Suggestion Box 2013
Forum Name: Graham Slee Blog [sponsored by Cadman Enterprises Ltd]
Forum Description: This category is where Graham Slee comments - you can reply - but the rest of the forum is for members postings
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=1674
Printed Date: 27 Mar 2026 at 12:35am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Suggestion Box 2013
Subject: Suggestion Box 2013
Date Posted: 07 Jan 2013 at 8:44pm
Posted By: Baconrind
Date Posted: 13 Jan 2013 at 10:52am
Would you ever consider adding a DAC into the SOLO UL Diamond Edition , this would be a brilliant compact all in one solution for me.
I saw a competitors tube amp with integrated DAC and its something I think would sell. Not sure if I can link so left if out.
Regards Dean
Date Posted: 13 Jan 2013 at 10:55am
Regards Dean |
Dean, my thoughts were very similar if not the other way up...
I thought about including a headphone out to UL spec in the big DAC I'm designing.
Posted By: less
Date Posted: 13 Jan 2013 at 11:26am
I like the sound of that Graham!
Date Posted: 13 Jan 2013 at 11:28am
Regards Dean |
Posted By: mrarroyo
Date Posted: 13 Jan 2013 at 1:53pm
This would be brilliant!
------------- Miguel
Date Posted: 13 Jan 2013 at 2:05pm
+1
Posted By: AlieN
Date Posted: 13 Jan 2013 at 4:03pm
Graham I like your suggestion but I would also see a benefit in Dean's (Baconrind's) request. I do a lot of my listening in my "office" while at a computer, so a USB DAC headphone amp would be fantastic. Even better if it also had line level out. Neil
Date Posted: 13 Jan 2013 at 4:10pm
AlieN wrote:
USB DAC headphone amp would be fantastic. Even better if it also had line level out. Neil | Isn't that the Bitzie?
Posted By: JamesD
Date Posted: 13 Jan 2013 at 4:17pm
Having a top notch headphone out on the big DAC is OK but what happens if someone also wants to listen to vinyl through headphones? Do they need the big DAC with its own headphone amp plus another headphone amp just for vinyl? Or am I not understanding this correctly?
Date Posted: 13 Jan 2013 at 4:22pm
Can always put in a line input.
Posted By: JamesD
Date Posted: 13 Jan 2013 at 4:39pm
Mmm... being someone who listens mainly using loudspeakers rather than headphones I'd prefer the headphone amp to be built into the Aria (if anything), i.e. like most amps/preamps... or just leave it out and use a line out from the Aria so the user can choose from one of your existing headphone amps based on budget and requirements.
However, from the point of view of a headphone-only person I guess the argument could go the other way... plug a phono stage and digital source into the big dac with its headphone amp output and you're all set!
Date Posted: 13 Jan 2013 at 5:24pm
DACs with a headphone socket are very common. DACs with a SoloULDE-quality headphone output are definitely not.
In the past I've had a hifi rack full of kit, each with its own headphone socket. Duplication of sockets would be nothing new, but unless Graham can produce a completely modular product line, where you select what features you'd like in which item, I can't see how some kind of headphone duplication can be avoided.
For my use, I'd love a combo unit - Aria (tone controls and all  ), SoloUL, Reflex M, Big DAC with USB input. A music centre without the source components. And you could put it in an even bigger case with a couple of Proprius amps. Think of the cabling you'd dispense with, and the GSP goodness the thing would have . . . . Dealers could do nice bundles with the appropriate loudspeakers and CD/turntable/streamer of the day. A turn-key GSP system not only for the discerning music-lover, but for the lifestyle crowd too.
Date Posted: 13 Jan 2013 at 5:50pm
For my use, I'd love a combo unit - Aria (tone controls and all  ), SoloUL, Reflex M, Big DAC with USB input. A music centre without the source components. And you could put it in an even bigger case with a couple of Proprius amps. Think of the cabling you'd dispense with, and the GSP goodness the thing would have . . . . Dealers could do nice bundles with the appropriate loudspeakers and CD/turntable/streamer of the day. A turn-key GSP system not only for the discerning music-lover, but for the lifestyle crowd too.  | +1, but without the headphone socket(s) and without the USB input to the DAC, for me. Can a DAC have an Ethernet input or is that only for "streamers"? I'm pretty well up there in terms of ignorance.
