Forum Discount Terms & Conditions
Forum Name: Claiming your member's discount
Forum Description: Club Loyal Activity Discount for all posting members
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=4198
Topic: Forum Discount Terms & Conditions
Subject: Forum Discount Terms & Conditions
Date Posted: 20 Apr 2017 at 7:02pm
Membership Discount Coupon Codes you can use at the https://www.HiFiSystemComponents.com" rel="nofollow - HiFiSystemComponents.com shopping cart.
These discount coupon codes are only available to contributing members. If they are used by anybody else the purchase will be cancelled!
Discount is only available to contributing forum members. Therefore please contribute good stuff and make this a great forum!
Check your star rating status by looking at any of your posts - it's under your username to the left of your post. Even if you look at an old post it will show your current star rating.
1 star 5% - code: CLAD-level-1
2 star 7.5% - code: CLAD-level-2
3 star or above 10% - code: CLAD-level-3
Enter your coupon code when you're all done adding to your cart. If you change or update your order you will have to re-enter your coupon! Please ensure your coupon code is entered properly (copy and paste) and the product description line/s update/s to say you've used the coupon.
Need to change your delivery address? Use our contact form here: https://www.hifisystemcomponents.com/services/contact-us.html" rel="nofollow - https://www.hifisystemcomponents.com/services/contact-us.html and let us know.
