Frugel Horn Lite flat pack speaker kit
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4404
Topic: Frugel Horn Lite flat pack speaker kit
Subject: Frugel Horn Lite flat pack speaker kit
Date Posted: 20 Jan 2018 at 8:56am
Yesterday I collected a Frugel Horn Lite flat pack speaker kit from Stefan at http://www.kjfaudio.com" rel="nofollow - www.kjfaudio.com . These speakers will be for my daughter. I’ll let you know how I get on with build.
Date Posted: 21 Jan 2018 at 10:39am
Got the glue out yet, Ifor?
I'll be watching with interest. I found OSMO Polyx oil gives very good results for finishing, got mine from here: http://www.wood-finishes-direct.com/product/osmo-polyx-oil" rel="nofollow - http://www.wood-finishes-direct.com/product/osmo-polyx-oil
I put several coats on with a soft cloth and a light sand after each of the first 2 coats.
Happy building
Date Posted: 21 Jan 2018 at 11:13am
OSMO Polyx oil, agreed, good stuff, great finish without too much prep. Thumbs Up
Date Posted: 21 Jan 2018 at 12:38pm
I even used it on my "new" turntable, built on an IKEA Bamboo Breadboard.
Date Posted: 21 Jan 2018 at 1:52pm
Happy building
Not yet. Fitting a bath shower screen for the girl today and Caroline is using the dining table for upholstery. It’ll have to wait. Osmo Polyx Oil is already what I intend to finish them with. I recently used it on the dining room floorboards. The speakers will get a glossier finish.
Date Posted: 21 Jan 2018 at 1:54pm
That looks gorgeous Ian. Is it Rega based?
Date Posted: 21 Jan 2018 at 2:04pm
Thanks Ifor,
Yes, Rega 24V motor and TT PSU, stock Rega sub platter and bearing, Deco Audio twin belt pullley, 33 rpm engineering 24mm acrylic platter and Audiomods Classic arm built from Jeffs' kit.
I hope to upgrade the bearing and subplatter soon, I'll put it all in a thread soon.
Date Posted: 21 Jan 2018 at 2:51pm
Want a job? Wink
Date Posted: 21 Jan 2018 at 4:08pm
What's the pay like?Shocked
Date Posted: 21 Jan 2018 at 5:35pm
Erm... Embarrassed
Date Posted: 21 Jan 2018 at 6:39pm
That's a lovely TT, Ian! A prototype GSP one, bundled with GramDrive, Accession and a pair of Proprius for a turnkey system. Just add cartridge and speakers. Wink
Date Posted: 30 Jan 2018 at 6:54pm
Unboxing
Date Posted: 30 Jan 2018 at 6:57pm
Pre glue
All glued bar one side
Date Posted: 30 Jan 2018 at 6:59pm
Starting to cut and glue the felt.
Date Posted: 30 Jan 2018 at 7:55pm
Good progress Ifor. That looks like a very well machined flat pack kit. Did it go together without any fettling? Neatly cut felt too.
Happy sanding and varnishing
Date Posted: 30 Jan 2018 at 8:19pm
No fettling needed at all. It’s very well cut.
Date Posted: 30 Jan 2018 at 10:55pm
You're making this look very easy Ifor!
Date Posted: 30 Jan 2018 at 10:59pm
it really couldn’t be simpler. No clamps needed!
Date Posted: 30 Jan 2018 at 11:05pm
Even so the use of tape is clever for butting the edges up. When I was considering a kit or a self build I was going to use the old school glue and pin (thin nails) of my youthful speaker DIY.
Date Posted: 02 Feb 2018 at 7:04pm
Quick addition of top felt to both speakers this evening.
Posted By: Ernie
Date Posted: 03 Feb 2018 at 6:17am
Built the XL version last year . My ProAc SC1’s went on the Bay. Happy building.
Date Posted: 10 Feb 2018 at 12:14pm
1st coat of Osmo Polyx Oil applied around speaker binding posts, though you would hardly know it, prior to assembly.
Ready to stick the other side felts.
Stuck
Date Posted: 11 Feb 2018 at 6:39pm
i'm looking for help now.  My soldering skills are not good, but i have successfully built a couple of Genera phono stages.  How do i best set about attaching the internal speaker wire to the speaker binding posts?  I've been trying for a while and have, so far, been unsuccessful.  It's what i struggled with most when building the FH3s for the boy, but that time i managed.  i think i'm dealing withe thicker speaker cable this time.
Date Posted: 11 Feb 2018 at 8:02pm
I used Spatia wire, it's much thinner. For the thicker cable cut a few strands out so that you can thread it through the hole or make the hole bigger then solder. It will need a quite a bit of heat/time for the heavy brass part to get hot enough for the solder to flow. It's generally good practise to "tin" the parts first, ie apply a small amount of solder to coat each part before you bring them together, usually helps in getting the heat into the heavier part before you apply solder.
Date Posted: 11 Feb 2018 at 8:10pm
Thanks Ian. I used Spatia wire for the FH3s, which is probably why i’m Finding this so much more difficult. I’m not sure my soldering iron is man enough for it.
