Solo ULDE amp
Forum Name: UK Loaner Program
Forum Description: A members only service in the UK
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4427
Printed Date: 27 Mar 2026 at 2:55am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Solo ULDE amp
Posted By: gbr2004uk
Subject: Solo ULDE amp
Date Posted: 11 Feb 2018 at 2:31pm
I've sent a private message to Fatmangolf but I'd like to put some reasons here as to why I want to try out the highly-acclaimed Solo Ultra Linear Diamond Edition Headphone Amplifier (Solo ULDE).
I got the Voyager in 2009 and then the Bitzie + Lautus cable in 2013. I've been extremely happy with the Bitzie which has been in continuous use, night and day, ever since.
I've been a Sennheiser headphone user for many years and a few years ago got the HD700 (I know it has a mixed press) and I kept the HD650 for plugging into a Yamaha Clavinova -- it's still a great phone in my ears.
The HD700 with the Bitzie is great for most of my purposes, giving a very clear and precise sound. But recently I've noticed that with a lot of CD recordings of string music (as in quartet) there's quite a harshness in the higher-mid to high frequencies. This doesn't occur at all with, for instance, recorded piano music.
Some of this might be me and my age-related high-frequency loss (not severe, but I have to use hearing aids to watch television and for example at meetings if someone across the room doesn't articulate clearly enough).
I emailed Graham, who to my delight replied with a quite long and detailed explanation, and with particular reference to my query about the Solo.
Basically I had been advised by A.N.Other (whom I'd unwisely consulted) to get a tube (valve) amp and I did quite a bit of amateur research around the web before deciding that at my stage of the game I didn't want to have to muck around replacing burnt out valves, or trying whole sets of different valves — I just want to listen to the music (mostly classical and jazz). And in addition, I was put off by some reports of the 'hum' (noise floor) that you can get with some tube amps. (Plus the hours you might have to spend chasing up the cause and cure.) If I were still a young man, then maybe ...
So I came back to where I should, on past experience, have gone first — here!
If I can borrow the Solo, I'm fairly sure I'll know in half a day whether it does for me what I'm hoping it will do. I'll try it primarily of course with the HD700, but also give it a run on the HD650 (connected to the Bitzie DAC, with Lautus cable).
And the rest of the fortnight will confirm initial impressions.
All best Brian Milton Keynes, UK
Date Posted: 11 Feb 2018 at 2:48pm
Hi Brian - I'm sure the ULDE will do the business for you! Let us know how you get on . . .
Date Posted: 11 Feb 2018 at 2:50pm
Sure will, many thanks Bob.
Date Posted: 12 Feb 2018 at 7:38am
@Brian I have just replied to your PM and hope you'll like the sound of the Solo ULDE with your Sennheisers as much as I do mine.
Date Posted: 12 Feb 2018 at 2:56pm
Thanks Jon, I've caught up with it and done the necessary! I've also asked if I need a special cable to connect it to the Bitzie (perhaps it's included in the trial package?) all best Brian
------------- Voyager 2009, Bitzie+Lautus cable 2013, Sennheiser HD700 & 650, Yamaha Clavinova
Date Posted: 13 Feb 2018 at 8:13am
Have replied in PM and on your other thread.
Posted By: vinylmad
Date Posted: 31 Dec 2020 at 11:39pm
Thanks to (Graham and) John C, I have a Solo ULDE on loan.
I wasn't sure whether to begin a new thread for my query, but seeing an appropriately-named albeit old topic is already here I hope Brian and others won't regard this a hijack!
Everything is sounding just fine, very fine in fact, but I'd like confirmation on the volume control settings. Notes accompanying the unit explain that for low-impedance 'phones, to expect the control to be in the 5-to-1 o'clock range, depending on input level, and 11-to-5 o'clock for high-impedance 'phones. With both my Sennheiser HD600 (300 Ohms) and Final E5000 IEMs (14 Ohms) I'm getting plenty of volume at around the 9 o'clock position. Is this anything to be concerned about? My source output level (from the manual) is 2.1V.
------------- Colin G.
Rega RP8/Ania Pro/Aria/Elicit-R, Neat Motive SX2, REL S2, Chord Epic RCA/Speaker; Innuos Zenith Mk.3, Oppo UDP-205, Chord Shawline USB; Solo ULDE (loaned/returned), HD600; EtherREGEN;...
