Seeking knowledge
Forum Name: Amplification
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2431
Printed Date: 18 Apr 2024 at 1:15pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Seeking knowledge
Subject: Seeking knowledge
Date Posted: 21 Jan 2015 at 12:51pm
i currently have an integrated amplifier from a mainstream manufacturer. In the long term I expect I'll replace it with a Majestic and a pair of Proprii.
As some of you will know the amp has been doing its stuff running in a pair of Frugal Horn Mk3s and mostly low volume. Over the last few days when I turn the volume right down on the amp I can still hear it playing in the room next door. What's occurring?
Date Posted: 21 Jan 2015 at 2:02pm
ICL1P wrote:
...when I turn the volume right down on the amp I can still hear it playing in the room next door. What's occurring? |
It's OK Ifor, Mulder and Scully are already on the case... they're inside your Frugal Horns...
Date Posted: 21 Jan 2015 at 2:24pm
ICL1P wrote:
Over the last few days when I turn the volume right down on the amp I can still hear it playing in the room next door. What's occurring? |
Well each speaker cabinet is large (and heavy) so when directly coupled with the hard floor and indirectly coupled with the walls of the listening environment (all have a low frequency of resonance), the vibrations are synergistic (they summate) and depending on the damping properties of the materials, the vibrations would probably be audibly transmitted several metres even if the source is at low amplitude. Amplitude increases substantially close to or at resonance.
Is there any way you can decouple the speaker cabinets from the room further???
Date Posted: 21 Jan 2015 at 2:28pm
Ash, what I thought I said was that the amplifier volume control no longer silences the amplifier when turned all the way down.
Date Posted: 21 Jan 2015 at 2:32pm
Perhaps it really goes from 1 to 11, not 0 to 10?
That's interesting. What is the source of the signal going into the amplifier? So there's no other gain controls then?
Date Posted: 21 Jan 2015 at 2:39pm
I've tried different sources. TT through Reflex, TV and Pi through a DAC.
Posted By: Dave Friday
Date Posted: 21 Jan 2015 at 2:51pm
My guess is that the chassis end of the volume control has a dry joint,how are you with a test meter?
------------- lp12,oc9mk3,ca610p,krimson40watt pa,kef105.4
A limitation of the potentiometer travel, I guess. Another example of not being fully off is with the Bitzie. When its Alps volume pot is turned fully anticlockwise, there is still very very low level audio heard in the left channel of headphones (right channel was silent for me). It's not a blue velvet, which is the reason for the slight inbalance. Quite minor though. Although your issue isn't with one channel; it's both. All depends on how well matched it is for the input sizes it typically receives. At least with the TV input (analogue, I assume?), you can use the TV's own volume to solve the problem??
With a second volume control on the audio chain (I had Solo ULDE or Proprius for this), the resistance could then be altered such that no signal could be heard in either channel.
Date Posted: 21 Jan 2015 at 2:52pm
Ifor, (1) Have you been able to turn the volume all the way down to "0" before and have the actual sound go silent? If so and it does not now, the volume control may be dirty from lack of use at the "bottom" of travel. The volume control, if dirty, can be cleaned with control cleaner; sometimes a dirty control can be rotated back and forth (or up and down) many times to clear the debris.
(2) Do you have another sound system in the other room? a TV, radio, or other with the the same program material...
Here to help,
Date Posted: 21 Jan 2015 at 3:10pm
The Frugels are quite sensitive, so whilst less sensitive speakers perhaps don't receive enough drive for audible sound the Frugels will produce a more audible output. It is not uncommon for the zero of volume controls not to be a true zero as there may be either a mechanical end error or there may be not be absolutely zero resistance at the end of the potentiometer track, caused by dirt on the wiper. Sometimes a few vigourous end to end rotations of the control might clean it, otherwise don't worry unless the balance is significantly out.
Date Posted: 21 Jan 2015 at 3:33pm
Dave Friday wrote:
My guess is that the chassis end of the volume control has a dry joint,how are you with a test meter? | What's a test meter?