Date Posted: 11 Feb 2018 at 9:12pm
I would think that it would need at least a good 25W iron with a heavy chisel style bit. An alternative might be to use a solder tag type washer. Much easier to solder and fit as they are secured to the post with an extra nut.
Perhaps a bit late to say this, but I use 4mm Instrument sockets on speakers and terminate my speaker cables with BFA 4mm BANANA PLUGS Z-type Gold Plated Cable Connectors http://www.ebay.co.uk/itm/4-BFA-4mm-BANANA-PLUGS-Z-type-Gold-Plated-Hollow-Speaker-Cable-Connectors/302480843779?hash=item466d436403:g:kVIAAMXQ01tRUKwW" rel="nofollow - https://www.ebay.co.uk/itm/4-BFA-4mm-BANANA-PLUGS-Z-type-Gold-Plated-Hollow-Speaker-Cable-Connectors/302480843779?hash=item466d436403:g:kVIAAMXQ01tRUKwW
Date Posted: 12 Feb 2018 at 7:49am
I would carefully tease the stranded wire into two halves, twist and tin them separately.Tin the flat bits of your terminal, then run one wire through the hole in your terminal, solder it with a 25W iron to the terminal, and sold the two wire ends together.
Date Posted: 12 Feb 2018 at 9:24am
Thanks Ian and Jon. I just checked my iron; it’s 50W so should be OK. I’ll try to get a new bigger tip for it tomorrow.
Date Posted: 12 Feb 2018 at 6:36pm
I think I've found some Spatia left over from the FH3s.  Does this look right?  If so, can someone remind of the science as to why a cross sectional area of about one third is as good, or better (based on all the Spatia user experiences i've read) than what I've been trying to work with?
Date Posted: 12 Feb 2018 at 6:51pm
Hi Ifor,
The larger is I guess about 2.5mm2, good enough to carry up to 30 amps. To me this is overkill for a speaker rated at a few watts taking at most 2-3amps for full output.
I like to think of Spatia as being far more "agile" in its ability to carry the signal.
Whatever the reason, Spatia brings a significant improvement to the sound.
Date Posted: 12 Feb 2018 at 7:45pm
It’s actually 4mm2.
Date Posted: 12 Feb 2018 at 7:52pm
It’s actually 4mm2.
Best saved for monster subs in auto sound off systems!LOL
Date Posted: 12 Feb 2018 at 9:22pm
Saved by Spatia.  It's not pretty, but it's done.
Date Posted: 12 Feb 2018 at 10:08pm
In my experience the material and construction should be the answer...
Date Posted: 13 Feb 2018 at 8:14am
Well done Ifor.
Date Posted: 31 Mar 2018 at 8:56am
Ian, what type of soft cloth did you use? I’ve applied a fist coat with a brush, but don’t really want to buy a new brush for each coat. Cloths might be cheaper that Osmo Brush Cleaner.
Date Posted: 31 Mar 2018 at 9:52am
Hi Ifor,
I used some fine sponge for the first coat, then soft cotton cloth from old pillowcases/sheets. Make the cloth into a pad and apply in even light strokes in the same direction as the grain. For large areas I use the cloth wrapped around a sponge as it holds more liquid. If the surface is really smooth and finished with 600 grade AlOx "sandpaper", then just the cloth is OK, a light sanding with 600 grade after the first coat improves the depth of shine if you're really fussy!
Have fun
Date Posted: 31 Mar 2018 at 10:38am
Thanks. I didn’t know sandpaper that fine existed!
Posted By: Ernie
Date Posted: 31 Mar 2018 at 12:47pm
Is this a new design across the Frugal horn range? Only the sides look to be chamfered rather butted.
Made some XL’s about a year ago, sound excellent.
Date Posted: 31 Mar 2018 at 1:14pm
It is the newest of the FH range. Stefan at KJF Audio has cut them all this way now, but not yet shown in the pictures on his website. His idea is that no clamping is needed, just tape.
Date Posted: 31 Mar 2018 at 2:14pm
When it comes to refinishing car paint and metalwork 600 grade is quite coarse, finer than Aluminium Oxide, Silicon Carbide paper grade 1200, 1800 and even 2400 are available.
Posted By: Ernie
Date Posted: 31 Mar 2018 at 5:41pm
Must make some Lites then to see what they’re like. Must save the pi## about of veneering too.
Date Posted: 02 Apr 2018 at 8:50pm
NIce work. I get my super fine abrasives for polishing from that big river place and have some 3200 and it probably goes even higher!
Date Posted: 11 Apr 2018 at 7:29pm
I got a bit disheartened, because I messed up when putting the FH Lites together, having previously told you all how easy it was!  I didn't have them lined up as well as I should have, which came as a bit of a shock when I finally glued the the final side to each speaker.  I had a proud edge on each that needed sanding away and I haven't got the perfect finish that Stefan's new cuts are designed to produce.  Anyway, in the end I'm pleased enough and importantly so is the girl.  Job done!
Date Posted: 11 Apr 2018 at 7:32pm
Date Posted: 11 Apr 2018 at 7:34pm
Date Posted: 11 Apr 2018 at 9:45pm
They look really good to me Ifor. Thanks for sharing the photos and the experience, I've been there too!