Date Posted: 01 Jan 2021 at 12:57pm
Ah! The magic of the ULDE
Your source, however, does seem a tad hot, but that's what the volume control is for. Personally, I'd want to find a way of taming the 2.1V to something more like 0.7V. Our overworked John C is good at attenuators.
Posted By: vinylmad
Date Posted: 01 Jan 2021 at 2:13pm
I've never been sure of how to interpret these claimed output levels from line gear. 2.1V is what my Oppo's manual says.
Line input sensitivity on my integrated amp is stated as 196mV into 10KOhms, for full rated output; and the same voltage is quoted for the Record Output, which is what the Solo ULDE is plugged into. At socially acceptable listening levels (thinking of the neighbours!) my amp's volume control is in the 10 - 12 o'clock range, depending on the recording, with me sitting about 8' from the speakers. Similar volume settings apply when using my phono pre-amp, where its rated line output is "only" one tenth of the Oppo.
Date Posted: 01 Jan 2021 at 4:01pm
Commiserations.
Perhaps manufacturers cannot afford or be bothered with the purchase of harmonized standards? After all, complying with standards is so "square." Why spend £100 to £300 on just one of the many standards applicable?
I must admit that I search the internet for bootlegged copies of standards, but eventually realize I have to do the right thing and buy a copy.
The problem is keeping up with the many reissues, but they tend to be much like earlier versions, just with new things added.
So IEC 1938 ratings should still be valid in IEC 61938:2019, and if so, these are the ratings we manufacturers should be aiming for.
Source device: output impedance 2.2k or less, capable of driving 22k.
Input device: Input impedance 22k or greater, ability to work with a source impedance of 2.2k or less.
Source rated output voltage: nominal: 0.5V RMS; minimum: 0.2V RMS (-8dB of max recording amplitude); maximum: 2V RMS ("full scale" level of a CD player. The maximum output of the maximum RMS transient)
Input device rated input voltage: nominal: 0.5V RMS; minimum: 0.2V RMS (as source) overload source EMF: equal or greater than 2.8V RMS (if an analogue output of a digital player)
Before IEC 1938 was DIN, and that specified "domestic line level" as -10dBu ref 0dBu = 1mW into 600 ohms, and that relied on some mathematical understanding (you'd expect electronics engineers to be capable of that).
1mW into 600 ohms is 775mV, and -10dB is 0.316 x 775 = 245mV.
But that was in the days before audio arrogance.
Posted By: Ernie
Date Posted: 01 Jan 2021 at 9:10pm
Hi Graham, Buy your standards from Estonia they’re only £20-30. BSi are a right rip off.
Date Posted: 02 Jan 2021 at 11:21am
Ernie wrote:
Hi Graham,Buy your standards from Estonia they’re only £20-30. BSi are a right rip off. |
Shhh!
Posted By: Lucabeer
Date Posted: 13 Jan 2021 at 10:46am
The Oppo has a volume regulation, from 0 to 100, for the analogue outputs! I have no problems with it at 100 with the ULDE (with very low impedance headphones...), but if you find that the output is too hot you could tame it by setting it at 50 or 70...
Date Posted: 13 Jan 2021 at 8:44pm
FWIW I have occasionally fed my Oppo 203 straight into my Solo ULDE and also found no problem with the levels.
Posted By: vinylmad
Date Posted: 14 Jan 2021 at 1:20pm
In practice, my Oppo's stereo RCA output, even at 100% (where I normally have it, as it best matches my phono stage's volume), is not unusually hot. My integrated amp has a good range of usable volume control and doesn't feel like its inputs are being over-driven. Even so, running the Oppo directly into the Solo, or the Solo running from the Record output of the integrated, at 9 - 10 o'clock the volume is plenty loud enough for me, into (300 Ohms) Senn' HD600/HD800.
If I did want to reduce the Oppo's output, I'm not sure if it would be done in the digital domain - by throwing bits away(?) hence less good, or (better) with analogue circuitry.
Posted By: Lucabeer
Date Posted: 14 Jan 2021 at 1:35pm
The Sabre in the oppo works at 32 bits internally... so there is no perceptible loss.
