headphone amp not working
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4872
Printed Date: 29 Mar 2024 at 2:20pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: headphone amp not working
Subject: headphone amp not working
Date Posted: 06 Feb 2020 at 8:33pm
I've just got myself a musical fidelity amp got it for the tape out/fix line out connectors But I am not getting any sound out of my headphone amp GS Solo with PSU1 I have connected the dealer three times now and i'm not getting any joy they say they will get back to me but don't they have just sent me a Email for a review. That's not going to be a good one I know the headphone amp works has i'm using it direct from the CD and turntable not happy
Date Posted: 06 Feb 2020 at 8:51pm
You're not switching to any tape loop are you?
Date Posted: 06 Feb 2020 at 9:09pm
Conventional tape out (tape rec or rec out) is on all the time. It outputs whatever source you have selected - or should do.
On some of the double switched type amps with separate source and tape out selectors you have to be sure to select the source you're playing.
If this is now handled by software-switching it might need to be set-up a particular way to work.
Usually this is only a problem using amps with DIN sockets for tape, where the outputs are on pins 1 and 4 instead of the common 3 and 5 wired cables.
Let's hope we can help you get it working one way or another.
Date Posted: 07 Feb 2020 at 3:06pm
1st of all Thank you Graham Slee it was the double switch type but in RCA form I plugged it in the Tape rec socket and i'm up running Should of come here 1st Now HAPPY