Date Posted: 21 Jan 2015 at 3:38pm
This just in from the manufacturer:
"Hello Ifor Phillips,
Thank you for your email. It sounds like the volume control may be faulty on your Amplifier wot we made. The cost of replacing the volume control and service is:
VOLUME CONTROL £ 24.40 plus VAT £ 4.88 TOTAL £29.28
LABOUR £ 162.00 for 1.5 hrs
carriage £ 26.40 UK only
The turnaround is usually 3-5 days"
I think I'll try some of the suggestions of forum members rather than fork out £162 for their labour. Thanks everyone.
Date Posted: 21 Jan 2015 at 3:46pm
A digital multimeter is what I think Dave is talking about. I got a good one from B&Q a few years back for about £20. Measures eletrical resistance, capacitance, potential difference/voltage, current flow, tests electrical continuity with a beep etc. Just plug the supplied rods/probes into the device and you can test various properties of PCBs or electronic components.
That amplifier is no longer under warranty I suppose then? I just feel that if that was a GSP product, you'd get better customer service than that...
I think it might be wise to investigate Dave's suggestion. If the metallic housing of the volume potentiometer is not properly "tied down", it might be left "floating" perhaps (?)
Date Posted: 21 Jan 2015 at 3:49pm
BackinBlack wrote:
The Frugels are quite sensitive |
Not with Mark Audio drivers fitted! The drive units are Alpair7 by the look of 'em
Date Posted: 21 Jan 2015 at 4:18pm
Ash wrote:
(It's not a blue velvet) |
Alps don't name their pots "Blue Velvet".
I believe you are referring to an Alps RK27. The Bitzie uses an Alps RK09. The plastic on the RK27 is blue and on the RK09 green. Neither use velvet.
Both (like most pots) have carbon elements deposited on SRBP by silk-screen process, and some end-resistance tolerance is allowed because of registration error. The larger the print, the smaller the percentage of error. The tolerances are given by Alps in their data sheets.
As most parts are riveted or pressed together there will be errors within tolerance here too.
Wipers (which output the set volume or level) are formed from thin metal sheet having spring properties such as phosphor or beryllium bronze. Each wiper is often divided into a number of wiper fingers to reduce the possibility of the track lifting - or bouncing - when operated quickly.
The AC27 wipers are divided into 5, and smaller diameter pots have wipers divided into 3 or 2 wiper fingers.
Over extended use, parts can wear out and the wipers can loose their springiness. DC offsets are not all that well tolerated on the RK27 (see data sheet). The elements may become loose and go slightly out of position, and this might be the cause of Ifor's problem.
If the "ground" connection was lost, that channel would most likely fail to full volume.
Date Posted: 21 Jan 2015 at 5:16pm
The earthy end of the volume controls could have a low resistance " dry joint". But as you say Graham the crimping at the ends of the carbon track could be poor/ loose. I have two 10 k pots that had that problem!
Posted By: marshmid
Date Posted: 21 Jan 2015 at 5:35pm
If the above suggestions do not solve the problem, I successfully replaced a faulty volume pot on a Cambridge P50 amplifier. Neither air or cleaning fluid improved it. The amp was worth next to nothing and the Alps pot was about £15 (maybe less) so it wasn't a difficult decision. There was a good clearance around the pot so the job was not difficult.
I do not have the soldering skill to build a Genera!
However, more modern amps may have limited clearance or be surface mounted?
Date Posted: 21 Jan 2015 at 6:02pm
It's certainly not a big enough problem to send it back to the manufacturer for repair. It is several years old and I bought it second hand. Sometime soon I'll open it up and have a look. With my new found confidence and skills, I might even be tempted to replace it myself as Marsh did.
Thanks everyone.
Date Posted: 21 Jan 2015 at 6:13pm
Date Posted: 22 Jan 2015 at 10:25pm
Does the crossover in the Spenders make the difference since there is non in the frugal?
------------- Steve
Date Posted: 22 Jan 2015 at 11:15pm
ServerBaboon wrote:
Does the crossover in the Spenders make the difference since there is non in the frugal? |
Good question! There's a whole load of bit's and pieces not manipulating the signal with the FH3/Alpair7.
Date Posted: 22 Jan 2015 at 11:41pm
Pass!
Date Posted: 23 Jan 2015 at 5:34pm
That's an idea about the crossover. And I wonder if the speakers' sensitivities are slightly different at 1 watt to the manufacturers' stated figures, or not linear in their response to reduced power input compared to the 1 watt levels. Or perhaps one of the speakers has more midrange output at lower levels?
