Creating CD's from FLAC files?
Category: Digital Audio
Forum Name: Music for digital repro
Forum Description: Your kind of music in digital format
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2491
Printed Date: 09 Jul 2020 at 9:10am
Topic: Creating CD's from FLAC files?
Posted By: earwiggo
Subject: Creating CD's from FLAC files?
Date Posted: 14 Mar 2015 at 9:58pm
Apologies if this has been covered on this forum before but I can not find it, but I ripped lots of cd's via DBPoweramp in FLAC, got rid of some of the actual cd's (or lost them!) and now want to copy some of the FLAC files back on to a re-writeable cd, to listen to in the car. Does anyone know of any software that would allow to let me do this, prefereably for free! I have a laptop with Windows 7 Home premium and it has a cd/dvd tray?Wink
Many thanks
...If only I knew that yesterday!
Date Posted: 14 Mar 2015 at 10:17pm
Hi Steve,
I've often used foobar2000 when burning audio CDs from FLAC files, it works very well. It's also a very versatile digital music player if you haven't got it already?
Date Posted: 14 Mar 2015 at 10:37pm
You could also try dbpoweramp companion program CDwriter. https://www.dbpoweramp.com/cdwriter.htm
Windows also has a built in CD writer.
I create a playlist of titles I want to burn to CD, decide on the format, and use dBpoweramp batch converter to put them in the required format - usually mp3 for use in the car; then burn a data disc, not CD audio as a data disc holds far more and can be read by most systems.
Hope this helps.
Posted By: tg
Date Posted: 15 Mar 2015 at 5:42am
There is a freeware burn software called https://www.ashampoo.com/en/usd/pin/7110/burning-software/Ashampoo-Burning-Studio-FREE - Ashampoo that will create a standard Audio CD from FLAC files.
I just tested it with a complete album which is now playing in my CD player.
Check the options or it will a:/ apply volume levelling, b:/ insert 2 second gaps between tracks.
The dBpoweramp CD writer only works with 32 bit versions of dBpoweramp.
Ians tip re mp3 is good if your car player can handle that.
Date Posted: 15 Mar 2015 at 10:32am
Tony, I've not yet made the move to 64 bit, my laptop works quicker than I can read or type! But seriously, I am aware that not all my current software is 64 bit compatible. CDwriter is an older program and no longer supported, but works fine. Foobar is probably the simplest and most reliable.
There is plenty of software to burn discs, important factors are getting all the id tags correct and ensuring that the software will use the format you want; eg iTunes and Windows will by default use their own formats rather than mp3 or flac. not all players will cope with Apple lossless.
I also prefer to use RW discs, we all make mistakes!
Date Posted: 15 Mar 2015 at 11:01am
Burner XP is free and very simple to use https://cdburnerxp.se/en/home - https://cdburnerxp.se/en/home
It also automatically decompresses FLAC files back to WAV during the process, so there's no other messing around with the files required.
Posted By: tg
Date Posted: 15 Mar 2015 at 11:21am
Ian, my post was for Steve who seemed to want something to make an audio CD from FLAC files directly, something which the software I indicated will do with no fuss - eg tell it you want an audio CD and show it the FLAC files and away it goes.
Foobar may well do that also, although I use it as a player I have never used it for burning discs.
I only included the mention of CDwriter being restricted to 32bit since he gave no indication which version of W7 he was using and it might have been an issue.
Since my thoughts were on creating a standard audio CD, the issues of tags and formats, which for a data CD are, as you say, worthy of consideration, were of no consequence.
FWIW I still use XP and Nero 6 for most burning as I still use other software that will not run on W7 and later, although I maintain a multiboot system and use W7 64 when I need the memory and hardware features that are not available in XP and just installed W10 preview on another disc to check it out.
Posted By: John C
Date Posted: 15 Mar 2015 at 12:42pm
You Could try EAC (Exact Audio Copy).
It's free and will convert, rip, burn, etc most files. You may need the cuesheet file but it works well. If you want best quality it does seem to work best decompressing to wav first.
EAC can also compare your files to an online database and help get rid of any glitches.
http://www.gspaudio.co.uk - Turntable and Headphone Audio
Date Posted: 15 Mar 2015 at 12:43pm
Before anyone picks me up on Foobars abilities, it doesn't burn CDs. What it does do is enable the construction of a folder/playlist that can be burnt to disc by whatever software you choose.
I think Steve was looking for something to create CDs for use in his car, in which case a data CD or DVD will hold far more music at acceptable compression levels for car use.
Date Posted: 15 Mar 2015 at 1:32pm
It may be an add-on I've got or maybe Foobar utilising some other burning program unbeknownst to me. But what I do is make a playlist no longer than 79 minutes (of FLACs or any other format) and then mark and select all the tracks, right click the selected tracks and then Convert > Write Audio CD.
