What Turntable Mat ?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=1642
Printed Date: 26 Mar 2026 at 10:40pm
Topic: What Turntable Mat ?
Posted By: Paul P
Subject: What Turntable Mat ?
Date Posted: 18 Dec 2012 at 10:31am
Hello. I was wondering what the difference between a Felt Turntable Mat  a Cork and also a leather one  is ? Thanks .
Date Posted: 18 Dec 2012 at 1:04pm
I ditched felt for acrylic and now have much reduced static.
Date Posted: 18 Dec 2012 at 8:23pm
Same experience here.
Posted By: kgilroy
Date Posted: 18 Dec 2012 at 8:37pm
I use a Boston Audio Design Mat which is made out of graphite and does the trick for me.
Keith
Date Posted: 18 Dec 2012 at 11:09pm
Mine is an Inspire Acrimat.
Date Posted: 19 Dec 2012 at 3:01am
Paul,
the effect of those different materials will vary somewhat according to what type of deck you use and the material of the platter, whether it is metal, glass, acrylic or some other material.
To some extent the effect will also vary according to what arm and cartridge you use.
Since none of the materials you mention are expensive, perhaps the best solution is to try them for yourself and see which you prefer.
You could make your own from cork gasket sheet or  a piece of  upholstery leather.
The effects can also be altered somewhat by use of a clamp or weight, you may also wish to experiment with those.
Even changing the support on which your turntable stands will affect the sound produced and may prove a fruitful area in which to experiment.
All good fun, have a try and see what you think.
Posted By: Paul P
Date Posted: 03 Jan 2013 at 8:14am
Thanks for that . What about isolation platforms that the Turntable sits on I've seen ones made by Pro-ject and Russ Andrews any thoughts?
Posted By: kgilroy
Date Posted: 03 Jan 2013 at 8:51am
I have not tried any of the commercial solutions but instead use a 1 1/2 inch block of maple wood underneath my turntable and that is isolated from the supporting shelf with silicone rubber feet from Herbie's audio ( http://herbiesaudiolab.net/ - http://herbiesaudiolab.net/ )
Herbie's is a good source of isolation material.
Keith
Date Posted: 03 Jan 2013 at 9:13am
I've a couple of platforms from SRM/Tech which do the business for me. Stuart's a nice guy to deal with, and was happy to facilitate a bespoke size platform for my little SL7.
Edit: talking about TT mats you'll see that for the QL1 I ditched the Technics rubber mat and had a copper platter bonded on top of the stock metal (steel?) one. Though the rubber mat deadened the ringing a fair bit, the copper makes it totally dead.
Date Posted: 03 Jan 2013 at 10:33am
Those platforms look great Bob. I've used soft wooden cutting boards for small boxes with some success, usually on spikes.
Date Posted: 03 Jan 2013 at 10:46am
Thanks Jon. I also use some small sorbothane feet under some components - you can just see them under the Solo to the left of the QL1. Whether or not these make any actual difference I don't know LOL. But it's nice to know you're giving the kit the best chance of working well . . .
Posted By: LOINER
Date Posted: 03 Aug 2014 at 7:43pm
Just done a quick test with leather and the original felt mat and I thought the leather sounded a little bit clearer but there wasn't much in it.I cant say I noticed any difference in surface noise.
Record Deck ...Rega Planar three (1992)Rega RB300 arm
STUART
GRAM AMP 2SE
Date Posted: 03 Aug 2014 at 9:43pm
My turntable has a rubber mat. It doesn't seem to attract dust or encourage static buildup, doesn't leave any residue on the vinyl underside and provides plenty of grip so that it would never slip during playback. I only have a cheap £90 Ferguson turntable but the last time I listened to it through a HD250II, I thought it sounded pretty awesome.
Date Posted: 03 Aug 2014 at 11:45pm
I can second Bobs' comments about the SRM Tech platforms, I have a SRM Silent Base under a Rega Planar 3, my second turntable. The three adjustable feet also make TT levelling a breeze
Posted By: 16s
Date Posted: 05 Aug 2014 at 2:25am
My TT is on Michells own acrylic iso platform. Very dense. Works well for me.
Rich
Michell Gyrodec SE, Michell Tecnoarm, Ortofon 2M Black, Systemdek IIx 900, RB300, 2M Blue, Rega Fono mkII
Date Posted: 12 Sep 2021 at 7:01pm
I know the colour of the mat makes no difference to the sound quality but the red leather one I use adds a bit of colour to all the black and silver box's in my system. I have tried other materials but I have found that leather works for me, I also tried it with out a mat (acrylic platter) but found the bass was warmer with the mat, plus with the mat I felt that there was no danger of the record slipping on the platter (maybe my mind is over playing things here but I just had that nagging feeling that just wouldn't go away) Got a red mat because my football team plays in that colour.
