Phono buying advice
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4355
Printed Date: 27 Mar 2026 at 5:57am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Phono buying advice
Posted By: aurimas
Subject: Phono buying advice
Date Posted: 01 Nov 2017 at 2:01pm
Hi all,
I'm a new member though I've been around for a couple of weeks or so now going through the forum.
My current setup consists of the 2016 Rega Planar 2 with Rega Exact cartridge, Rega Fono Mini A2D preamp, Hegel H80 amp and Dali Rubicon 2 speakers.
The phono preamp is the next thing I am looking to upgrade as I think my system would benefit most with a better phono stage.
Now I am not entirely sure which would be the model I should go for so hopping you will kindly share your experience and suggestions and make it very easy for me :) Price is not that important but I would not want something that is a huge overkill for my setup.
Any input will be highly appreciated.
Thanks, Aurimas
Date Posted: 01 Nov 2017 at 8:56pm
Welcome, Aurimus. I’m sure you’ll get lots of helpful advice, including trying out the loan program. As for overkill, you’ve got a terrific turntable and a fantastic amp, so perhaps we could have some information on what you’d consider overkill? I suppose that a price point or a performance point? All the best, Mick.
Posted By: aurimas
Date Posted: 01 Nov 2017 at 9:41pm
Thanks Mick.
While I am happy with my TT I appreciate there are higher quality ones and so I thought that's what those higher end Phono preamps like Reflex M are for. I just assume they would not make a difference in my system. My definition of overkill would be something like: 'a preamp that would get bottlenecked by the rest of my system'. I'd be happy to be corrected if I'm wrong.
As for a loan, that indeed sounds fantastic but I had already tried contacting Jon a couple of weeks or so back but haven't heard from him yet. Perhaps he is busy. I just accepted loan option is off the table and therefore, I would go with recommendations.
Thanks, Aurimas
Date Posted: 02 Nov 2017 at 7:11am
Just back. Reply sent to your PM regarding EGV loan.
Posted By: dillon
Date Posted: 14 Dec 2017 at 12:03am
Hiya
The Era Gold V is a stunning phono stage. It's raved about by no less than Micheal Fremer of Stereophile and Analog Planet Fame - he's the doyen of championing vinyl playback. I use a Revelation M which at heart is the Era Gold V. I had the same thoughts as you when I had a L*nn Axis front end. Not sure if it would expose the lesser front end and electronics. I can tell you my old Axis never sounded better and came close to the LP12. It sounded sublime.
And that is the key. It made the Axis perform better, not show up any weaknesses. It wasn't overkill at all...just showed how good that deck is. Since then, it has been paired with an L*nn LP12 and a VPI, where the performance was raised to another level. It now lives with my newly bought Nottingham Analogue Hyperspace with Space Arm- and performance is raised by miles yet again.
The moral of the story? The Era V will maximise whatever front end and electronics you use with it no matter the price range. As you keep improving your gear, you will need to keep improving the phono stage over and over. That's not really true value. I learnt the hard way, making too many sideways upgrade moves. Perhaps spend a little more now to save a lorra dosh later. It's forward thinking ( if you are able to, of course).
But that's just me, innit. A home loan will sort you out! It is your best friend.
Dil
------------- Nottingham Analogue/Origin Live/ PS Audio/ Burson Audio/GSP/ John Cadman
Posted By: aurimas
Date Posted: 14 Dec 2017 at 8:38pm
Hi Dil,
Yes - I really enjoyed having EGV on loan. In fact so much that straight after I ordered Reflex M and Spatia cables, and Cusat interconnects.
I went for Reflex since the difference in price is not that great. So far its been great! Very happy.
Now I'm being curious about Majestic DAC. I think I will need to drop Jon a line to see if its available for loan. Oh dear..
Regards, Aurimas
Date Posted: 14 Dec 2017 at 8:42pm
aurimas wrote:
Hi Dil,
Regards, Aurimas | I went straight in with the Reflex M and love it, but i’m now curious about the Accession. Majestic DAC and pair of Proprii followed. Very happy!
Posted By: dillon
Date Posted: 14 Dec 2017 at 8:46pm
Hi buddy
Arghhhh...sorry my bad! I meant the Reflex M of course! Not the EGV. Revelation is a Reflex based design so we are on the same page.
But the EGV is a top phono stage too!
