Spatia Links
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4321
Printed Date: 27 Mar 2026 at 2:30am
Topic: Spatia Links
Posted By: Gijo1977
Subject: Spatia Links
Date Posted: 10 Sep 2017 at 10:16am
Hi Team,
I have just received my spatia links, with the Spatia cables and Accession pre inbound. Tongue
Now the cheering has subsided Wink, I have an interesting problem.....
How do I best use the Spatia Links to connect the terminals on my speakers? Do the little arrows need to connect in a little loop? do they point away from the amp? should I connect the speaker cables to the tweeter terminals (or the woofer?)......
Thanks for the smart answers to what I feel may be a bit of a dopey question.
Dan
Date Posted: 10 Sep 2017 at 10:37am
Experiment and report back Smile
Posted By: Gijo1977
Date Posted: 10 Sep 2017 at 11:28am
OK, Will do :)
Date Posted: 10 Sep 2017 at 11:47am
The arrows on Spatia cables point from amp to speaker. If it helps I found running the cables to the HF teminals on the speaker and then jumpering from those to the LF terminals sounded best, arrow on links from LF to HF.
Date Posted: 10 Sep 2017 at 3:09pm
I would like to point out I had nothing to do with the 'development' of the Spatia links. I was unable to believe that such a short length of wire could make one jot of difference. But around 6 years ago John and Leo reported to work and swapped out my short pieces of tri-rated wire. I was stunned, and they just stood there and laughed at me for doubting it. Embarrassed
Date Posted: 10 Sep 2017 at 3:59pm
I do mine like this, arrows mark the flow of signal
Red cable to the bass/mid terminal and the black to the treble, with the jumpers arranged accordingly, bass to treble on the red (or +) side of the crossover, treble to bass on the black (or -) side.
With my speakers, I prefer this to any other way of connecting and even to bi-wiring.
Date Posted: 10 Sep 2017 at 5:19pm
My cable supplier also recommended switching the cables so one is to each connection (high/low), never tried as mine are separate positive and negative cables but common thinking.
Posted By: Gijo1977
Date Posted: 27 Sep 2017 at 11:41am
Hey Guys, Thanks for the feedback.
I finally have now sat down and done some testing.... WOW, what a difference it made to just adjust which terminal the speaker cable is connected to.
I have connected mine with the positive cable connected to the HF terminal, spatia links arrows towards the LF posts and then the negative (black) speaker cable coming out of the LF post to the Amp.
The sound is now MUCH clearer and there seems to be the feeling of 'space' around instruments and voices sound like they are in a space... not too sure how to describe it? The best thing I heard was a trumpet which was in behind the Little River Band, and I could hear the musician playing, not just the trumpet sounding.
I am supper chuffed now. My speaker cables are A1, my Accession is A1 and burned in beautifully, the RP6/Dynavector 10x5 can sing, and my NAD Hybrid AMP seems to be playing really nicely with the rest of the team!
Great work on the gear Graham, John, Leo and the rest of the team there in the UK. Also a shout out to the Aussie loaner program for giving me the chance to listen to nearly all of the gear prior to purchase.
Dan
Date Posted: 27 Sep 2017 at 10:22pm
Dave, I've tried this and the opposite (+ to HF first, - to LF first). I prefer your suggestion, thank you.