Date Posted: 13 Jan 2013 at 6:01pm
Phew Bob, think of the price tag?
I could envisage 1U racking style cases...
Containing a) the Aria, b) the big DAC and c) a stereo power amp...
And they could be stacked (or even racked), or even not have rack ears and use some bling stand...
But a phono stage included? I doubt if we'd achieve Reflex quality sharing the same power supply.
Date Posted: 13 Jan 2013 at 6:10pm
Ifor, you've just demonstrated why this combo unit would be a nightmare to produce! We all have our own preferences, and unless something is totally modular I don't see how Graham could contemplate building it . . . it was a bit of daydreaming on my part, TBH!
As far as the ethernet socket goes, Graham would need to build in some streaming solution - maybe use http://www.streamunlimited.com/v3/en/Stream700.html - Stream Unlimited's offering like a lot of companies do. This would make it a MegaCombo.  (I can't see a little graphic of pigs flying . . .  )
Date Posted: 13 Jan 2013 at 6:14pm
Graham Slee wrote:
Phew Bob, think of the price tag? | But it would be a 10th the price of a Burm**ster combo for 110% of the quality .
(Ok, leave the Reflex out, but put in a Streamer . . .)
Date Posted: 13 Jan 2013 at 6:33pm
As far as the ethernet socket goes, Graham would need to build in some streaming solution - maybe use http://www.streamunlimited.com/v3/en/Stream700.html - Stream Unlimited's offering like a lot of companies do. This would make it a MegaCombo.  (I can't see a little graphic of pigs flying . . .  ) | http://www.animationlibrary.com/animation/23900/Pig_flies_3/
I forgot to leave out the tone controls, but I would like the streamer.
Date Posted: 13 Jan 2013 at 7:33pm
I like the pig!
Now, I'd like the tone controls included on my MegaCombo....but defeatable...
Date Posted: 13 Jan 2013 at 7:42pm
morris_minor wrote:
http://www.streamunlimited.com/v3/en/Stream700.html - Stream Unlimited's offering like a lot of companies do. | I hadn't realised, though I suppose I should have done, that companies buy these units in. Do the companies that use them produce products of different quality due to the way their implementation of the bought in component, or are they all the same?
Date Posted: 13 Jan 2013 at 10:33pm
ICL1P wrote:
morris_minor wrote:
http://www.streamunlimited.com/v3/en/Stream700.html - Stream Unlimited's offering like a lot of companies do. | I hadn't realised, though I suppose I should have done, that companies buy these units in. Do the companies that use them produce products of different quality due to the way their implementation of the bought in component, or are they all the same? | I would imagine that implementation is the key. The bought in streamer board would deliver a stream to the DAC which would be the responsibility of the buying company to fettle.
Date Posted: 13 Jan 2013 at 10:46pm
If that's the case it's definitely on my wish list. Graham?
Date Posted: 14 Jan 2013 at 10:36pm
morris_minor wrote:
As far as the ethernet socket goes, Graham would need to build in some streaming solution - maybe use http://www.streamunlimited.com/v3/en/Stream700.html - Stream Unlimited's offering like a lot of companies do. |
Bob, I was intrigued by this and have been googling it a bit. It seems that several, maybe all, of the big names in streamers use the StreamUnlimited 700. Are you aware of any other units that might be used by others? Do any manufactures make their own? I think we need to know more if we are going to persuade Graham to put this on the 2013 list. maybe I'm just dreaming.
Date Posted: 15 Jan 2013 at 8:42am
Hi Ifor,
I don't know of any others TBH. For a manufacturer to make their own solution they'd need computing/coding skills for the firmware and expertise in assembling the computer components, displays etc. Even for the high-end boutique outfits it's probably not worth getting these skills in-house.
I don't know what it would take to persuade Graham to do a GSP streamer, or MegaCombo music-centre-audiophile-life-style unit? Maybe he could tell us?
I'm thinking airborne  . . . . .
