UK Voltage
Forum Name: Power Sources
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2354
Printed Date: 26 Mar 2026 at 10:54pm
Topic: UK Voltage
Subject: UK Voltage
Date Posted: 06 Oct 2014 at 3:57pm
I have noticed that recently the mains supply to my house seems to be creeping ever closer to the supposed max for the UK, 253V (230V AC +10% / -6%). Since I took this photo mid afternoon today, it has hit 250.9V
I found the following quotes on a UK University site. This is suggesting that equipment including hi-fi is inefficient in wasting energy/reducing life at higher than necessary voltages. Does this also have a detrimental effect on what we hear?
Also, listening late at night when the grid is allegedly 'cleaner', music does seem even higher quality (but then again it may just be the effect of drinking a placebic substance at the time)
"It is not unusual for the supply voltage to vary substantially throughout the day. The average voltage in the UK is around 242V. This means that in the majority of properties, electrical equipment is running at a voltage much higher than needed, resulting in excessive losses in many types of equipment. This is due, in a large part that due to the so called harmonisation of supply voltages in Europe all new low voltage appliances are designed to operate at 230V or even 220V. Therefore it can be seen that much equipment designed to be operated at 230V and 220V may be being supplied with a voltage above this if we consider that the UK average supply voltage is 242V, much higher than is needed....if it is still well within the statutory limits, (i.e. 220 Volts) there will usually also be benefits of increased life and reduced maintenance of the equipment...."
Posted By: LOINER
Date Posted: 06 Oct 2014 at 6:36pm
HARMONISATION MMmm
I think you will find that what happened was that the UK agreed to this, and then when it came the time to do it the UK said sod that it is going to cost to much, and likewise the Europeans did the same,the only difference now is that they are allowed to vary by +or -10% which means it can go as low as 207V and as high as 257V.
Late night listening,yes I agree with you music does sound better with or without the placebic substance.
STUART
GRAM AMP 2SE
Date Posted: 06 Oct 2014 at 7:58pm
It's generally quieter outside at night as well.
Date Posted: 07 Oct 2014 at 12:40pm
I use a mains regenerator (a Powerinspired unit) for source components which outputs
a steady 230V & music still sounds at it's best late in the evening!
This could well be because of reduced outside noise & also just due to a more relaxed &
'receptive' mood for listening to music.
A chilled tipple does help too!
Date Posted: 07 Oct 2014 at 12:55pm
Could variations in frequency play a part as well? According to these graphs I found on Wikipedia it does however seem as if these occur all throughout the day and night in most places.
http://upload.wikimedia.org/wikipedia/commons/b/bb/Variation_of_utility_frequency.svg - http://upload.wikimedia.org/wikipedia/commons/b/bb/Variation_of_utility_frequency.svg
Date Posted: 07 Oct 2014 at 2:03pm
My amp's PSU transformer (which isn't connected to the regenerator but is filtered) buzzes
much more early evening than later at night, suggesting mains sinewave distortion & DC
offset I believe.
Date Posted: 07 Oct 2014 at 2:17pm
This just further demonstrates the need for good well regulated power supplies.
There is plenty of information available, but none of it will help if your power supply filtering and regulation is not up to it.
For live info see: http://www2.nationalgrid.com/uk/Industry-information/electricity-transmission-operational-data/ - http://www2.nationalgrid.com/uk/Industry-information/electricity-transmission-operational-data/ or http://www.gridwatch.templar.co.uk/ - http://www.gridwatch.templar.co.uk/
Date Posted: 21 Nov 2014 at 12:53pm
Hi Drewan77.
I have a monitoring device and my voltage is typically 233-243 - have dropped below 230 but cannot recall seeing over 245v.
Would seriously love to try some form of generation system (e.g. PS Audio) but funds & space preclude.
Would be interested to know what is more typical?
Richard
Date Posted: 21 Nov 2014 at 5:02pm
As I type it's hovering between 236-241 so it seems to be more 'normal' at the moment. I have never tried a power conditioning device but if the improvements I believe I notice during late night listening are indicative, cleaner power must surely be beneficial
