PSU required for EXP / MM pre setup?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2142
Printed Date: 27 Mar 2026 at 2:15am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: PSU required for EXP / MM pre setup?
Posted By: Jackal008
Subject: PSU required for EXP / MM pre setup?
Date Posted: 16 Jan 2014 at 10:01pm
Apologies for my ignorance here, reading lots and learning quickly though re pre amps. I'll probably have to brush-up on physics 101 though to get back into the swing of things...
Assuming an EXP / MM pre amp setup is acquired, is there a requirement for the PSU for each component or does the EXP PSU 'clean-up' any power issues prior to sending the signal through to a non-PSU MM pre (probably a Reflex M)?
Appreciate your patience and learned responses.
Carl
Date Posted: 16 Jan 2014 at 10:30pm
Welcome Carl. From my experience one PSU1 can power an Elevator EXP (made in the last 3 years) and a Reflex M if wired up correctly. The power connections are in parallel so the each unit gets its supply directly from the PSU1.
Date Posted: 16 Jan 2014 at 10:39pm
Thats good to hear and means I can invest in decent interconnect cables.
Does 'wiring up correctly' require the skills of a technician or is there a bi-connecting power cable, or similar?
Date Posted: 17 Jan 2014 at 4:42am
And then I found this post which addresses exactly what I had queried: http://audio-forum.gspaudio.co.uk/one-psu-two-units_topic1886_page4.html
Does GSP or can GSP provide a Y cable to power two devices, i.e. EXP and Reflex M? If not, what would be the recommended way to acquire one?? Note, I intend on using the GSP interconnects (CuSats) to address the ground issues.
Im based in Sydney, Australia (currently watching our lads beat up on the English cricket team again in the second one day match 4 for 81 - and its bloody hot over here right now!).
------------- Carl
First album I heard as a kid: LA Woman - The Doors
Date Posted: 17 Jan 2014 at 8:25am
Im based in Sydney, Australia (currently watching our lads beat up on the English cricket team again in the second one day match 4 for 81 - and its bloody hot over here right now!). |
Not a pretty sight to see old England crumble is it? I guess it must be written in the stars. I've noticed a few thoughts appearing on that subject online, but none as good as this...
"As they stared blankly. in dumb misery deepening as they slowly realised all they had seen and all they had lost, a capricious little breeze, dancing up from the surface of the water, tossed the aspens, shook the dewy roses and blew lightly and caressingly in their faces; and with its soft touch came instant oblivion." (Wind In The Willows, Ch.7 Piper At The Gates of Dawn, Kenneth Grahame, 1908)
Regarding the cable, it is not yet a stock item although a word in John C's ear could result in you receiving something which would work - that's username John C, my production director (tel: +44 (0) 1909 568739)
Date Posted: 17 Jan 2014 at 9:13am
| Not an edifying sight for us pommies! As for the heat, Melbourne Zoo lions have big iced lollies to cool off - frozen blood. Nice!
Date Posted: 17 Jan 2014 at 11:01pm
In 1994 I was in Melbourne Zoo at Christmas and went onto the final test at Sydney. Holiday of a lifetime for a cricket fan.
I didn't enjoy England's performance in the Ashes. However I thought Australia's teamwork and resilience was impressive, and their bowling was outstanding. The accuracy and discipline of all their bowlers put pressure on the English batsmen that was telling. It's not the first 5-0 down under but all 100 English wickets fell.
Back on topic: I'm glad you found the "Y-lead" thread inspiring and pleased that Graham has offered John's services.
Date Posted: 17 Jan 2014 at 11:42pm
Tight game, Aus won by 1 wicket with three balls remaining...
Graham - thank you very much for offering John's help, and for WitW passage! Truly much appreciated. I am OS now and will be back in Sydney first week of Feb to follow-up.
PS: Left 30 deg Sydney last night and arrived in -20 deg in Hokkaido today!
------------- Carl
Posted By: LOINER
Date Posted: 17 Jan 2014 at 11:54pm
[QUOTE=Jackal008] Tight game, Aus won by 1 wicket with three balls remaining... The headlines over here were" England snatch defeat from the jaws of victory"
------------- STUART SOLO ULTRA LINEAR DIAMOND EDITION LAUTUS DUAL MONO 1.5M INTERCONNECTS GRAM AMP 2SE
Date Posted: 18 Jan 2014 at 10:05am
...or as Mr Waters put it: "hanging on in quiet desperation is the English way"...
Date Posted: 18 Jan 2014 at 3:15pm
At this time we (English) usually also remind ourselves that it's not the winning but the taking part that counts - As if!!
