Era gold & Dynavector 10X5
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=2132
Printed Date: 27 Mar 2026 at 2:55am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Era gold & Dynavector 10X5
Posted By: brianupnorth
Subject: Era gold & Dynavector 10X5
Date Posted: 12 Jan 2014 at 3:27am
Any one had experience with the Era Gold V mated to a Dynavector 10 X 5? Good, bad, indifferent?
------------- Brianupnorth
Date Posted: 12 Jan 2014 at 3:47am
Brian,
that was the cartridge I was using when I purchased my Era Gold V some 7 years ago. I had already tried another equivalently priced phono and found the EGV to better it.
------------- Tony G
Date Posted: 12 Jan 2014 at 11:06pm
Tony, I am currently using a Rega Exact 2 but am considering the Dynavector 10X5. What was your experience with the Dynavector run through the Era Gold? Brian
Posted By: phildent
Date Posted: 12 Jan 2014 at 11:29pm
Not heard the Rega but the Dynavector is an excellent cartridge,very low surface noise,good tracker and a real fun sound.Itcan rock but also does delicacy.Sounds good through any of the compatible Graham phono stages.Very good value for money and is still one of my 'in use' cartridges. Phil
Date Posted: 12 Jan 2014 at 11:49pm
Hi Brian I've heard the 10X5 and was impressed. I think it would be a noticeable step up from the Rega Exact which I have run on my Rega P3-24 for some time.
Date Posted: 13 Jan 2014 at 1:36am
TBPH I preferred the Denon DL-110.
Subsequent events left a cloud over that, in that the cartridge I had, may have been damaged when I got it.
Date Posted: 17 Jan 2014 at 12:48am
Curious how much you adjusted VTA on your Rega for the Dynavector. I am running an RP6 which I find is much more revealing than the Planar 3 I had for many years, only down side is it is much more fussy about vibration isolation.
Brian
Posted By: Rushboy
Date Posted: 16 Feb 2023 at 1:08pm
I have a question: Is the gain of 41.5 db sufficient to amplify the Dynavector 10x5 MC/HO well? The MC/HO have a lot less gain than normal MM.
Posted By: Ernie
Date Posted: 16 Feb 2023 at 2:15pm
Rushboy wrote:
I have a question:Is the gain of 41.5 db sufficient to amplify the Dynavector 10x5 MC/HO well? The MC/HO have a lot less gain than normal MM. |
Yes, used this combo on an LP12, you’ll be fine.
Posted By: Rushboy
Date Posted: 16 Feb 2023 at 2:22pm
I like the LP12. But I love my Well Tempered even more.
Date Posted: 16 Feb 2023 at 9:27pm
According to the Dyna website, the current version of that cart has around 2.8mV. That is actually not far off from a conventional MM cart, which typically has between ~3-5mV of output. You'll simply have to turn up the volume control a little more, but it should work fine.
Posted By: Ernie
Date Posted: 16 Feb 2023 at 10:15pm
Rushboy wrote:
I like the LP12.But I love my Well Tempered even more. |
Orbe with SME V now, plus a Hana SH and Accession MM. Need to try an Enigma.
Posted By: Rushboy
Date Posted: 17 Feb 2023 at 3:12pm
Okay, maybe I'll get a Dynavector 10x5. I had heard a Dynavector 10x5 , on a Naim Stageline N a long time ago, and it didn't sound very good.
Posted By: Rushboy
Date Posted: 27 Feb 2023 at 1:52pm
Hello, I briefly had a Dynavector 10x5 here to try out. The amplification of 41.5 db of my Accession is easily sufficient. Unfortunately, the 10x5 had a problem with the suspension. Too bad...
