5 Pin Din to phono cable.
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2514
Printed Date: 27 Mar 2026 at 6:08am
Topic: 5 Pin Din to phono cable.
Posted By: spinningdeck
Subject: 5 Pin Din to phono cable.
Date Posted: 05 Apr 2015 at 10:46am
Hi
Could anyone advise me as to which gsp stereo interconnect cable would be suitable to connect from a gsp phono stage, to Naim 5 pin din on my Naim 102 pre amp, without using separate 5pin din to phono adaptors.
Can phono to 5 pin din cable be custom made by gsp?
Hope this makes sense.....
Thanks
Date Posted: 05 Apr 2015 at 10:59am
Yes! And it often is. The best thing to do is call John C on 01909 568739 and discuss it.
Posted By: oldagetraveller
Date Posted: 05 Apr 2015 at 11:56am
I inquired about this some time ago and was told that the GSP cables could not be fitted into a DIN plug.
I resorted to using the DIN "breakout" with Cusat phono to phono where required with good effect. However, I would have preferred not to have used the "breakout".
http://www.gspaudio.co.uk/din-breakout.htm
