A very reasonable 280,000 Euros . .
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2902
Printed Date: 27 Mar 2026 at 5:06am
Topic: A very reasonable 280,000 Euros . .
Subject: A very reasonable 280,000 Euros . .
Date Posted: 08 May 2016 at 10:15am
It comes in 9 cases, and STILL has belt drive - for "controlled slippage", naturally . . . Confused
https://youtu.be/3C84geXA8LU - https://youtu.be/3C84geXA8LU
Date Posted: 08 May 2016 at 2:19pm
I've had to cancel my order for a Rolls Royce Phantom as I can't really afford both Unhappy
Date Posted: 08 May 2016 at 5:27pm
Oh come on . . .
Not another wannabe a millionaire "it's really worth 5 years equivalent of a top-end salary because it's not mass produced" BS.
He can I suppose retire after selling just 4 or 5 of those brutes, and enter the Hi-Fi hall of fame.
What about those catering for normal folk eh?
Date Posted: 08 May 2016 at 5:42pm
..but this one has a tangential arm, the ability to mount 5 cartridges and separate cabinet for the power supply. Not sure about the W.A.F. though... Confused
Posted By: JamesD
Date Posted: 08 May 2016 at 5:45pm
I've not got a problem with the well off spending excessive and perhaps vulgar amounts of their money on over the top items just to be different and better than their neighbours. That is, if the money filters down the chain to pay the average person their wages. But I doubt that is the case in this example.
Anyhow, in my area Phantoms are ten-a-penny so I'm off to buy my Aston Martin Lagonda Taraf!
Aren't ears brilliant
Posted By: hedgehog@35
Date Posted: 08 May 2016 at 6:42pm
I was wondering if could put a  couple of caterpillar tracks on it and rename it the "Tiger", but that might be politically incorrect.
Russell
Date Posted: 08 May 2016 at 6:57pm
That looks like the very butch cousin of Henry The Hoover . . Shocked
Date Posted: 08 May 2016 at 7:47pm
I bet it costs less than quarter of a million and it looks a lot more useful (but not for playing records).
Shame about the vacant look on its face LOL
Date Posted: 15 May 2016 at 12:01pm
The madness continues . . .
https://www.youtube.com/watch?v=WfJZzbb7eGw - https://www.youtube.com/watch?v=WfJZzbb7eGw
120,00 (Euros?) for a tangential tonearm. (Slightly less for the TT it sits on . . )
Date Posted: 15 May 2016 at 12:07pm
Didn't they do that sort of thing in jukeboxes for a lot less money?
Date Posted: 15 May 2016 at 12:35pm
Meanwhile, some lucky sod has their Jaguar F-type R parked outside my flat. A stunning piece of engineering that cost less than... a tonearm!! Confused
Date Posted: 15 May 2016 at 12:40pm
I've a couple of Technics parallel trackers off eBay that work perfectly well. Less than £150 the pair.
"High end" kit just get more and more outlandish. It wouldn't be quite so bad if there was some genuine innovative advance that filtered down to stuff us mere mortals could buy . . .
Date Posted: 15 May 2016 at 9:35pm
Hardly 'cheap' but nevertheless, this looks interesting....
http://hifipig.com/affordable-tangential-tonearm-from-clearaudio/ - http://hifipig.com/affordable-tangential-tonearm-from-clearaudio/
Date Posted: 15 May 2016 at 11:42pm
That does look interesting! The only other tangential arm I've seen at a similar price looked like a bit of a Heath Robinson affair. This looks, well, like you'd expect from Clearaudio.
Date Posted: 16 May 2016 at 8:10am
All these air bearing arms have an ultra-thin signal wire allowing the arm to move freely, but what price shielding against EMF?
Date Posted: 16 May 2016 at 11:43am
In the unlikely event any of us have deep enough pockets and the inclination to try I suppose it is difficult to say Bob.
Interestingly my daughters 4g iPhone caused TV interference where as the same 3G does not. Unless a fault the RFI issues can only get worse?
Date Posted: 17 May 2016 at 8:50pm
A good point. Next we'll be lining our listening rooms with metal foil!
Date Posted: 17 May 2016 at 8:52pm
...or buying all our gear from companies like GSP Audio that take RFI seriously and invest in controlling it.
Date Posted: 17 May 2016 at 9:29pm
I now realise why so many companies don't worry about this too much. It's because the best solution lies elsewhere.
http://www.lessemf.com/personal.html#221 - Simple, Elegant, Mobile
Date Posted: 22 May 2016 at 6:50pm
Ah foil hats! Previously sold to protect the gullible from mind control programmes, ironic given the power of marketing used by the companies selling those products. Erm, that was the point you'd already made Dave!
Date Posted: 22 May 2016 at 8:38pm
Those garments are pointless. Confused The body would have to be fully encapsulated by the absorbing material for a shielding effect to be produced. Even then, what about the ultra high velocity/energy cosmic radiation that passes through the earth (and us) every second??
and even then, why would it make a difference??
Posted By: pankon
Date Posted: 22 May 2016 at 8:49pm
By the way, "Apolyt" seems to originate from the Greek word "απόλυτος", which means 'absolute'.
Perhaps, unimportant trivia... Smile