Date Posted: 15 Jan 2013 at 9:45am
morris_minor wrote:
Hi Ifor,
I'm thinking airborne  . . . . . |
I am not Lord Sugar and I don't like music centres which is all a lifestyle unit is or ever will be.
We've been looking into a music server for a short while, or should I say John and Leo have. I'm encouraging them by authorizing a little of the R&D budget in its direction. They need to study what you've been talking about (that's Ifor, Bob and others who've chipped in) and come up with their ideas of a solution. I can then apply the D-A conversion and analogue circuitry and package it.
They are the next generation of this company. Please support them by shopping for the Graham Slee brand whenever you can.
Date Posted: 15 Jan 2013 at 11:16am
Exciting news, Graham!
Date Posted: 15 Jan 2013 at 1:46pm
Very exciting.
Date Posted: 15 Jan 2013 at 2:08pm
Ok, here's my feature list for a GSP streamer:
- Wifi and ethernet
- USB in (as in Bitzie)
- SPDIF in and out
- "Big" DAC performance (96/24 minimum)
- 2 (say) RCA inputs (for phono amp etc)
- Pre-amp
- Solo UL performance headphone amp
IMO a plain "streamer only" box would have too much competition; it needs to have added GSP analogue goodness to be distinctive.
Edit: USB out to host computer with an ADC would be nice for the vinyl-rippers . . .
What do others think
Date Posted: 15 Jan 2013 at 2:27pm
| I would want the full 2 x toslink and 2 x coaxial inputs as planned for Biggus DACcus if this is going to be my DAC rather that a "transport". Does it need analogue inputs, Bob? Aren't they best left to the Aria.
I think we need a poll. If t's just you and me interested maybe the R&D budget is best spent elsewhere.
Date Posted: 15 Jan 2013 at 2:50pm
I think we need a poll. If t's just you and me interested maybe the R&D budget is best spent elsewhere. | Maybe it doesn't need analogue inputs? The market it's aimed at needs to be decided I suppose.
I think if Graham wants a poll he should start one, but at the moment this might detract from the Aria and DAC launches. John and Leo might have had time (maybe??) for a bit of research and then we could know what the parameters or expectations were . . .
But I know of one close competitor with a network music player/controller for digital and analogue sources only a 'click' away, and I've seen it bundled with a matching amplifier too. The goalposts are constantly moving unfortunately . . .
Posted By: Gary
I'd like a streamer that's just a digital transport. Leave the analogue stuff to a good DAC. The other thing to look for in a streamer is user friendlyness. The best in my opinion are the Sonos Connect and the Squeezebox Duet and Touch units. (I use a Sonos at present but have had a Squeezbox Duet in the past).
Date Posted: 15 Jan 2013 at 2:53pm
Hi Gary,
I'm a Squeezebox user and agree that ease of use is key to a streaming system. There are many ways to go with this - maybe we'll get a poll about it sometime?
Date Posted: 15 Jan 2013 at 6:11pm
I agree about the streamer and DAC being different units. The Touch is really easy to use and a couple of long cables means it's in my hands when I am listening to music.
Date Posted: 17 Jan 2013 at 1:45am
So basically you want a micro-computer?
Posted By: Gary
Date Posted: 17 Jan 2013 at 9:01am
Graham Slee wrote:
So basically you want a micro-computer? |
That's the problem, the streamer is just a dedicated computer. You can pick up a cheap second hand Squeezbox 3 and use a good DAC and it will sound as good as a £1000 one box streamer/DAC like the Musical Fidelity Click or even the Naim UnityQute and equivalent Linn with a good secondhand amp. As far as I know the magic happens in the DAC and amplification wich you already have or soon will have mastered.
Posted By: musicdude
Not an other poll .... I'll say no ...
------------- Andy
ProJect Xtension 10 with Clearaudio Charisma V2, GA2 SE, Majestic DAC, CuSat50, Yamaha CD-S1000, Yamaha M-80, Revel F-52.
Date Posted: 17 Jan 2013 at 9:31am
Gary wrote:
That's the problem, the streamer is just a dedicated computer. You can pick up a cheap second hand Squeezbox 3 and use a good DAC and it will sound as good as a £1000 one box streamer/DAC like the Musical Fidelity Click or even the Naim UnityQute and equivalent Linn with a good secondhand amp. As far as I know the magic happens in the DAC and amplification wich you already have or soon will have mastered. |
I totally agree.
