Revox B790 and recommand cartridge
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=21
Printed Date: 27 Mar 2026 at 5:06am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Revox B790 and recommand cartridge
Posted By: FritzS
Subject: Revox B790 and recommand cartridge
Date Posted: 18 Jan 2008 at 2:18pm
Hi, my Revox B790 needs a higher compliance, but today I use an older (about 15 .. 20 years) Ortophon MC 10 MKII with additional weight - the Revox arm is very short and lightwight. So not all cartrige are recommand. I want to install a new cartridge + another cable (?) + a phono preamp.
Which cartridge are recommand? MC or MM? One of my dealer says Goldring G1012 / G1022 / G1042
Revox is an special game but I love this turntable
------------- AKG K812, K872, K712, Q701, K701, K501, K550, K271, Denon AH-D 7000 "Green" SOLO (with LME49860NA), WNA MKII Marantz SA7001 KI, Philips CD650 Revox B790, G1042, Reflex
Date Posted: 18 Jan 2008 at 4:12pm
The 1042 is a Warmer MM than some of the newer ones. I have the Reson Reca which is a version of the 1042 with different profile which makes it a smoother and more detailed than the 1042 but as a consequance more expensive.
Posted By: FritzS
Date Posted: 28 Jan 2008 at 4:23pm
The other way are one of them Ortofon - Vinyl Master silver , Ortofon 540 Mk II or Ortofon VMS 30 Mk II - in price similar to 1042
Posted By: FritzS
Date Posted: 20 Feb 2008 at 5:06pm
I contact some dealers here in Vienna - I think I will buy a G1042.
The Goldring dealer I contacted have a high opinion from gspaudio and Graham Slee
Posted By: FritzS
Date Posted: 26 Feb 2008 at 5:04am
Have I this seen right - the 1042 have no build in thread, but Reson Reca have a build in thread.
The Revox tonearm have a build in thread too.
Date Posted: 26 Feb 2008 at 7:52am
Hi FritzS,
The Reson has a different body which I believe is made of metal rather than plastic, and I suppose they have threaded the holes? I wouldn't see the lack of threads as being a problem in use - few cartridges have them.
Posted By: FritzS
Date Posted: 27 Feb 2008 at 5:29am
I ordered a G1042 now
The phonophono.de dealer tells me he mounted some on B790 turntables too and have best experience
Date Posted: 27 Feb 2008 at 10:21pm
Hi Fritz, it is good you have made a choice, now it is only 500 hrs from sounding its best  Enjoy the ride.
