Reflex M - wow!
Forum Name: Write A Review
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2197
Printed Date: 27 Mar 2026 at 5:07am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Reflex M - wow!
Posted By: tpbholm
Subject: Reflex M - wow!
Date Posted: 04 Mar 2014 at 11:48am
I've had my new Reflex m for a few days now. It's been plugged in and powered up since last Friday (28 Feb). My previous phono stage was an inexpensive mass produced one. It came highly recommended by the hifi press and it did a good job. However, I upgraded my turntable from a Pro-Ject Debut Carbon to a Linn Majik LP12 with a Hercules Power Supply and T Kable tonearm cable. I suppose I expected to hear a vastly improved sound with the Linn but although it was definitely better, it wasn't what I was hoping for. So... I considered all the components in my setup and came to the conclusion that the weak link was the phono stage. I then embarked on some research to identify a suitable upgrade. There are no good hifi dealers close to me so I knew I would be buying in the dark so I wanted to minimise the risk of getting a turkey. All my research led me to the Refex M. I considered the loan program but everything I read suggested that I wouldn't be disappointed so I ordered one direct from GSP together a PSU1 and settled down to wait for 2 weeks while it was built and tested. To say I am delighted with the Reflex M doesn't come close to describing the sheer pleasure I'm getting listening to my vinyl collection. This is the vast improvement I was hoping for from the LP12. The best bit is that everyday the sound I am getting is improving from the initial wonderful sound I got on day 1. It's difficult to put into words what I am hearing. There's a presence to the music, a fullness, depth and detail that is stunning. Listening to Neil Young's Live At The Cellar Door LP it's like having Neil in the room (An audience member coughed during Expecting To Fly and I looked around because I thought someone had come into the room!). The Blue Nile's first two LP's are breathtaking - the space around the instruments is almost palpable. For the first time in my long love affair with vinyl I feel I'm getting the sound that I've always aspired to, but never quite achieved. I'll admit to a little nervousness about spending such a (for me) significant sum on a phono stage but I now know that I got serious value for my money. My only regret is that I'll never again experience that initial euphoria I had when I heard the first LP through the Reflex M. Thanks Graham Slee!!
Posted By: fixedwheel
Date Posted: 04 Mar 2014 at 11:56am
Thanks for the great review. Which arm and cartridge are you now using?
I have to admit to be itching to try the Reflex M, with the EXP Combo.
Cheers again, John
Posted By: tpbholm
Date Posted: 04 Mar 2014 at 11:59am
Hi. I'm using the Project 9CC arm and Linn Adikt cartridge which come as standard with the Majik LP12.
Date Posted: 04 Mar 2014 at 12:00pm
Welcome to the forum, Trevor!
Thank you for sharing your experience with the Reflex M. All of us here that have one know exactly how you felt when powering up for the first time, and then letting it settle, drawing you into the music. Out of curiosity what cartridge are you using with it?
Edit - too late, again!
Date Posted: 04 Mar 2014 at 12:02pm
Cheers for the update Trevor
John
Date Posted: 04 Mar 2014 at 10:39pm
tpbholm wrote:
My only regret is that I'll never again experience that initial euphoria I had when I heard the first LP through the Reflex M. Thanks Graham Slee!! |
Well put and thanks for joining us in GSP land!
Posted By: Jackal008
Date Posted: 05 Mar 2014 at 7:53am
Oh, can't wait for my Reflex M and EXP.
It's going with a Funk Firm LSD turn table and Zu Audio DL103 cart, so should put all the rest of my components to shame!
Waiting patiently in antipodeans...
------------- Carl
First album I heard as a kid: LA Woman - The Doors
Posted By: kirschv
Date Posted: 05 Mar 2014 at 7:39pm
Date Posted: 05 Mar 2014 at 8:45pm
Jackal008 wrote:
It's going with a ... and Zu Audio DL103 cart |
Have you compared the Zu variant with any of the other modded 103s, or indeed, a standard one?
It was a path I nearly went down after good experience with a stock 103 a few years ago.
John
Posted By: Lucabeer
Date Posted: 05 Mar 2014 at 9:13pm
I have been using a Reflex M for one month now, and I think I can give the best possible kudos to it. The simple point is that (like with the Solo headphone amp), you tend to FORGET it's there. That's the best compliment I can think of. If it weren't that I have to turn the mono switch when playing mono records, I simply wouldn't think of it. It's there. It does its job perfectly. Nothing more to desire. Simple as that. Transparent.
Date Posted: 06 Mar 2014 at 7:30am
John
Unfortunately I can not provide a comparative comment as I haven't received the LSD with Zu103 cart yet as the TT is also waiting on the dust cover from the UK. Delivery should be imminent though and when I get it all set up with the GSP pre's I'll do my best to give an appraisal. I am coming from a low base though regarding gear so the setup should be very good to me indeed.
Carl
------------- Carl
Date Posted: 06 Mar 2014 at 7:40am
Cheers Carl
No probs on the comparisons. I so nearly went that route, but got offered a stonking cartridge, lightly used, at less than a DL-1033 and a wood body would have cost me.
Nothing wrong with a "source first" approach, after all, you put anything back after you have lost it!
Looking forward to your thoughts when everything is up and runnning.
John
Posted By: Wilki
Date Posted: 11 Aug 2014 at 3:36pm
I have same Majik, adikt and reflex m with same results. Added a linn lingo and even better results. Now on quadraspire wa shelf. Sound sublime. Not hifi it's pure music that's being produced by this combo.
Date Posted: 28 Oct 2014 at 9:31am
All of those thoughts echoed here. I was thinking Era Gold V but decided to go for the Reflex M unheard. Happy times! And I'm finally close to a Rega RP6/Exact combo to make better use of the Reflex! Mick.
Date Posted: 28 Oct 2014 at 9:50am
Aussie Mick wrote:
All of those thoughts echoed here. I was thinking Era Gold V but decided to go for the Reflex M unheard. Happy times! And I'm finally close to a Rega RP6/Exact combo to make better use of the Reflex! Mick. |
Nice to hear you're enjoying your Reflex. I also got mine unheard and it's arguably one of the best purchases I've made. Lots of happy times, lots of "wow!"s.
------------- Proprius, Reflex M, Solo UL, Bitzie, CuSats & Spatia --------------------------------- Johan
Date Posted: 28 Oct 2014 at 11:45am
The more GSP kit you buy, the more you know that it'll out-perform its price-point, and consequently auditions just waste time before getting your own!
Wows and smiles all round!
Posted By: Suggs
Date Posted: 28 Oct 2014 at 2:01pm
Wows and smiles all round!  |
Are you trying to make us loaners redundant?
------------- Derek
Date Posted: 28 Oct 2014 at 2:35pm
There'll always be the un-converted to convince!
Date Posted: 28 Oct 2014 at 5:32pm
morris_minor wrote:
There'll always be the un-converted to convince!  |
Us loaners are usually the first to try and first to buy after auditioning! (or is just me?)
Date Posted: 28 Oct 2014 at 10:26pm
I love my Reflex Era Gold and the Reflex M is almost perfection but I still feel irresistibly drawn towards the forthcoming 'Gold' model
Date Posted: 29 Oct 2014 at 7:47am
My Reflex M continues to deeply impress & so does recently acquired Reflex C.