But a problem is that folk may not wish to go down the 2nd hand SB route - and Squeeze networks aren't always the easiest to get going. I've had one for about 8 years, and mine now has six players and 4 iDevice-based players on it - and occasionally it throws it hissy-fit.
The new breed of uPnP streamers are hopefully simpler to get going, and the decision that Graham & co need to make is: do they follow the herd and join the rest in offering a streamer (but with markedly superior analogue stages etc), or sidestep this and provide DACs and other components for folk to add on to their existing streamers as upgrades? Following the herd is not a GSP trait, but market trends need to be watched carefully IMO.
Posted By: Gary
Date Posted: 17 Jan 2013 at 10:00am
The only advantage of modern streamers over older Squeezebox's except the Touch is they don't need a computer or NAS running Squeeze Serve (Don't know if its still called that). In my opinion the ultimate streamer was and possibly still is a Squeezebox Transporter and a Squeezebox Controller, the big HiFi companies Naim, Linn and Cyrus to a large extent have only just caught up with it. If Graham can produce a streamer like the Transporter then I'd buy it.
The other problem with streamers is the IT support that would be needed. You just have to look at the forums for Squeeze Box and Sonos to see the problems some people have, usually caused by their own IT ignorance.
Date Posted: 17 Jan 2013 at 10:14am
Squeezeserver is now Logitech Media Server . . .
I use a Transporter in my living room system and it is a quality piece of kit. Recently it's been plugged into an Audiolab 8200AP - via both analogue and digital, and I still prefer the much older on-board DAC than the 8200APs shiny new one.
And yes, IT ignorance is a major factor in folk not getting on with the SB players. If I hadn't worked in IT I'm not sure I'd have stuck with it in the early Slim Devices days.
It's wishful thinking of course, but I wonder how the system would have developed if Logitech hadn't bought Slim Devices out? A much lower key product range, but I suspect it would still be in production and being developed . . .
Date Posted: 18 Jan 2013 at 5:01pm
I've been away a few days and only just caught up with this. Should I understand from the last few posts that, excluding the DACs, whether built in or separate, there are no sonic differences whatsoever between streamers made by, L, N, MF, D, M etc, etc?
If that is the case, what, if anything, do they bring to the party that my iTunes and Airport Express/Apple TV three room system doesn't?
Posted By: Gary
Date Posted: 18 Jan 2013 at 6:31pm
I was relying on experiences I had just over a year ago when I decided I wanted to upgrade from a Sonos ZP90 through a MF X-DACv3 and MF X-150 amp. I listened to a MF M1 Clic with my amp, a Naim UnityQute and Linn Sneaky (last two through their built in amps). None of them could match my original setup for sound quality or ease of use. Now I'm using CuSat50 and Spatia the gap will be even greater. I've no idea what the streamers over £1500 sound like, and I've not heard the Cyrus streamers or anything made by Apple. I ended up replacing the DAC for a Rega.
Date Posted: 18 Jan 2013 at 7:55pm
In essence my Apple based system delivers ALAC files digitally to an Arcam rDAC which feeds my amp. Control is very simple either from iTunes on the iMac or via the Remote app on iPad and iPhone. So music files in iTunes are "pushed" to the DAC, whereas with a streamer they would "pulled" from the iMac. I suppose the question really is whether the software in a streamer would do a better job that iTunes. Maybe there's a lot more to it Han this. I haven't a clue and maybe the Airport Expresses and Apple TV have limitations I don't understand.
Date Posted: 31 Jan 2013 at 8:28am
But I know of one close competitor with a network music player/controller for digital and analogue sources only a 'click' away, and I've seen it bundled with a matching amplifier too. The goalposts are constantly moving unfortunately . . . | The more I think about the more I think that what I want is a single unit containing the streamer and the complete Biggus DACcus. (A streaming DACcus might be called the Pee.). So if such a product were to follow on after the Biggus DACcus I might be very interested.
