 2020 at 1:34pm
Hi all
I’m taking the leap from the world of MM to MC, and will be upgrading from the truly magnificent V Era Gold to the Reflex C. I've just acquired a Kuzma Stabi S with a Van Den Hul MC One Special with low hours. Does anybody know how this cartridge will pair with the Reflex C?
One last question: does it make a difference what input impedance I choose in the checkout — 100 Ω or 1k Ω ?
Many thanks for your time
Paul
Date Posted: 03 May 2020 at 2:20pm
Originally posted by humanhands humanhands wrote:
Hi all
Paul
https://www.analogueseduction.net/cartridges2/van-den-hul-mc-one-special-mc-moving-coil-cartridge.html - https://www.analogueseduction.net/cartridges2/van-den-hul-mc-one-special-mc-moving-coil-cartridge.html
Is that your cart at the link above? It looks like the manufacturer recommends 200 ohms loading for this cartridge. If it were me I would think you would want the 1K ohm version of the Reflex C, then use loading plugs to bring it down to 200 ohms.
Date Posted: 03 May 2020 at 4:42pm
Yes, that's the one. Thanks for the advice!
