Acutex M412STR cartridge
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2463
Topic: Acutex M412STR cartridge
Subject: Acutex M412STR cartridge
Date Posted: 21 Feb 2015 at 2:04pm
Anyone who's bothered to read my ramblings in these pages will know I'm not averse to swapping cartridges on my TTs. For years I didn't bother - I had a GyroSE/Tecnoarm with a G1042 and it stayed on permanently. However when I switched over to Technics parallel trackers I bought p-mounts like they were going out of fashion (of course they had actually gone out of fashion, by then, so a lot of my purchases were new-old-stock). A chance came to get an Azden p-mount from Australia, which duly arrived only to be faulty. I never saw another one.
But recently a http://www.ebay.co.uk/itm/251802035889?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT - half-inch mount Acutex caught my eye on the 'Bay , selling for around £46 incl. shipping from Italy. Acutex were a US brand made as an OEM by Azden (who also made for Empire - which may explain the visual similarities between them and the Acutex). Azden themselves were previously Piezo.
After some searching around - and taken note that some buyers had got models with mis-aligned cantilevers - I decided to chance it. My 412 now has about 10 hours under it. With a weight of only 4gm, my arm wouldn't balance it out without a headshell weight.
The sound is big and bold. Plenty of detail with good integration across the frequency spectrum. HF percussion is well defined if sometimes lacking a little refinement; a world away from the filigree gossamer-spun treble some MCs have. Obviously, the low hours mean the sound will probably evolve, but unless it actually gets worse the Acutex is definitely a keeper, to be put into the swapping rotation with the MCs and other cartridges.
Date Posted: 21 Feb 2015 at 2:37pm
FYI: Acutex Tri Pole system:
Date Posted: 13 Nov 2015 at 3:47pm
This cartridge is still being sold on http://www.ebay.co.uk/itm/PUNTINA-ACUTEX-412-STR-PER-GIRADISCHI-INTROVABILE-STYLUS-FOR-TURNTABLE-NUOVA-/252163282321?hash=item3ab61a5591:g:g-cAAOSw5ZBWN7X1 - eBay (at the same low price).
Scroll down the listing and you'll see they've nicked my photo from this thread! Shocked
I suppose I should be flattered . . .  Approve
Posted By: Nigechap
Date Posted: 14 Nov 2015 at 2:43pm
Hi Bob, How did the sound settle after running in? I take it you would recomend a punt on one of these?
Nigel, Bristol U.K.
Date Posted: 14 Nov 2015 at 6:18pm
Hi Nigel. Yes I think this is worth a punt - if you don't like it you haven't spent a fortune. I haven't used mine in a while, but it was settling in nicely and getting a bit more refined. I'm just playing a rip I did with the Acutex of a John Dankworth big band album, and it's got super dynamics and impact. IMO, well worth the money. I think I'll swap out my current cart, now, and give the Acutex some more air time. Wink
If you do get one, let us know what you think. BTW spare stylii are unobtainable as far as I can tell. But if you like it a lot the price for a complete cartridge is a lot less than you'd pay for some MM replacement stylii, so buy another one!
Date Posted: 15 Nov 2015 at 10:36am
I've just swapped my Zyx R100 for the Acutex and am now thoroughly enjoying Dire Straits "Love Over Gold" with it. It's a totally unfair comparison of course - but the Acutex has a more forward presentation and sharper treble which tends toward being a bit splashy when compared with the R100.
Running some FLAC files in parallel with the Acutex has proved interesting - a rip with the R100 (from the 180gm remaster I'm currently playing), a CD issue, and an Ortofon OMP40 rip from my original 1980s LP. The OM40 was a considerably more expensive buy, but aside from a more refined treble doesn't offer a whole lot more than the Acutex (though I need to dig out the original LP for a proper comparison).
Date Posted: 15 Nov 2015 at 1:28pm
Hi, always good to hear someone who isn't following the herd!!
I have never hears of the Acutex though does look like some of the Empires from some time ago.
I was cautioned once they cartridge manufacturers manufactured to differing specs to suit the temperatures & humidity in certain regions of the world. not sure whether this is true to some high end or not if purchasing from other parts of the world though Europe probably safe?
Also I have some experience of some expensive MC and its tracking ability deteriorating after several years use (not wear related) - I have no idea how old the Acutex is but could this be an issue?
Richard
Date Posted: 02 Aug 2016 at 12:19pm
My Acutex has just made it to https://youtu.be/9HC2dwt7wqg - YouTube .