Anyway, if you don't hear clipping/saturation, simply keep it this way: the Solo is meant to work that way with high impedance headphones which have good sensitivity too.
Posted By: vinylmad
Date Posted: 14 Jan 2021 at 5:44pm
Sorry, I might have misunderstood. Would the Solo prefer it if I actually reduced the Oppo's output and aimed for a higher position on the volume control at my ideal listening level?
Date Posted: 14 Jan 2021 at 8:38pm
I think you'd prefer it.
(the Solo is just a machine)
Posted By: vinylmad
Date Posted: 20 Jan 2021 at 4:06pm
I've now returned the loaner Solo, so my thanks to John C. for organising that.
Having pulled up a dining chair next to my setup while I've been trying the Solo, I've realised a fundamental problem when sat in my easy chair some 4 metres away: my arm isn't long enough to adjust the volume! Not so much a problem for CD/digital sources as I can remote control my Oppo's line output. For vinyl it would be a different matter. How do other Solo users manage the volume with vinyl? Do they set it at the beginning of a side and leave it, or do they normally sit close enough to reach the control?
Date Posted: 20 Jan 2021 at 6:59pm
vinylmad I find that I only use a remote when playing a CD on the CD player (skipping tracks) As for volume I set that when I'm at my system. But i'm lucky my Solo is near where I sit, but I don't often adjust the volume. I think remotes have made us laze. They are good for somethings like changing channels on TVs, setting up a home cinema system or if you got multi room audio, and really how often are you going to alter the volume any way . If you are vinyl mad then you have to get up out of your chair to turn over the LP to play the other side so you can adjust the volume then. Ha Ha. Back to CDs do you find that when playing an album you tend to listen to the whole album when it's on vinyl but on CDs you skip tracks I find I do
Date Posted: 20 Jan 2021 at 11:10pm
I’m someone who doesn’t like the extra weight of a long cable run. It means I’m seated within touching distance of Solo and turntable. Mick.
Posted By: vinylmad
Date Posted: 21 Jan 2021 at 1:18am
Currently I need to use a headphone extension cable, as I won't be dragging a heavy armchair half way across the room from my speaker listening position to be next to my gear. (Nor do I fancy the idea of Bluetooth-ing, as even current generation Bluetooth looses fidelity.)
Mostly I listen to ripped CDs, playlists and Qobuz, with the occasional vinyl binge. CD albums (as rips) usually get played beginning-to-end, as do LPs. Playlists are often multi-artist/multi-album - so remote volume control is kind of a necessity with them.
It's a great shame that more headphone amps don't offer remote control for (at least) volume, and that there seems to be a general assumption in the market, that headphone listeners are within arm's reach of their amp. My internet searches have revealed only a couple of straight amps with this "feature", and prices are steep. I'm distinguishing these from a significant number with remote control that are built around a DAC. What Hi-Fi magazine did a review entitled "Best headphone amplifiers 2021...", and it's telling that of the thirteen devices they reviewed, only one didn't have a built-in DAC. And almost all were limited to digital-only inputs.
My Oppo already provides a respectable DAC, so if I did add a headphone amp/DAC I'd also want to have the option of running its DAC through my speakers (and so reduce the Oppo's up-time when not watching a DVD/Blu-ray). The issue then for me is that the more affordable ones don't provide a Line Out. It seems that I would need it to be a head amp/DAC/pre-amp...when all I want is a straight headphone amp with remote control.
Date Posted: 21 Jan 2021 at 10:53am
Have you considered a Bitzie?
Posted By: vinylmad
Date Posted: 21 Jan 2021 at 5:38pm
BackinBlack wrote:
Have you considered a Bitzie? | If it had an analogue input and remote control volume then I seriously would, so have I missed something?
Date Posted: 21 Jan 2021 at 7:49pm
A remote volume control with digital audio?
A streamer in a wired system via ethernet with stored media to ensure audio signal fidelity.
Streamer with audio operating system and a mobile phone in your hand with a complementary control app?
Posted By: vinylmad
Date Posted: 21 Jan 2021 at 8:43pm
Ash wrote:
A remote volume control with digital audio? | Remote volume control on the Solo would be exactly the kind of thing I'm looking for. Input connected to my integrated amp's 'Record Out', so that I get to listen to whatever sources (vinyl, CD, streamer) are connected to it.
