A new member
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4900
Topic: A new member
Posted By: maronetone
Subject: A new member
Date Posted: 10 Apr 2020 at 12:50pm
Hi all,
I've just joined up to what looks like a great forum and have just joined. I'm looking for a phono stage for my turntable and came across Graham Slee. I like the look of your phono stages and would be interested in anything you may suggest.
I have a Nottingham Analogue Ace Spacedeck turntable with an Ace Spacedeck arm. I'm using an Audio Note MM IQ2 cartridge.
I was looking at the Graham Amp 2 SE or Era Gold V....any comments?
Thanks
Date Posted: 10 Apr 2020 at 1:22pm
Hello again,
Thought I'd give a bit more background. I've never had a separate phono stage before and it's something which is new to me. I'm using the onboard Quad 34 phono stage at the moment. I'd be grateful for any advice. Thank you..
Date Posted: 10 Apr 2020 at 1:24pm
welcome Anthony. With that kit you’ve got to consider the Accession. I would suggest you request a home loan of both the Accession M and the Reflex M.
Date Posted: 10 Apr 2020 at 1:47pm
Thanks for that, Ifor. They certainly both look like great phono stages and you obviously think that they'd give the best result. I have to say, I did consider the Reflex M. I do love my turntable set up, and even through the onboard phono stage on the Quad 34 it sounds lovely. If I'm able to home loan that would be really good. Is the home loan system still operating at the moment? Thanks again. Tony
Date Posted: 10 Apr 2020 at 1:54pm
I think it is. Hunt out “John C” in the members’ list and send him a private message.
The Accession didn’t exist when I bought my Reflex M, which is the best bit of HiFi kit I’ve ever purchased.
Date Posted: 10 Apr 2020 at 2:21pm
Thanks Ifor, I will do that. All the best. Tony
Posted By: kgilroy
Date Posted: 10 Apr 2020 at 3:47pm
I will just second the Accession recommendation. I had an ERA V Gold for 7 years and loved it but just upgraded to an Accession MM. Definitely worth it.
Keith
Marantz TT-15S1, Maestro V2, Accession MM, Icon Audio Stereo 40 Mk lll, Wharfedale Jade 3.
Mac Mini, BitPerfect, Dynaudio Xeo2
Marantz SA-15S1, Apple TV, Cambridge CXA60, B&W DM2000, REL Sub
Date Posted: 10 Apr 2020 at 5:17pm
Thanks Keith, that's really helpful to hear. My upgrade to a Nottingham Analogue Ace Spacedeck was a massive step for me and the phono stage choice is part of that. I see that you are running a valve amp but you've not opted for a valve phono stage, like the Audion or similar....the Accession is much different? Thanks again. Tony
Posted By: kgilroy
Date Posted: 10 Apr 2020 at 7:51pm
Hi Tony. I like my valve amp a lot but perhaps a valve phono stage would be a step too far. Not tried one to be honest. I have become a big fan of Graham Slee design philosophy and it does it for me.
I've had the Accession for just over a week so about half way through burn-in. You will have noted on the website a lot of discussion about burn-in. They like about 300 hours initially and then just left powered on 24/7 thereafter.
Keith
Date Posted: 10 Apr 2020 at 9:37pm
Hi Keith, yes, I think I know what you mean. I have got some thinking to do regarding Accession and Reflex M. I will try and take advantage of the loaning arrangement to try them both out. Thanks very much for your input. All the best. Tony
Date Posted: 11 Apr 2020 at 7:54pm
With more time at home I've been re-ripping some of my record collection, replacing Elevator and Revelation M rips with AccMC recordings into the same ADC recorder and I'm hearing more of the music. The Accession is more money but I think it is a big step up if you want to take it.
Date Posted: 11 Apr 2020 at 10:08pm
Hi Jon,
Thanks for that. I had a long conversation with John C today and hopefully will have a chance to compare and contrast the Reflex M and Accession....the more I hear, the more I'm looking forward to it!!
Thanks again. Tony
